hi guys,
just wondering what the smallest width tyre allowed on an 8 inch wide rim is?
I was hoping to put a 215/60/14 on, temporarily for 2 months or so,
I know it is rather small, just curios both on the law, and whether it would be alright for a couple of months
Timbo
smallest tyre for 8 inch wide rim?
_timbo_hatch_
, Jun 02 2007 01:22 PM
7 replies to this topic
_timbo_hatch_
Posted 02 June 2007 - 01:22 PM
Posted 02 June 2007 - 02:51 PM
According to the rim calculator I have the smallest tyre is a 235/60/14 which requires a 6.5-8.0 rim. However Toyo specify a 6.0-8.0 rim for the 225/60/14.
http://www.toyo.com....RPDFs/600F5.pdf
The law is that the rim must meet the tyre manufacturer's specifications.
Posted 02 June 2007 - 03:03 PM
Ive got 215/60 14 on the back of my hatch with 8inch dragways. I couldnt get anything wider.
_big chris_
Posted 02 June 2007 - 08:38 PM
Hi Timbo,
I had a tyre rim calculator bookmarked,
Car Bible
Have to scroll to the section
"An ideal rim-width calculator"
it seems to suggest that 235 is the minimum width tyre for an 8 inch rim,
But,
from working for a mechanic and tyre fitter mate,
he said that the best way to work it out,
match the tyre width to the rim width,
In this case,
the rim is 8 inches wide,
8 x 25.4 = 203.2mm
therefore the minimum tyre width would be 205mm wide (next available size up)
I think if you don't go below the rim width with the tyre size,
you should be safe.
therefore a 215 should be safe, AFIK.
The ideal ratio of rim to tyre,
Rim width plus 1 inch = tyre width.
Chris.
Car Bible
But,
In this case,
8 x 25.4 = 203.2mm
you should be safe.
Chris.
_Squarepants_
Posted 03 June 2007 - 09:11 PM
Qld law says tyre width can not be greater than 30% larger than original and tyre rolling diameter can not be greater than 15mm larger than original.
However, if you've got club/special interest rego, you can do what ever you want.
_JBM_
Posted 04 June 2007 - 04:33 PM
I have front tyre 225/60 on a 14x8 rim. On the back is a 245/60, same rim.
James
EDIT: Im in NSW.
James
EDIT: Im in NSW.
Edited by JBM, 04 June 2007 - 04:33 PM.
_LH 333_
Posted 05 June 2007 - 02:17 PM
I have 215/45/17 on an 8 inch rim and theres no problems.
legally there may be
Posted 05 June 2007 - 02:28 PM
A 45 profile tyre requires a wider rim than 50 or 60 profile tyre.
The correct rim for a 215/45/17 is 7.0 - 8.0" so you have no problems.
http://www.toyo.com..../Proxes T1R.pdf
People who do fit the wrong size tyre to their rims should keep in mind that insurance companies would be within their rights to refuse an accident claim.
Edited by ls2lxhatch, 05 June 2007 - 02:32 PM.
