HQ Brake conversion Tutorial
278 replies to this topic
#226 _ausdev_
_ausdev_
Posted 16 February 2019 - 02:58 PM
Hi TB ..... this is a good question ...... there is conflicting information on this thread which gets confusing to those who have not done the mods before..... it would be great if we could remove unclear information and make the different options correct and obvious... such as ....
Using Torana stub, steering arm, HQ PBR caliper, HQ disc rotor.
1.Remove torana calipers and solid disc rotors and throw away. Purchase HQ disc rotors and HQ PBR cast iron calipers.(calipers will probably need a rebuild.)
2. Have engineer shop remove 6 mm from  "RADIUS" of new HQ disc rotor(this will make the disc radius the same as original solid disc).(If using 2nd hand rotors, brake face will need machining all way to inside edge.)
3 Fit machined HQ disc rotor to torana stub with new japanese bearings, tension bearing, replace split pin and cover.
4. Fit HQ PBR callipers, tension up and check for  any clearance issues. A small amount of metal may need to be removed from the bottom of the calipers for steering arm clearance.
5. Drop car on the ground to load up suspension and test lock to lock clearance..make necessary adjustments.
If you KNOW (not think) any of this information is incorrect or could be changed for clarity please let me know.
Al
#227 SLR576
SLR576
  • 34 posts
  • Name:Steve Ogilvie
  • Car:LX SLR5000
Posted 04 March 2019 - 05:40 PM
Thanks Ausdev,
I just followed these instructions and all fitted spot on!!
#228 _Troopa77_
_Troopa77_
Posted 09 November 2019 - 03:37 PM
Regarding strugglers method of converting (machining down HQ rotors), can anyone tell me if there is a certain model caliper I need? And PBR or Girlock? Cheers Leigh
#229 dron
dron
  • 129 posts
  • Name:Darren
  • Car:UC
Posted 09 November 2019 - 05:30 PM
The uc caliper (alloy) with the steel part that holds the pads from the same age H series car will work. I have both here somewhere.
I was going to go that way but ended up with the UPC compleat big brake kit, Worked and fitted well.
If any one wants the calipers, New HQ disks, Drumb stubs with the hq caliper mount from CRS let me know thay are just colecting dust now.
#230 _Troopa77_
_Troopa77_
Posted 09 November 2019 - 06:32 PM
Thanks Dron but I have new rotors here, just need to know what calipers will bolt up to my factory LX Torana caliper mounts..
#231 dron
dron
  • 129 posts
  • Name:Darren
  • Car:UC
Posted 09 November 2019 - 10:06 PM
The uc caliper with the hz support to allow for the thicker vented disk.
If you use the hz caliper the bleader will be in the wrong place. The alloy section of both is the same except for the bleade screw location.
#232 yel327
  • 13,633 posts
Posted 10 November 2019 - 05:40 AM
Not quite right. The Holden caliper has the brake hose underneath, the Torana one has it on the top. Bleeder should be the same.
#233 UCSLE
UCSLE
  • 710 posts
  • Name:troy
  • Car:Goggomobil
Posted 10 November 2019 - 03:10 PM
Hq discs on torana stubs is a crap conversion and depending on the caliper it can dangerous
the disc wont line up correctly , using a UC caliper with  HZ support will probably drag the outside pad
there is two types seals for UC caliper that go on the slides , one has boots the other has o-rings
the boot style caliper will drag the pad more
using something like a HQ caliper can have the inside pad fall off the cradle as the pads / discs wear down
#234 Toran the Carbarian
Toran the Carbarian
  • 45 posts
  • Car:LH SL/R
Posted 11 November 2019 - 12:36 PM
I'm not having a go but am genuinely interested as to what you think is a less crap and safer upgrade to front brakes if I want to keep 13" rims. Cheers
#235 RallyRed
  • 8,147 posts
Posted 11 November 2019 - 01:38 PM
A liitle off topic maybe...The go to conversion for the LJ Group N track cars is vented BMW rotors and Volvo twin spot calipers.
Established, effective, bolt on, fits 13 " wheels and can be purchased as a package for around ?? $1500.
Edited by RallyRed, 11 November 2019 - 01:39 PM.
#236 UCSLE
UCSLE
  • 710 posts
  • Name:troy
  • Car:Goggomobil
Posted 11 November 2019 - 05:20 PM
stay standard
#237 VinnieSLR
VinnieSLR
  • 60 posts
  • Name:Vinnie
  • Car:LX SLR5000
Posted 15 December 2020 - 08:17 PM
I want to upgrade my 77 LX Brakes and go the full HQ option. Previous owner did the version of grinding down HQ Discs but used LX front calipers...so other than having ventilated discs and HQ stud pattern for wheels there isn't much benefit it seems. The way previous owner did it also caused an issue with the brake pad being to big and slightly grinding into the hub, but have fixed that now.
