![](https://secure.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e?s=100&d=https%3A%2F%2Fwww.gmh-torana.com.au%2Fforums%2Fpublic%2Fstyle_images%2Fblackstream%2Fprofile%2Fdefault_large.png)
LC/LJ Legal side dump pipe
_troy_
Posted 29 May 2007 - 08:28 PM
Posted 29 May 2007 - 09:22 PM
http://www.dotars.go...es_3Feb2006.pdf
Page 6.
The outlet of an exhaust system must be rearwards of any passenger side entry door or opening window.
Exhaust systems must provide a minimum of 100 mm ground clearance.
The maximum exhaust noise for a 6 cylinder measured at 3200 rpm is 81 decibels.
Edited by ls2lxhatch, 29 May 2007 - 09:23 PM.
Posted 30 March 2024 - 01:21 PM
NCOP3 Section LA Engines 3 Feb 2006 [PDF: 580 KB]
Page 6.
Website has been updated to this:
https://www.infrastr...1jan2011_v3.pdf
Posted 30 March 2024 - 05:36 PM
Posted 30 March 2024 - 05:47 PM
So you can have it exiting kerbside pre 1988, but needs to be aft of opening rear window. Is that doable on a torrrie?
Non-opening passenger window maybe?
Posted 30 March 2024 - 06:12 PM
Posted 31 March 2024 - 06:00 AM
No.
Posted 31 March 2024 - 09:41 AM
the only cars that a legal in wa with pipe on curb side is a hot rod pre 48
and no side exit with any opening windows
did a dodge at4 pickup with full ve commy running gear
did side exit on both sides , had to remove curb side pipe for licensing
Posted 31 March 2024 - 04:44 PM
![5529473a38b20b57c8600d2c70742505.jpg](https://uploads.tapatalk-cdn.com/20240331/5529473a38b20b57c8600d2c70742505.jpg)
This is legal in SA due to vehicle age, but the cops assume it isn’t.
Posted 31 March 2024 - 06:28 PM
He's pretty picky Clay,
Pre-1988, 400mm away from an opening, 100mm off the ground, and with-in the outside of tyres.
Exhaust tip should be angled down at 15 degrees.
Nice chrome:
Booked for side pipe.png 1.2MB
3 downloads
Posted 01 April 2024 - 05:40 PM
![](https://s3.amazonaws.com/tapatalk-emoji/emoji16.png)
Posted 03 April 2024 - 10:01 AM
I put a 2.5 inch side pipe on mine for an event at Bathurst a couple of years ago.
As much as I love the sound, I took it off again as they aren't legal in NSW because it's not far enough from the door or the side windows that can open.
I did get both systems made so i can easily swap them for when I feel like being a hoon
