flywheels coming loose
40 replies to this topic
#1 _uglybob_
_uglybob_
Posted 13 May 2007 - 10:01 AM
gday guys as i posted before my flywheel has come loose and now i seem to read alot that they come loose a fair bit. i actually unscrewd the new bolts out of the flywheel by hand yesterday. will it normaly be resolved with just loctite?
ben
#2 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 13 May 2007 - 10:14 AM
loctite will not work. Dowels between flywheel and crank will fix. I broke my crank and block when it happen to me, sheared the heads off 7/16 api flywheel bolts. I had of drove it, i would have lost my feet
Edited by lakeside, 13 May 2007 - 10:16 AM.
#3 _uglybob_
_uglybob_
Posted 13 May 2007 - 10:57 AM
so everyone has had to mod their flywheel in similar ways to keep it on. that sux i only just had the crank linished could hav had to dowels put in then! its just gonna hav to do with a bit of super stud lock for the time being. its gota be driving thursday night when i pik up the old fella from the air port!
does anyone use the lock wire method? has anyone actually welded the end on the bolt in behind the crank?
#4 rodomo
  • 18,039 posts
Posted 13 May 2007 - 11:02 AM
Keep the RPM down til you fix it properly.
If it starts chopping out the end of the crank, its engine out again.
#5 gtrboyy
gtrboyy
  • 3,211 posts
Posted 13 May 2007 - 12:12 PM
You will have to keep the revs way down till you come up fix a permanent fix,a good harmonic balancer,doweling,loctite & tack welding the bolts is what we did that worked on mine.Used to buzz it to 6000-6500rpm regularly.Never came loose on me but did on the previous owner.
I didn't know what the lock wire method was back then otherwise I would have done that instead of doing the bodgy tack welds of the bolt heads to the flywheel.
#6 _evilsim_
_evilsim_
Posted 13 May 2007 - 01:43 PM
I used loctite plus some 'star washers' - thats what I call them not sure if it is the correct name and the flywheel never came loose again.
#7 _dave720gtr_
_dave720gtr_
Posted 13 May 2007 - 01:57 PM
you can drill and tap the fly wheel in three spots in a triangular shape between the bolts right in to the crank just shy the other side. use allen key grub screws then locktite them in along with the fly wheel bolts ! make sure its spotless of dirt and oil in the thread holes / bolts before locktite. arp bolts would be the good ...
Edited by dave720gtr, 13 May 2007 - 01:59 PM.
#8 _uglybob_
_uglybob_
Posted 13 May 2007 - 03:07 PM
ok i think thats what i shall probably do then ill keep the revs down and then wait to do something a little more perminant. all sounds too hard wish i knew it was a problem before. never had a problem with it when i had a manual in it the first time. i think ill probably eventually get applied automotive to drill the bolts i have so i can use the lock wire method, i defiantly dont want to weld it at all. i think ill go and get some star washers and slap it back on with some loctite today and keep it down to 5000.
what is considerd as a good balancer with out going to a romac jobie? that could be a drama as well since i have a pretty average one at the moment.
Ben
#9 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 13 May 2007 - 05:03 PM
all later model blue motors come with a dowel from the factory.
#10 dinky48
dinky48
  • 69 posts
Posted 13 May 2007 - 05:06 PM
Is it a standard flywheel ? I used to have a lot of trouble like u, years ago. Eventually, I took the crank out of the engine, and got a steel flywheel made that was an interference fit onto the back of the crank, and along with 7/16" Grade 8 bolts, fixed it finally !
#11 _82911_
_82911_
Posted 13 May 2007 - 05:41 PM
DON'T USE STAR WASHERS IF YOU VALUE YOUR FEET
Star washers will "pound out" and allow the bolts to come loose. Evilsim, I'm afraid you were just lucky!
What you need is the hardened and ground undercut washers. They are what is supplied for head stud kits. They are flat on one side and have an undercut chamfer on the other side.
The washer is installed with the chamfer facing the flywheel.
Red loctite annd 3 dowells.
Interferance fit on the spigot is nice too if you have access to a lathe and can Knurl...
Oh... and lockwire is also a good idea, if needed.
FORGET THE WELDER.. that is rough....
Cheers Greg..
#12 piquet
piquet
  • 857 posts
Posted 13 May 2007 - 05:50 PM
before you go down the pathways that heae been sugested it may be worthwhile doing a bit of research first.
have you checked out the runout on the flywheel?
this is fairly easy to do witha dial indicator on the clutch face of the flywheel.
There is a tolerance in the workshop manual as to the max allowable runout.
If the run out is within the tolerance it may be a simple fix with a dowell or two.
This is best done with the crank and flywheel out of the car as is also the drilling and fitting of additional capscrews or bolts.
If it is outside the tolerance it could indicate either a warped flywheel or a bent crankshaft. A warped flywheel would be an easy fix, just get another one. A bent crank is a teardown(sorry) and rebuild.
