LX Hatch
277 replies to this topic
#151 orangeLJ
Posted 20 November 2008 - 08:29 AM
just not so crash hot for XU-1 parcel shelves!
Looks very nice though mate!
#152 lx308
lx308
  • 2,843 posts
  • Name:Tony
  • Car:Nuffin. Goin touring.
Posted 14 December 2008 - 08:21 PM
Well, we've got the diff in, brakes all bled a bit too easy. Fuel tank in & got some 16x7 commodore rims to roll it around on, or so we thought, as the r/h rear tyre rubs & the l/h is clear by about 10mm.......
Rolled it out of the shed & gave it a wash.
Dropped the motor in this morning & the bloody clutch master cylinder hits the rocker cover. I'll have to chat with Mal Wood tomorrow :banghead:
Then we had trouble getting the TKO into spot. I think it's just because we can't get the engine to drop down far enough to get the right angle, but it will have to wait another week now :rolleyes:
It's getting frustrating... :cry:
#153 bullitA9X
bullitA9X
  • 4,168 posts
Posted 15 December 2008 - 08:13 AM
fxxcking awesome job your doing there m8 :spoton:
#154 MRLXSS
  • 12,414 posts
Posted 15 December 2008 - 08:15 AM
MMMMMMMMM! Sexy!!!
Orange hatches! MY FAVOURITE!
#155 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 15 December 2008 - 11:12 AM
Thanks for the encouragement fella's. Made the decision overnight to pull the motor out, move the master cylinder higher. Replace the brake lines with braided lines which will also make some more room around the rocker covers. Then we can also measure up WTF is going on with the TKO.
#156 lx308
lx308
  • 2,843 posts
  • Name:Tony
Double post. Don't know what hapenned there!!!
Edited by lx308, 15 December 2008 - 11:25 AM.
#157 ls2lxhatch
  • 5,332 posts
Posted 15 December 2008 - 02:28 PM
If you are going to remove the motor then I suggest you leave the motor bolted to the K-frame and lift the body off the k-frame. Once the motor and k-frame are clear attach the TKO to the motor and lower the body back on. Let me know if you decide to go this way and I will post pictures of how to get the k-frame to line up when you lower the body back on.
Using the above method I can fit the k-frame with the LS2, headers and transmission in under 30 minutes.
Have you checked the backspace is the same on all your commodore rims?
#158 _rorym_
Posted 15 December 2008 - 03:02 PM
If its VN heads...the clutch master wont clear the rocker cover.....should have asked me!..Lol!....I trimmed the rocker cover to clear. See the back corner bevelled off and rewelded. Also in the pic..hard to see...but you don't seem to have the 45 degree bracket to position the master over the top of the rocker cover...you have absolutely no chance of it clearing without it sitting up in the air like mine.
Edited by rorym, 15 December 2008 - 03:06 PM.
#159 _rorym_
Posted 15 December 2008 - 03:11 PM
Getting some Dynamat down. We intend o do the complete floor right into the spare wheel well. (soory about the phone photos)
A bit busy in this corner.
We are moving along slowly, but at least it's progressing now...
Looking at these pics...your clutch master is WAY too low...no way in the world it will clear the rockers/engine in any way. The heads/rockers sit back within 15mm of the firewall...sorry to deliver bad news .....
Edited by rorym, 15 December 2008 - 03:24 PM.
#160 _rorym_
Posted 15 December 2008 - 03:31 PM
See in this pic...the heater tubes coming out of the firewall about 40mm?...the engine sits 20mm back in past them.
#161 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 15 December 2008 - 04:00 PM
Andy,
The rims were all off the same car so I'm assuming they are the same. There is bugger all room there for these rims anyhow & it could only be 5mm out either side to cause this. Just to have to make sure when Stan measures it we go on the right hand side :spoton:
And right you were Rory :cry:
Lets hope the new under dash setup works....
