webers
_Dan355_
, May 11 2007 03:04 PM
11 replies to this topic
#1 _Dan355_
Posted 11 May 2007 - 03:04 PM
What were the type of webbers that ran on the a9x???
#2 _ultrabluea9x_
Posted 11 May 2007 - 04:05 PM
dan some ran downdraughts,and i beleive some ran sidedraughts as well as conventional four barrels
#3 _Dan355_
Posted 11 May 2007 - 04:22 PM
cheers for that ultrabluea9x
would you know what size they were.
Posted 11 May 2007 - 04:43 PM
48's usually I think
#5 _Dan355_
Posted 11 May 2007 - 05:05 PM
cheers for that dattoman would any one have any pictures.
#6 _purpleLC_
Posted 11 May 2007 - 06:13 PM
The down draught webers used were 48IDF style,
while the side draught (usually on the L34) were 48 DCOE.
Hope this helps.
Hope this helps.
Posted 11 May 2007 - 06:18 PM
a quick search on webers & webbers for the poor spelling, will have you holding a number of engine bay pics
Welby
Welby
#8 _Dan355_
Posted 15 May 2007 - 12:25 AM
Cheers for that Welby
I have found the following pictures the one of the manifold
has to different heights for the webers to mount to and the
engine bay pic shows them at the same height would this
manifold work or would i have to use the one like in the
engine bay and if any body knows can you buy these manifolds.
Posted 15 May 2007 - 12:30 AM
Those manifold adaptors are now deleted from Redline
I'm after one for my own car
All the ones I have seen are level.. maybe the pic is dodgy
Posted 15 May 2007 - 01:33 AM
^ that pic does look decieving but could it have been made off set like that for the duel plenum manifold to keep all runners equal length from butterfly to valve head?
#11 _Dan355_
Posted 17 May 2007 - 09:53 PM
Instead of running the 48 size webers can you use like 45DCOE webers 40 dellortos they will be running on a 308 stroker
#12 _rorym_
Posted 17 May 2007 - 10:27 PM
You need to be a bit cautious on jetting on the 45mms on this setup..better to run a bit rich unless it is on the throttle most of the time. 48mm I am told were a different kettle of fish...but they are rare as hens..
