* * * * * 1 votes
The Shed Thread
878 replies to this topic
#451 LXCHEV
LXCHEV
  • 3,551 posts
  • Car:'76 LX - 383 Chev
Posted 09 November 2013 - 08:30 PM
Hey guys,
I notice a lot of people do their slab first, whereas others do the structure first, and then lay the slab into it.
What are the pros and cons of each method? I can't decide how to attack mine (hopefully I will be contributing to this thread next year sometime).
Keep all the pics, sizes and info flowing!
#452 rodomo
  • 18,032 posts
Posted 09 November 2013 - 08:32 PM
Mine has the slabs layed up to it. The shed is 20yrs old. The bottom of the gal sheet has rusted.
#453 _LS2 Hatch_
_LS2 Hatch_
Posted 09 November 2013 - 08:43 PM
I put the shed up first then poured the slab inside. When it rains I get no water inside, and also no wind. Up my way that's handy cause the wind has nothing to stop it.we are fairly open. For me, I would do it again the same way. Only down side, you loose 150mm height inside. Not a real issue though.
Just have to make sure it won't muck up the doors in the openings.
#454 dattoman
  • 16,487 posts
Posted 09 November 2013 - 08:53 PM
Mine will have the shed up and the slab done later
Theoretically
I have an existing slab from the old shed in place though its not large enough
So they will build the shed around the slab and I fill in the leftovers
I won't be losing any height as my shed builder uses 3.1m sheets for a 3.0m wall
So nothings lost and council doesn't seem to mind
So they work to a 3.0m finished height above floor level not ground level
#455 LXCHEV
LXCHEV
  • 3,551 posts
Posted 09 November 2013 - 09:02 PM
I'll be cladding mine with weatherboards, so I'm thinking slab first may be easier for this method?
#456 _Hamster_
_Hamster_
Posted 09 November 2013 - 09:48 PM
......You can still do that with a raised slab and overlap the sheets of iron 50mm or however much you like over the edge of the slab. No water/wind will get in that way either,
#457 rodomo
  • 18,032 posts
Posted 28 December 2013 - 08:48 PM
I just need a good erection to get it up.......................Single phase, 2 poster $1880 delivered.
#458 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 28 December 2013 - 08:51 PM
fwooaaar.
#459 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 29 December 2013 - 09:25 PM
Yeah baby, i want one.   :spoton:
#460 j...
j...
  • 54 posts
  • Name:Jason
Posted 15 January 2014 - 07:27 PM
Ok guys. i need you help. Time to build my shed. I know that the measurement are going to be 9000x6000(gable end) by 3000high (at the eaves). I am planning to have 2 roller doors in the 9000mm side with a 3 meter workshop. What I need from you experienced shed builder/buyers is some tips and recommendations on what to look for in a shed. I have done some quick quotes online. These surprisingly vary by upto $2000. I would like to know what questions I need to ask to compare the quality,functionaly and value of the shed. These are the areas I have though of so far:
Base Price
Delivery To home
PA Door Extra
Plans
Total Cost
  Roof TCT
Roof Profile
Walls TCT
Wall Profile
Gutter Type
Rafters
Mullions
Purlins
Wall Gurts
Residential Reg
Terraine catergory
Wind Catergory
I was hoping someone could explain the last 3 sections(Res Reg, Terraine And Wind Catergory) so I have an understanding of the implications of these.
Maybe I am over analyzing some things, but I really enjoy understanding/learning about different things. Plus I just want to make sure i get the best bang for my buck! I am also very handing so I will be building this myself, but will be getting the concreting done. Is there any other things I need to think of Eg Power( I know a give) but other things like water connection(is it worth it?)
Edited by j..., 15 January 2014 - 07:29 PM.
#461 Ice
  • 15,193 posts
Posted 15 January 2014 - 07:34 PM
Always good to have a wash trough to wash your hands
3 phase power is god to if you can afford it
Good to
#462 RallyRed
  • 8,115 posts
Posted 15 January 2014 - 08:09 PM
Hi...as Geno says 3 phase power is good , if you need it for your equiptment.
However "these days" for somewhere around $400 you can get a 1 phase to 3 phase converter ( VVVF drive ).
For that sort of coin, you get a top name brand unit that can run stuff at whatever speed you like from virtually 0rpm to 10  times its normal speed ( should you be feeling brave). Reversing direction is easy as ,too.
If you just want a bit of 3 phase power, it can just be left set at 50 hertz ( as per what you get from the supply authority)
Like all this stuff, there is more to consider before you race out and get one, and wire it up.......however, for  say,  a 1.1kw 3 phase motor, you no longer actually need  a 3 phase supply at all.
Think of all those big heavy sliding steel gates in industrial areas...most are supplied from no more than a power point, but have a 3 phase motor attached to their gearbox. The VVVF drive converts the supply to 3 phase.
The speed is just tweaked by a keypad / or a  PC until you are happy.