Also,
Is there different height MSD Dissy's available? Mine sits in the wrong place. I told Bob it was going in Rana & space was limited so we used the smallet cap but, sheesh, the dissy is tall
#162 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 02 January 2009 - 12:01 PM
The clutch master problem should be rectified. Under dash master cylinder from Mal Wood.
#163 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 02 April 2009 - 10:06 PM
Some more movement!!! :clap:
Finally, after xmas, school holidays, building a shed down the coast, trying build a house, running & trying to sell our business - I have got something done on the Torrie. Got some small flexible brake lines with banjo fittings made & joined them up to the hard brake lines. Took 3 goes to get the double flare right. I was running out of line on the rear!. The missus has also got good at bleeding the brakes.
Sorted out the under dash master & lines. Should have enough room there now!
A pic of the shed...
Will try to get the motor back in soon, but the bloody block we want to build the house on needs slashing again :fool:
#164 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 18 April 2009 - 12:58 AM
Mate I have the same underdash master from Mal Wood as you. Did you find you had to modify the pedal at all to make it clear the steering column when you attemp to depress the pedal to the floor?
Mine gets about 2 inches from the floor before hitting it, so I'm having to cut it and reweld it myself.
Dave
#165 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 18 April 2009 - 06:20 PM
Nah. It seems ok. It does just touch the column.
#166 _cruiza_
_cruiza_
Posted 18 April 2009 - 06:26 PM
Yours really is one nice looking hatch, I have never seen an orange one in the flesh, I hope you can put some video up when you get it going.
#167 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 13 May 2009 - 06:56 PM
Well, the sparky has been & done what wiring he can. We are trying take 2 of the engine/box install on Saturday :spoton: . Can't believe it's been six bloody months since we found what would fit & what wouldn't. When we get the engine in the sparky will come back to finsh it off.
Roll on Sat!
#168 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 17 May 2009 - 12:09 PM
Well, it's in!
Found the MSD dissy is too tall.... What have other people found here?
Looks like the rear on the engine needs to go down a bit more, but it can't. I can't come forward any either. It needs a shorter dissy. Do MSD make shorter shaft dissies?
#169 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 17 May 2009 - 12:20 PM
The missus also fitted the fuel filler neck, number plate bracket & tail lights. Went to check out the new rear side trims we got to find that they appear to be made 25mm too short!!
Looks like we need to talk to boomfunk. At least he knows what Torries are supposed to have in them. We should've been talking to him from the start. :fool:
#170 76lxhatch
  • 7,208 posts
Posted 17 May 2009 - 12:56 PM
Looking at the gearbox angle you probably want the rear to come up a bit to get the driveshaft angle right. I noticed that the MSD dizzy is very tall when I compared it to the Accel one I bought - just removed the internal module and run the MSD 6A straight from the magnetic trigger. Maybe its so tall to clear bigger manifolds...?
#171 76lxhatch
  • 7,208 posts
Posted 17 May 2009 - 12:57 PM
Actually if you bring the rear of the engine up, won't the dizzy clear the lip forward?
#172 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 17 May 2009 - 02:36 PM
There isn't enough room in the tunnel to get the 12mm spacers onto the g/box mount that came with the box. I was wondering if the engine was too high but if we turn the engine mount brackets around then I reckon the HE sump will hit the steering rack.
We are supposed to have a MSD 8589 dissy but the picture below shows that the 8589 only has about 50mm fom the mount to bottom of cap, ours has 110.
If the engine could come down, we could fit the spacers & bring the rear up.
#173 _The Baron_
_The Baron_
Posted 17 May 2009 - 03:00 PM
Are you suffering from HQ engine mount-itis?
Your angle of the dangle looks too down at the back.
Ask Welby as he has the same setup and has been chasing vibrations.
#174 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 17 May 2009 - 04:30 PM
Might be. Here's 1 of my mounts.
Attached File  17052009054.jpg   545.17K   56 downloads
#175 76lxhatch
  • 7,208 posts
Posted 17 May 2009 - 04:34 PM
Those are HQ mounts, but don't they sit the engine the lowest which is what you want?
