LX Hatch
277 replies to this topic
#101 Heath
  • 18,393 posts
Posted 28 August 2008 - 06:53 PM
Rubber on the flares looks GREAT compared to all the other jobs I've seen. Really shows off how well the two parts fit together and goes very very well with the rubber strips on the bumpers. Colour is a good choice. WOW that garage had some nice contents!
#102 lx308
lx308
  • 2,843 posts
  • Name:Tony
  • Car:Nuffin. Goin touring.
Posted 28 August 2008 - 09:22 PM
Yeah, just need to get all the contents together! Bloody shed isn't big enough, but I don't think I'll be allowed to delete the garden anymore to expand the shed
#103 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 01 September 2008 - 02:07 PM
Getting some Dynamat down. We intend o do the complete floor right into the spare wheel well. (soory about the phone photos)
A bit busy in this corner.
We are moving along slowly, but at least it's progressing now...
#104 _LX77SL_
_LX77SL_
Posted 05 September 2008 - 04:30 PM
hey mate awesome car. just a quick question what sort of booster and master cylinder are you running??
cheers ayden
#105 MRLXSS
  • 12,414 posts
Posted 05 September 2008 - 04:44 PM
Great work mate! This is a top notch build! I can't wait to do a build like this! Must be so satisfying walking out to the shed and seeing in there!
#106 _LJ355_
_LJ355_
Posted 05 September 2008 - 05:18 PM
Looking real good mate real quality rebuild :clap:
If you dont mind me asking how much did it cost to put the dynamat in ?
#107 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 05 September 2008 - 09:26 PM
From memory, the back half is Torana & the front half is dunnydore. Master cylinder is XC falcon. Datto did the booster for me.
Yeah it is. Will be even better when the bugger's back on the road! The kids are wrecking the place with me & the missus in the shed all weekend...
The Dynamat was $190 for 9 sheets. We will probably use 18 sheets. I hope. We also want to do inside the spare wheel area & then might throw some carpet in there. I was going to ask Boomfunk if he could knock us up a carpet for there.
Thanks for the comments guys.
#108 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 01 October 2008 - 01:44 PM
Got the heater back in. The cables had been fitted the wrong way around on the controls at some time in the cars life, caused us a headache for a hour or so. The under felt is in with heat shield under felt up the front, we also fitted new under felt to the area behind the dash. (more phone photos...)
We have the K frame out to overhaul & repaint, then the driveline can go in & then it's time for the wiring. We are really itching to get the dash back in but I''m sure the sparky wouldn't want too much gear in his way for the rewire job.
The door trims have turned up. I ended up going direct to Easterns & got a set in 3 weeks. :spoton:
I have a sound system to fit. It won't be hard as it's 2 6x9's & an amp which we will plug a ipod directly into.
All slowly moving along, not as quick as I would like but when you only have weekends & kids to also entertain the time is limited.
#109 _The Baron_
_The Baron_
Posted 01 October 2008 - 02:36 PM
Looks great!
Just a thought, front seat mounting will require you to cut out the sound proofing where the seats mount to the floor pan. Fiddly sh!t but it must sit completely against the pan or the seats will come loose for ever.
Also, why not clean/repair the original wiring loom out of the car and just lay it back in?
I did with clothes washing powder in the laundry sink (drove the wife nuts).
Tip thou, don't leave it in the suds too long as whilst the original loop tape has no adhesive, any past repairs with tape with glue will dissolve.
#110 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 01 October 2008 - 03:16 PM
Thanks for the pointer on the seats Baron. I'll get the trimmer (Missus) onto it!
We already have a new wiring loom so we may as well use it up. The old loom would certainly be easier & cheaper, but nothing so far has been easy or cheap so we may as well keep the theme happening :cry:
#111 _Marshall_
_Marshall_
Posted 01 October 2008 - 05:11 PM
Look nice.
what rims and tyres are you going to put on it ???
#112 _Herne_
_Herne_
Posted 01 October 2008 - 05:18 PM
Excellent work, that's a truly impressive and motivational project if I ever I saw one.
Workmanship looks to be of the highest standard.
Herne
#113 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 01 October 2008 - 05:40 PM
Thanks for the comments fella's. It should all be good fun when its going. :rockon:
As for rims they will probably be someing from Billet Specialities. 17x8's & 17x9 or 10's. Thats the plan anyway. Hope the Aussie dollar goes back up by the time we need them. They appear to be good value.
