LX Hatch
277 replies to this topic
#201 lx308
lx308
  • 2,843 posts
  • Name:Tony
  • Car:Nuffin. Goin touring.
Posted 30 September 2009 - 05:25 PM
awesome build thread, very descriptive Posted Image
be awesome once its licened! do you have engineering reports for the mods?
What mods? :dontknow:
#202 ls2lxhatch
  • 5,332 posts
Posted 30 September 2009 - 06:41 PM
Been messing around with plugs, leads, dissy cap in an effort to track down the miss. Had to re set the tappet clearance, as they were all very loose. Engine sounds alive again now but still has a funny choof out the left hand pipe. almost sounds like a burnt valve. It does clean up after 10 mins or so, so I'll leave it for now & get it licensed.
My link
Rear rims arrived, the front rims were incorrect, so we have another 4 week wait. Trying to aim for license next week on the Commodore rims.
Fixed Link
#203 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 30 September 2009 - 06:47 PM
Thanks Andy. I didn't check it...
#204 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 30 September 2009 - 08:54 PM
http://s175.photobucket.com/albums/w125/lx308/?action=view&current=26092009012.flv
Anyone got any thoughts on this miss out the left pipe? I'm not running any cross pipe. The only thing i can think of is the no2 lead has different ohm reading to the rest. I swapped it over to no1 before I did the tappet clearance & it made no difference, then. I haven't done it since.
Edited by lx308, 30 September 2009 - 08:55 PM.
#205 ls2lxhatch
  • 5,332 posts
Posted 30 September 2009 - 11:35 PM
I would run the engine with no 2 lead disconnected to confirm it is the cylinder with the problem. Once you have pinned it down to a cylinder then I would eliminate the plug and lead by swapping in a working plug and lead from the other bank. If the plug and lead do not fix the problem then check compression on that cylinder.
#206 rodomo
  • 18,037 posts
Posted 30 September 2009 - 11:42 PM
Or check compression while he has the plug out? :huh:
Not a true reading with the other plugs in but at least an indication?
#207 _mumbo_
_mumbo_
Posted 01 October 2009 - 08:57 AM
Use your timing light put on all the leads one by one if it does not flash on one you have found it and it is a electrical problem . If that does nt work then its a mechanical miss
#208 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 04 October 2009 - 03:28 PM
Thanks for the pointers. Have swapped all plugs & leads on the left side - no differnce. Did the timing light trick on the leads, all looks good. Did a compression test & all have around the 150 - 160 PSI. The missus gave it a big rev (by mistake) & it seemed to clear up somewhat. Need to get it liceneced & take for a good drive to see what happens from that. :spoton: We haven't burnt 20lts of fuel yet so it still maybe settling a lifter in? It dosent rattle but.
Checked the lights to day as we are booked in for a wheel alignment & licence check on Tuesday & the bloody sparky has wired up the rear indicators together! When you put the l/h or r/h indicator on both rear lights flash. AAAARRRGGGGGHHHH. :furious:
I just rang him, so hopefully we will sort it out tomorrow.....
#209 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 11 October 2009 - 06:26 PM
89King, you jinxed me! All was sweet at the license inspection. Graeme (the inspector) was that wrapped with the car all he wante to do was get in it for the test drive! All passed & sweet, faxed the forms to head office, should be good to go in a couple of hours. Head office, or is that orrifice, rang him & they wren't happy with the tyre size. Said they are too tall. Graeme said that's because they are on Commodore rims with Commodore hubs. Oh, says head office, it's a modified car then, here's the form to fill in...... :Headbang2:
Now I need an engineers who wouldn't mind a pleasant drive out to the country.
I did get to drive it for about a kilometre. Higlight of the week. :rockon:
#210 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 31 October 2009 - 05:04 PM
Rear rims ahve turned up. The front rims were wrong so they have just been made & sent on the 27th. :spoton:
The licensing dept are currently taking 4-5 weeks for mod applications. 2 weeks down & counting....
#211 dattoman
  • 16,487 posts
Posted 31 October 2009 - 05:30 PM
Looks great
And from such humble beginnings
What tyre size is that ?
#212 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 31 October 2009 - 06:08 PM
Getting there Datto. Still don't know what to do with the rocker covers.
Those tyres are 255/40Rx17. Front will either be 235/40, 235/45 or 245/40's. I have the 235/40's, but they might be a bit small on the diameter side.
#213 dattoman
  • 16,487 posts
Posted 31 October 2009 - 06:44 PM
hmmm..... how about some fabricated ones like mine
http://cgi.ebay.com.au/HOLDEN-VN-COMMODORE-HEAD-RACE-ROCKER-COVERS-V8_W0QQitemZ110451751983QQcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item19b76ffc2f
#214 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
  • Car:LXSS, VUSS, VESSv & the mighty HB
Posted 31 October 2009 - 06:59 PM
Hi Tony,
Your car has turned out a treat, its a credit to you, well done.
I have a TKO 600 for my hatch, did you have to move the shifter position or did you leave it in the standard position as in the photo of it siting in the box?
Cheers Paul.
#215 dattoman
  • 16,487 posts
Posted 31 October 2009 - 07:09 PM
Wondered this
STD position in Welbys
But he had to get a different shifter
Seats might be alittle further back though
#216 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
Posted 31 October 2009 - 07:19 PM
I�m pretty sure you can reverse the shifter plate allowing you to have two positions with the standard plate, but weather you need to do this I don�t know.
Yeah it looks like Welby�s seats are further back and has a bent stick to allow for this, I would also guess he would have a peddle box as well.
#217 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 31 October 2009 - 10:36 PM
Right on a couple of counts.
The shifter point is smack bang middle of the factory hole.
I do run a pedal box but have short legs.
The drivers seat is no further back than normally located and i use the standard steering columm.
I swapped the original straight shifter (hurst) for the dog leg to bring it closer to an arc dropping my hand from the steering wheel.
Back to the topic, those rear wheels look awesome, great job so far! So close....
#218 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 01 November 2009 - 10:27 AM
As it is in the box. Welby gave me the std shifter hole measurments & that's where we cut.
Datto, do they leak?
#219 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 01 November 2009 - 10:44 AM
Datto, I have also noticed that they don't have the front & rear bolt holes to hold them down. Only the centre ones.
#220 dattoman
  • 16,487 posts
Posted 01 November 2009 - 11:35 AM
They are Chev
Thats why
oh... you mean the ones on ebay... he says they seal better than factory ones
Guess you'll have to ask him about it
And do they leak.... I'll tell you in 20 yrs when I finish my car
#221 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 01 November 2009 - 01:59 PM
Those rims are the bussiness mate. Great job
#222 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 01 November 2009 - 10:05 PM
If those are the Bocam ones, mate of mine runs them on his Monaro and they are fine. Rubber gaskets.
#223 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 03 November 2009 - 03:44 PM
Thanks. I reckon they look great. Only problem is that I think they will be seen everywhere now.
#224 _doogs_
_doogs_
Posted 03 November 2009 - 04:33 PM
Coming together well mate, sounds mean in that little vid.
#225 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 03 November 2009 - 06:11 PM
Just hope it's not too loud..
