might have to look at kevlar trans blankets
Posted 14 May 2007 - 09:40 PM
Posted 14 May 2007 - 09:57 PM
Posted 15 May 2007 - 02:30 AM
Ok, another wear point is the rear thrust bearing on the thrust faces. This wears alot with manuals and the only thing feeding any oil to it is based on oil splashing into a very difficult to get to hole.(you will know what hole I am referring to if you have a look.) You can grind a concave section on the top side of the hole to catch more oil but what I do is make another oil feed to the thrust bearing on the flywheel side.More things to add to the list of to do things!! keep it coming!
Posted 15 May 2007 - 05:32 PM
This is the reason I have to build another motor. The thrust ring on my crank was worn that thin that it was about to snap off crank. How did I know something was wrong, when I pushed the clutch in, the flywheel would hit back of engine. Keep the straight 6 tips commingOk, another wear point is the rear thrust bearing on the thrust faces. This wears alot with manuals and the only thing feeding any oil to it is based on oil splashing into a very difficult to get to hole.(you will know what hole I am referring to if you have a look.) You can grind a concave section on the top side of the hole to catch more oil but what I do is make another oil feed to the thrust bearing on the flywheel side.
Posted 22 May 2007 - 07:20 PM
Posted 22 May 2007 - 07:56 PM
You know what Troy.2.Some advice on here i took didnt work regarding flywheel advice, at alot of time and expense
Posted 22 May 2007 - 08:12 PM
Posted 22 May 2007 - 09:00 PM
MY flywheel has flown off twice now and im really p#$ed off!
1.Standard flywheel bolts are shit
3.Im biting the bullet and going yella terra aluminium with arp bolts clamped down to 90 pounds not 45-55 as stated .I will keep you informed if it works or not.
Posted 26 May 2007 - 04:38 PM
Posted 26 May 2007 - 05:50 PM
Posted 27 May 2007 - 01:16 AM
Posted 27 May 2007 - 10:06 PM
after comming off the first time, wouldn't you sit back and think, why did this happen. You only have 2 feet and ones no good without the other, trust me.MY flywheel has flown off twice now and im really p#$ed off!
Posted 04 June 2007 - 11:00 PM
Posted 05 June 2007 - 09:19 PM
Posted 05 June 2007 - 09:26 PM
Posted 05 June 2007 - 09:42 PM
you still understand why you use the dowells, i think.Problem solved,Loctite thread locker,90 pounds torque,arp bolts,yella terra flywheel,all good