#114 _Marshall_
_Marshall_
Posted 01 October 2008 - 06:16 PM
mmm so it's not going to be 100% legal then ???
I though i was pushing it with 17x7's front and 17x8's rear (17x7's are the legal maximum for WA)
#115 _conceptss_
_conceptss_
Posted 01 October 2008 - 06:27 PM
https://www.banditca...o...639&Style=2
I'll either get the Longbeach, Vintiques, Billet spec. or the Year One 17x10 Snowflakes just like the original Yellow hatch concept car had except bigger.
#116 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 01 October 2008 - 07:19 PM
Not entirely.....
I could get away with 8's easy enough as the license centre has already gave me that, however if you go off the new laws we should be able to run 9's..
We will see. I'm 42 with grey hair so everyone I talk to tell me to go to 10's :spoton:
#117 ls2lxhatch
  • 5,332 posts
Posted 01 October 2008 - 07:51 PM
7" rims were the legal maximum in WA before WA adopted the NCOP. Under the NCOP (page 16) rim width is unlimited but must be appropriate for the tyre fitted. The tyre width and diameter is limited to a maximum of 1.3 time the widest optional tyre fitted by the manufacturer and the diameter must not be more than 15 mm smaller or 25 mm larger than any tyre designated by the manufacturer for that model.
The SS tyre is a CR70H13 which is approximately 200/70/13 with a approximate diameter of 610 mm.
The A9X tyre is a DR70H14 which is approximately 200/70/14 with a approximate diameter of 636 mm.
If the SS tyre is accepted then the maximum width is 200 * 1.3 = 260 and the maximum diameter is 610 + 25 = 635 mm.
You may be able to convince the DPI that the metric equivalent of a CR70H13 is 205/70/13 in which case the maximum width is 205 * 1.3 = 266 mm and the maximum diameter is 617 + 25 = 642 mm.
The 235/40/17 tyre has a diameter of 620 mm and requires a rim 8.0 to 9.5 inches wide, I have approval for this tyre on my LX hatch.
If the A9X tyre is accepted then the maximum width is 200 * 1.3 = 260 and the maximum diameter is 636 + 25 = 661 mm.
You may be able to convince the DPI that the metric equivalent of a DR70H14 is 205/70/14 in which case the maximum width is 205 * 1.3 = 266 mm and the maximum diameter is 643 + 25 = 668 mm.
This means a 265/35/17 which requires a 9.0-10.5 inch rim would be legal.
Edited by ls2lxhatch, 01 October 2008 - 07:53 PM.
#118 _doogs_
_doogs_
Posted 01 October 2008 - 08:41 PM
Nice job mate, looks tops :spoton:
I am envious of that shed full of cars.
#119 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 01 October 2008 - 09:09 PM
I wish that shed was mine. That's where the panel work was done. My shed's barely big enough for 1 car!
#120 _Marshall_
_Marshall_
Posted 01 October 2008 - 09:43 PM
I really should read that code.
ls2lxhatch would you fill in my "Modification application" for me ? :spoton:
Edited by Marshall, 01 October 2008 - 09:44 PM.
#121 kudu
kudu
  • 1,462 posts
  • Car:LH SL/R 5000
Posted 02 October 2008 - 12:07 PM
Just a quick couple of questions for ya. The car looks awesome and its a great job so far and I love the colour. What made you change your mind from the yello?
Also in earlier pics the engine bay is orange but in the last ones it looks a tan colour. Is it just the way it looks in the camera phone?
cheers,
Scott.
#122 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 02 October 2008 - 12:35 PM
Kudu, when we tested the 3 yellows we were looking at they all looked like crap to us. I originally wanted Valencia so that's what we ended up with. Basically what was on the computer screen wasn't what we were seeing in the flesh.
As for the colour change it must be the phone. The shed faces north so it gets some sun in the shed & the camera in the phone doesn't seem to be able to handle the extra light (I presume).
#123 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 02 October 2008 - 02:49 PM
Here's a more colour correct photo.
#124 MRLXSS
  • 12,414 posts
Posted 02 October 2008 - 02:51 PM
That looks shit hot!
#125 76lxhatch
  • 7,208 posts
Posted 02 October 2008 - 04:02 PM
Absolutely awesome.
