fuel injecting 202 red
25 replies to this topic
#1 _mitch74_
_mitch74_
Posted 19 May 2007 - 04:38 PM
hey guys ive got a 202 red motor and a chick at work has a fuel injecting system kit for her black 202 i was wondering if it would all work on mine and whats the work invloved in it shes got all the parts to do it. also she herd you cant have a cam with it??? is this true.
cheers for the help
#2 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 19 May 2007 - 05:15 PM
You can fit the blue motor head to your red and then all the gear onto that. Use a blue motor head gasket as a template to see what holes need to be filled and what needs to be drilled.You need to use the VK EFI cam (which is meant to be close to that of LC XU-1?) as it is best suited to the long runners of the inlet manifold and it doesn't pulse the airflow meter.
Edited by FastEHHolden, 19 May 2007 - 05:17 PM.
#3 orangeLJ
Posted 19 May 2007 - 05:35 PM
im fairly sure the idea of not having a large cam is due to the computer. if you were to use a big camshaft you would need a computer edit i would assume.
#4 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 19 May 2007 - 07:17 PM
Which you cant do because they are an analogue system..there is nothing to edit..no chip to change. With a lumpy cam the inlet airflow wouldn't be constant and this would cause the vane of the airflow meter to swing backwards and forwards....causing more fuel to be injected than is required.
#5 _willo_
_willo_
Posted 19 May 2007 - 07:35 PM
there was an aftermarket "intelligent" setup available that was suitable for use with modified motors... but i can't remember the details
#6 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 19 May 2007 - 08:07 PM
There are heaps of aftermarket systems ranging from cheap simple jobs like Eagle and Wolf, up to all singing all dancing ones like Motec ect. You could get a Delco system off a Camira or VN Commodore and get the chip written to your application.
But as was discussed in another thread...you could modify the sensors of the stock system to get around their weaknesses.
For example the air flow meter is a vane style job, it has a flap that opens wider the more air that flows thru it...this is a restriction...if you were to remove the variable switch section and connect it to the throttle linkages it could still work correctly yet not inhibit airflow.
But it also depends on what the aim was...if you just wanted a simple EFI system I would just plonk the stock gear on and drive it. If the aim was all out performance I would go programmable engine management...with whatever other mods you wanted.
#7 _gstar_
_gstar_
Posted 19 May 2007 - 08:13 PM
efi 202 over rated
At the end of the day i think you would be more happy with some webbers, or any kind of forced induction.
#8 _hatcheddan_
_hatcheddan_
Posted 19 May 2007 - 10:01 PM
Heres a few picks of the motor I originaly bought for my hatch but I just ended up thrashing it around for a while and sold it
( is'nt that what ya do with commodores )
I'm not sure on the exact specs coz I did'nt build it but it was some thing like this
Red 202 block, 12 port alloy yella terra head, stage 3 heat seeker cam, Steel crank, genie extractors, VK injection, Gas reaserch throtle body, cold air intake,electronic ignition , gilmer drive belt and backed by a celica 5 speed and lsd.
I was gonna add a castlemain rod shop supercharger kit but I ended up going with a V8 insted. I'm spewin now coz the head alone was worth more than what I sold the car for.
But trust me THIS THING HAD NUTS. :D
Apparently 7K was spent on the drive line and gas system and was built by one of the HRT engineers. But who knows ?
#9 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 19 May 2007 - 10:47 PM
Hmmm..steel crank? 202?
Alloy head? that head doesn't look like one to me...but you are right, they are worth a ton...mine cost $2300 new
#10 _hatcheddan_
_hatcheddan_
Posted 19 May 2007 - 10:59 PM
Yeah like I said I don't know the exact specs of the motor this is just what the previous owner told me. but the bloke I sold it to has been offered 2 grand just for the head
#11 rodomo
  • 18,038 posts
Posted 20 May 2007 - 01:25 AM
Something like a Cyber lumpy cam? :blink:
#12 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 20 May 2007 - 11:59 AM
without the power :blink:
#13 _73LJWhiteSL_
_73LJWhiteSL_
Posted 20 May 2007 - 12:10 PM
Now thats what i want to do... VK EFI manifold with a Gas research carb bolted onto it.