I had a crank that was cracked in the radius of #6 Bigend allowing the whole back of the crank and flywheel to wobble. This caused loose and broken flywheel bolts.
hope its fairly straight forward
piquet
#13 Stedz_lc
Stedz_lc
  • 1,144 posts
Posted 13 May 2007 - 06:02 PM
oh more money! Anyone got any photos of the dowel's and how/best way to do it
#14 Stedz_lc
Stedz_lc
  • 1,144 posts
Posted 13 May 2007 - 06:05 PM
#15 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 13 May 2007 - 06:06 PM
don't work
#16 _82911_
_82911_
Posted 13 May 2007 - 06:16 PM
Too general Lakeside.....
It might work depending on how bad the harmonics in his engine are....
It didn't work for you because your crank was cracked....
We have been over this a thousand times... :banghead:
move on.
Cheers Greg..
#17 Stedz_lc
Stedz_lc
  • 1,144 posts
Posted 13 May 2007 - 07:25 PM
I take it this will be another job for the machinist
#18 turbotrana
turbotrana
  • 155 posts
Posted 13 May 2007 - 07:40 PM
I get the machinist to drill and tap 4 extra threads inbetween the existing bolts to accept
4 allen key bolts. Then loctite and it will never come lose.
In the turbo tory I have an alluminium flywheel and I only use the standard holes with Stage8 bolts and loctite and never came lose.
While your on the flywheel end you must also address the harmonic balancer end.
For this I have it drilled and tap to accept a chevy balancer bolt. The most important thing is to have the keyway milled to accept a much larger key. Otherwise you will chew these out. Easiest way is to get a metric key which is slightly wider than the existing one but you machine the top half of the key to the original width. Overall the keyway will be deeper and longer.
Then get a good bonded steel balancer.
I only ever use VK alloy timing gear and you must either weld them on the cam with 3 quick tack welds (TIG) or grub screw them in to they dont come off.
Its all these little bits that get you a reliable engine.
#19 _82911_
_82911_
Posted 13 May 2007 - 08:45 PM
I'm interested in the"weld the gear to the cam" idea...
I'm wondering...
A: how do you weld aluminum to cast iron?
B: if the gear was to move forward, where would it go? The timing case is in the way...
I know that cam thrust is an issue in a small block but i've gotta say i've never seen it in a Holden 6...
Having said that though, I have to date, rebuild about 20 or so engines for HQ racers and most of them had a bolt in the end of the cam to retain the timing gear...
Educate me please... I don't know why people do this?
Cheers Greg..
#20 turbotrana
turbotrana
  • 155 posts
Posted 14 May 2007 - 01:17 AM
The alloy timing gear has a steel hub with the timing gear cast around the steel hub. I've never seen an all alloy timing gear but they may have changed the design of late.
Why the timing gear slides off the end of the cam under heavy usage. I am not really sure but I thought it was a reason why there are straight cut timing gears.It may be that the helical gears are pushing the gear off in either heavy acceleration or deceleration just by the nature of the angle designed. Even crank harmonics may have something to do with it or even high volume oil pump may have something to do with it. The cam thrust plate gets chewed out because of the pressure the helical gears or whatever put it under. Thats why I have a seperate oil feed going to the thrust plate area. Nevertheless the VK timing gear is still the way to go IMO.
Many moons ago I was dealing with big solid lifter camed XU1 type motors that reved out to 7500rpm and once it happened a couple of times I just fixed it permanently.
A bolt and washer is probably the proper way to go but we just welded or scrub screw it. I didn't think there was much room between the cam and timing cover to put a bolt and washer.
If the gear moves forward it actually allows the cam to move backwards before maybe hitting the rear core plug and the gear hitting the front timing cover case. Timing will alter quite a bit also. Thats how you diagnose it.
#21 Stedz_lc
Stedz_lc
  • 1,144 posts
Posted 14 May 2007 - 07:58 AM
More things to add to the list of to do things!! keep it coming!
#22 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 14 May 2007 - 09:19 AM
Greg, what stops the flywheel moving slideway at big revs? His is the way it broke the first time.
#23 dinky48
dinky48
  • 69 posts
Posted 14 May 2007 - 07:21 PM
What Broke ? I forgot to add that the steel flywheel was dowelled also, engine was in an FX, so I had no room to run a bigger balancer unfortunately, on Greys they used to use M.F.Tractor balancers sumtimes. That 202 in the FX pulled over 7000 in 1st. & 2nd gears, dragged it heaps, and never had any more loose flywheel trouble !
#24 _Bomber Watson_
Posted 14 May 2007 - 08:17 PM
has anyone found this problem with a flexplate?
#25 TerrA LX
Posted 14 May 2007 - 08:55 PM
Flex plates usually just crack
