My 74 LH
242 replies to this topic
#176 ilovea9x
ilovea9x
  • 230 posts
  • Car:74 LH SL, 03 VY SS
Posted 20 July 2014 - 03:23 PM
Picked up my diff yesterday, got it gutted and started on the grinding.
#177 308mate
308mate
  • 523 posts
  • Name:scott
  • Car:76 SS hatch (Royal Plum, Chevron Chamois interior), HQish Van (Orchid Metallic)
Posted 20 July 2014 - 04:27 PM
Looking good. I like the wheels. They look like a chromed & widened Pontiac rim?
#178 ilovea9x
ilovea9x
  • 230 posts
Posted 20 July 2014 - 05:12 PM
There a HQ GTS wheel that's had the centre cut out and fitted too a new rim, there available in sizes 15-18 and up too 20 wide.
#179 _j.e.d._
_j.e.d._
Posted 21 July 2014 - 07:47 AM
Are you going to be converting the diff yourself? If so, I'd love to see heaps of pics of your jig setup & advise on doing this process mate..cheers  :D
#180 ilovea9x
ilovea9x
  • 230 posts
Posted 21 July 2014 - 09:48 AM
No leaving that too the professionals, I'm just cutting off the old mounts as it works out cheaper if you do it yourself.
#181 _j.e.d._
_j.e.d._
Posted 21 July 2014 - 10:19 AM
Fair enough. What's it cost over there to get that done?
#182 ilovea9x
ilovea9x
  • 230 posts
Posted 21 July 2014 - 11:54 AM
Should be around the $1000 mark and as I'm getting new axles not from them it may end up cheaper.
#183 ilovea9x
ilovea9x
  • 230 posts
Posted 18 August 2014 - 04:42 AM
Got the mounts cut off, just need to grind them flush.
#184 hawk
hawk
  • 2,156 posts
  • Name:steve
  • Car:UC Torana
Posted 18 August 2014 - 06:19 PM
looking good, will be interesting to see how the motor goes.
#185 ilovea9x
ilovea9x
  • 230 posts
Posted 06 October 2014 - 05:31 PM
Picked up this Friday
#186 76lxhatch
  • 7,201 posts
Posted 06 October 2014 - 06:25 PM
Sweet, the shifter is a nice touch
#187 Rob2408
Rob2408
  • 309 posts
  • Name:Rob
  • Car:1974 L32 SLR
Posted 08 October 2014 - 01:07 AM
Can I ask you where you found these wheels?
#188 ilovea9x
ilovea9x
  • 230 posts
Posted 08 October 2014 - 06:15 PM
The guys name is Ewan Wheeler you can find him on Facebook.
#189 ilovea9x
ilovea9x
  • 230 posts
Posted 10 October 2014 - 03:53 PM
Got the box in today was hoping the Toranas crossmember would fit as it's the same mount but it would sit it to high and it was hitting the tunnel.
My old Dellow's crossmember would have worked but it was cut for the celica box but at least it would hold it up for me until I make the new one.
Shifter came out a bit short, would be fine if I didn't want to use the console.
#190 Rob2408
Rob2408
  • 309 posts
  • Name:Rob
  • Car:1974 L32 SLR
Posted 10 October 2014 - 10:44 PM
Thanks heaps.  I'll go and check him out.
Great work on your build  :D
#191 ilovea9x
ilovea9x
  • 230 posts
Posted 19 October 2014 - 11:37 AM
Ended up reversing the shifter and I have a 8" up and 3" out bend hurst shifter coming so my forearm should clear the console now.
Only just needed a small tunnel mod so it would fit.
#192 rexy
rexy
  • 3,714 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 19 October 2014 - 04:03 PM
Love the safety boots!
#193 ilovea9x
ilovea9x
  • 230 posts
Posted 02 November 2014 - 04:57 PM
The new hurst stick still hasn't got here, but I've been playing with the gearboot.
Wanted it to sit up high in the console so it can be seen. The shorter stick doesn't really do it any Justice but I like it.
#194 ilovea9x
ilovea9x
  • 230 posts
Posted 03 November 2014 - 03:19 PM
Gearstick has finally got here, seems to hit the plate when going for 1,3,5 so a little cutting for clearance and it should be good.
#195 orangeLJ
Posted 03 November 2014 - 04:57 PM
What did the box and bell housing set you back if you don't mind sharing?
#196 ilovea9x
ilovea9x
  • 230 posts
Posted 03 November 2014 - 06:47 PM
So far about $4400 as I had to get the clutch plate made to suit.
The bell housing on its own is $700 and box $3150.
Edited by ilovea9x, 03 November 2014 - 06:53 PM.
#197 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 03 November 2014 - 07:50 PM
And its that from Dellow ????
#198 ilovea9x
ilovea9x
  • 230 posts
Posted 04 November 2014 - 03:30 AM
Yes all from Dellow
#199 ilovea9x
ilovea9x
  • 230 posts
Posted 09 January 2015 - 06:07 PM
Getting back to the ignition, my module finally arrived from America and is currently having a mount made for it.
This is what it will look like once it's finished.
#200 ilovea9x
ilovea9x
  • 230 posts
Posted 09 January 2015 - 06:18 PM
Just recived these updates