#463 SSAid
SSAid
  • 8 posts
  • Name:Adrian
  • Car:78LXSS
Posted 16 January 2014 - 12:27 PM
J...
Have a Look at Shedsafe.com.au this site will explain the Region, Terrain Cat among a lot of other stuff.
There are 4 Regions A B C D. They depend on where you live in Aus. Most in Land Aus can be Region A. Cat 3 is a lighter building Cat 2.5 medium Cat 2 is Stronger.
#464 MODNIZD
MODNIZD
  • 460 posts
  • Name:Phil
  • Car:4 Door LC RB25DET
Posted 28 January 2014 - 01:34 PM
So I'm almost done.
From shed up here is what has happened after that.
Removed the rear wall from the garage to give drive through access to the shed, I will probably put another rollerdoor on this when I get time.
11 full 6x4 trailers of brickies sand, compact and level to get ready for a 100mm slab. Then cut out sections for the hoists of 200mm.
Then plastic and rio.
8 cubic meters of concrete, laid and finished.
Then the doors went on.
#465 MODNIZD
MODNIZD
  • 460 posts
  • Name:Phil
Posted 28 January 2014 - 01:38 PM
I laid some slabs at the back of the shed, still need to cut some to finish.
Got ready for power. 500mm trentch between shed and patio, not a fun job!
Sparkie mate got into it. :)
#466 MODNIZD
MODNIZD
  • 460 posts
  • Name:Phil
Posted 28 January 2014 - 01:43 PM
Power wise, I did the following:
  • 8x Double GPOs on 2 circuits.
  • 2x 15 Amp GPOs on separate circuits (Welder and Compressor) with the compressor GPO in the back corner but a switch on the door frame too.
  • 2x Hoist separate circuits
  • 10x Double Fluros (4 in each bay and 2 above the Workshop area) Will add another 2 once mezzanine is in.
  • 3x exterior LED down lights out front
  • 1x 150W Halogen on the side of shed lighting up grass area
Now I need to seal and paint the floor, then put up the hoist and I can move in! Plan to build some shelving out of steel and also a mezzanine above the workshop area.
Slab - DONE
Power and lighting - DONE
Network Cable - Sleeve run between house and shed, wire to come.
CCTV - Needs the Network cables
Alarm - Will be ordering in the next day or so.
Aircon (Planned on Evap but told it might not be a good idea.) - Not sure what to do yet
Car 2 post Hoist - About to order
Possibly insulate walls and plasterboard - Later
Storage
Large TV
#467 RallyRed
  • 8,115 posts
Posted 28 January 2014 - 04:43 PM
nice job mate.
#468 _diggaman_
_diggaman_
Posted 28 January 2014 - 04:54 PM
Always slab first!!!
Wet concrete touching colourbond or gal will rust it in no time.
20mm*20mm rebate round the sides without roller doors will allow for the sheets to sit down on and allow nothing in, creatures or dust if done properly.
Plus the sub base touching the out side of the colourbond on my shed has done the same.
#469 Ice
  • 15,193 posts
Posted 28 January 2014 - 05:32 PM
Phil i got two mates with big sheds one is 200 sqm and he has evap works a treat has the doors open all day on a hot day and its cool inside
reverse cycle would mean doors have to be closed
by the way cool shed bud but i think you need more lights lol
#470 kiwi-lilj
kiwi-lilj
  • 1,426 posts
  • Name:Blair
  • Car:LIL J
Posted 28 January 2014 - 05:57 PM
I just bought a new house and it came with this shed.
Attached File  image.jpg   185.02K   12 downloads
#471 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 29 January 2014 - 09:16 PM
I've got my shed mostly up now... 9x7, 2 roller doors and a closed bay along the long side. Just need to get the doors up, the gutters etc on and the slab down and I can finally bring the LJ home!
#472 MODNIZD
MODNIZD
  • 460 posts
  • Name:Phil
Posted 30 January 2014 - 01:13 AM
Can never have enough lights ;)
#473 _wombathq_
_wombathq_
Posted 11 February 2014 - 10:08 PM
Base Price
Delivery To home
PA Door Extra
Plans
Total Cost
  Roof TCT
Roof Profile
Walls TCT
Wall Profile
Gutter Type
Rafters
Mullions
Purlins
Wall Gurts
Residential Reg
Terraine catergory
Wind Catergory
I think Residential Regs  would be refering to what the council will allow, depending if you are in a country or residential area, some require colorbond instead of zinc  also height may be an issue if your in town, locally I cant go any higher than 4.5m at the ridge line.  Terrane Category refers to how flat the block is and how much filling may be required, Wind Category this depends on your location, locations out of town will be a higher wind category than somewhere on the edge of suburbia and then a location in middle of suburbia would be less again, the higher the wind category the more bracing and tie downs required
#474 Statler
  • 6,309 posts
Posted 05 April 2014 - 10:13 AM
Yah! I can almost comment in this thread now.
#475 N/A-PWR
  • 9,636 posts
Posted 05 April 2014 - 10:14 AM
You just did Col,
Must be Proud
