Chassis Kit?
Posted 21 May 2007 - 07:48 PM
Just wonderin what ppl's thoughts are on chassis kits? In this case Lc torana and lx hatch back, do they work are they worth it? CRS the way to go? any comments welcome!
#2 _LJ355_
Posted 21 May 2007 - 08:00 PM
#3 _Monkey_
Posted 21 May 2007 - 08:07 PM
This is the lc-lj one
Posted 21 May 2007 - 08:22 PM
#5 _wayneo_
Posted 21 May 2007 - 08:37 PM
#6 _Monkey_
Posted 21 May 2007 - 08:45 PM
Posted 21 May 2007 - 09:10 PM
#8 _LJ355_
Posted 21 May 2007 - 09:19 PM
Posted 21 May 2007 - 11:38 PM
Posted 22 May 2007 - 01:31 PM
#11 _LX_SS_
Posted 22 May 2007 - 04:00 PM
i highly wouldn't recommend them for anything, and would recommend making one yourself to suit would be a better application.
#12 _STEVO_
Posted 22 May 2007 - 04:51 PM
is that about all i need for stength and to stop twist with the BBlock engine?
#13 _JBird_
Posted 22 May 2007 - 05:10 PM
Dont you already have a chassis kit on yours?Anyone know if getting a 4pt or 6pt cage welded in would have the same effect as a chassis kit?
Also, doesn't the CRS one have an engineering cert. or something. Because like Wayneo said, there looks to be nothing to them, and maybe the only reason (I can see) why people buy them would be for engineering purposes?
Posted 22 May 2007 - 05:23 PM
#15 _JBird_
Posted 22 May 2007 - 05:29 PM
Thats what I meant OJ
Posted 22 May 2007 - 05:42 PM
The reason u want the engineers certs with the CRS stuff is when u install the rails for a motor upgrade. eg Lj v8.
Adam
Posted 22 May 2007 - 07:12 PM
No,it's not required for engineers.That is what the engineer said anyway.Dont you already have a chassis kit on yours?
I'd rather put a cage in it if that would strengthen the car up then add more weight to it by putting in a chassis + a cage.On top of that I just don't like the crs kits & my lc is heavy enough IMO.
Posted 22 May 2007 - 08:43 PM
Posted 22 May 2007 - 09:04 PM
#20 _JBird_
Posted 23 May 2007 - 10:33 PM
You see a lot of weekend "drifters" use a cross brace inside their car connecting the rails where the b pillars meet. Competition "drfiters" would run a cage of some sort.
(all this from an engineering perspective).
#21
Posted 24 May 2007 - 01:05 AM
I'm no engineer but I reckon a 6 point cage with a diagonal bar would be more effective than the rail kit. The rail kit appears to only join the front suspension to the rear and the shell would still twist (your sills and tunnel are strong enough in my opinion to join the the front to the rear) where as a cage with diagonal bar should eliminate more twist.Im more after to stop twistin etc as ive only got a six with a bit or work, not for engineers etc yea im thinkin of makin my own has anyone got some decent photos of a kit installed/uninstalled?
Ultimately the gage joined to the chassis kit where possible would be the answer but weight would be an issue and fixture if the cage is ally.
Edited by rodomo, 24 May 2007 - 01:19 AM.
#22 _rorym_
Posted 24 May 2007 - 06:19 PM
Stedz...Just home but send me your email address and I will send you pics..The cage with the chassis kit allows me to jack the car under the front wheel...and that whole side of the car comes off the ground as a unit...its stiff all right. The cage in the LH which is 6 point and picks up the rear suspension points does exactly the same thing..so from experience...the cage does stiffen the whole unit to a serious degree! (Sorry James!)...For a 6 cyl LJ I would definately fit the chassis kit..even with a cheap..off Ebay... 4 point alloy cage...if you are weight conscious.Hey all
Posted 25 May 2007 - 11:20 PM
#24
Posted 26 May 2007 - 01:41 AM
Comparative tests were performed on the standard and reinforced vehicles. It was found that the bending strength of the vehicle is increased by approximately 30%. whilst the torsional stiffness in increased by approximately 40%.
An engineers certificate is required for the chassis kit in WA.
#25
Posted 26 May 2007 - 09:10 AM
Do you have any info on cages?
My theory is based on:
Cut the roof off a car and drive it versus cut the floor pan out and drive it.
Which will last longer?