What did you do about the injector holes? I was thinking of turning up some 'plugs' on a lathe and then sealing them in with some gasket sealer.
Steve
#14 orangeLJ
Posted 20 May 2007 - 12:34 PM
or just weld them up i would think.
#15 rodomo
  • 18,038 posts
Posted 20 May 2007 - 01:43 PM
Steve
You might find welch plugs to fit or tap them and find grub screws or threaded plugs from Pirtek or Enzed.
#16 _SLRMike_
_SLRMike_
Posted 20 May 2007 - 06:23 PM
Hey Mitch74,
Now this is just my 20cents worth, your car, your money, do what you want.
But this is my opinion.
I went thru the same process more than a decade ago. I wanted to keep the 202 in my car but wanted the grunt as well. My process was this, a VK EFI 202 Black motor and gearbox/trans would set me back about $1500 with the computer and loom, and overall the swap was straight forward, cross member, tailshaft, diff and rad all the same, simple after the auto sparky wires it in. But then there are these issues, the VK injector system take the injector timing from a sensor behind the head and mounted at the top of the bellhousing with a timing mark on the flywheel, so you have to use the VK setup auto or manual with a cable clutch, clearance for the sensor becomes a problem because its a tight fit and its plastic and expensive to break one while fitting the engine but a pain to fit after the engine is in. Now in SA you must run a cat converter and change your fuel filler and the pollution gear etc just to pass Transport SA (our RTA) Next problem, the EFI 202 is good for 170BHP according to GMH (if thats to be believed) now your 6cyl brakes wont stop you so time for an upgrade, V8 booster is simple but the six wont produce enough vac to run it so your back to square one, so your up for mods to get passed the RTA. And only 170HP so do the mods on the motor like your implying and guys here are saying $3-5k should do it, and I'd think $2500 should get you started with a basic setup right?
Now consider this, 253 V8, 180BHP straight out the box, stock, cost to convert to V8, well engine, trans,brakes,diff, tailshaft,radiator, I would be suprised if it cost more than $1500, done in a day, no dramas with RTA and would give the 202 a good run for its money, easy. Spend the extra $1k on mods like a decent carb and cam/heads and 200-220BHP easy a bit more than you'll get from the 202 for the same bucks. Go 308, 240-250BHP stock, the 202 wouldn't blow wind up its backside.
But like I said, your car, your money, do what you want.
Mike
#17 _hatcheddan_
_hatcheddan_
Posted 20 May 2007 - 07:45 PM
The engine in the photo's on page one shited on my 253 LX but it apparently had 7k spent on it. What do ya get when ya spend 7k on a holden V8 ?
Lots more fun :D
#18 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 20 May 2007 - 07:51 PM
gas research sell them i think..but i reckon just make them.
#19 rodomo
  • 18,038 posts
Posted 20 May 2007 - 08:06 PM
I could be wrong but I thought E.F.I was only available with auto?
#20 orangeLJ
Posted 20 May 2007 - 08:12 PM
i had a VK calais efi with a 4 speed manual, had a manual computer so im assuming you could get efi with manual, we later put a 5 speed in it. but yeah i had a manual efi 202.
#21 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 20 May 2007 - 08:15 PM
Strange?? as EFI was auto only.
#22 _SLRMike_
_SLRMike_
Posted 20 May 2007 - 09:26 PM
I thought there was a manual, 5spd EFI, could be wrong.
#23 orangeLJ
Posted 20 May 2007 - 09:29 PM
there had to be, otherwise i wouldnt have had a manual cmputer to put in my VK, just owuldnt make sense would it!
#24 rodomo
  • 18,038 posts
Posted 20 May 2007 - 10:39 PM
I'm desperately trying to stuff the worms back in the can now :blink:
#25 _73LJWhiteSL_
_73LJWhiteSL_
Posted 20 May 2007 - 11:30 PM
Stuff the injection, bolt a GRA carb on it and you'll never look back. :spoton: :rockon: :rockon: :rockon:
Steve