So if I want to do the full conversion, like an A9X would have had, are these the following items I'll need:
- HQ-HZ Disc/Hub
- HQ-HZ Stub Axels (does it matter if disc or drum Axel's?)
- HQ-HZ Calipers
- Harrop Steering Arms (already got these stored away)
- Custom/Lengthened brake lines
- Modification to the Master & Slave Cylinders??
I think I might be missing a few things but not sure?
When doing this I understand it can drop the cars height by 20mm, but is this at the front only? I would assume so.
Also, what would be required for the rears? I currently have a 9" with HQ Drums but want to be sure it has been done correctly.
#238 yel327
  • 13,633 posts
Posted 15 December 2020 - 08:33 PM
- HQ-HZ Disc/Hub
- HQ-HZ Calipers
You pretty much have it covered. You need:
HQ-WB rotors
HK-WB disc brake stub axles. L34 and A9X used the heat treated cab-chassis ones but not needed for a street car.
A9X steering arms
What hoses you need depends on the caliper.
If you have a 9” with HQ-WB drums all good, will just need the right wheel cylinders. Datto will be able to tell you which. Pretty sure your current master will do the job, but again check with Datto.
Caliper choice, there is probably only three original Holden ones:
HQ (all fast PBR). This is what L34 used but they were machined for a top entry hose.
HX PBR. Not a popular caliper but the only straight bolt in if you make a hybrid out of HX and UC (HX pad carrier and UC alloy caliper). I used to run these and they work OK but some people don’t like them.
HZ Girlock. As used on A9X but modified to clear the tie rod ends.
There may be a donor caliper that works too. Hoppers might have a suggestion.
HK-WB stubs do drop the front about 1” from memory. Might be a fraction less.
Edited by yel327, 15 December 2020 - 08:40 PM.
#239 VinnieSLR
VinnieSLR
  • 60 posts
  • Name:Vinnie
  • Car:LX SLR5000
Posted 15 December 2020 - 09:07 PM
HQ-WB rotors
A9X steering arms
Champion, thank you 👍
Might check out hopper stoppers for better calipers.
#240 VinnieSLR
VinnieSLR
  • 60 posts
  • Name:Vinnie
  • Car:LX SLR5000
Posted 15 December 2020 - 09:29 PM
Would I be ok with keeping the stock control arms and tie rod ends etc? Or do they also need to be changed?
#241 rexy
rexy
  • 3,739 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 15 December 2020 - 10:31 PM
I recommend staying with what you have and instead explore pad options.
it will handle much better keeping the Torana stubs in it.
#242 VinnieSLR
VinnieSLR
  • 60 posts
  • Name:Vinnie
  • Car:LX SLR5000
Posted 16 December 2020 - 10:13 PM
I would have thought going the HQ option, to make it like an A9X, would have been the best for handling?
#243 rexy
rexy
  • 3,739 posts
  • Name:Rexy
Posted 16 December 2020 - 10:25 PM
It certainly wasn’t my experience in my hatch. Drives a lot nicer now that I have put the Torana stub axles back in it.
#244 waynec
waynec
  • 23 posts
  • Name:wayne cameron
  • Car:LX Hatchback
Posted 23 February 2021 - 06:17 PM
need some help on this one guys ,
HQ Disk machined down HQ pbr caliper ,  standard LX stubs , caliper bracket hitting on tie rod end is this a common problem or am i doing something wrong here , ?
ground a fair bit of the bracket still touching any help please ..
Wayne.
maybe caliper  better of at rear of disk ?  or dose that create more problems
#245 purrlx
purrlx
  • 1,332 posts
  • Name:Danny
  • Car:LX hatch
Posted 24 February 2021 - 06:37 AM
What steering arm do you have, UC drop down lower and the A9X drop even further. There is a pics of the 3 somewhere on here.
#246 waynec
waynec
  • 23 posts
  • Car:LX Hatchback
Posted 24 February 2021 - 07:50 AM
Lx as suggested in this topic
#247 Bigfella237
Posted 24 February 2021 - 10:48 AM
Yeah but you have to use the correct steering arm for the suspension setup otherwise you'll induce bump steer.
The UC steering arm socket is lower because of the UC upper control arms, and the A9X is lower still because it has the UC-style UCAs plus the HQ-style stub axles with the 'drop-spindle'.
You can't just mix 'n match to suit the caliper clearance.
#248 waynec
waynec
  • 23 posts
  • Car:LX Hatchback
Posted 24 February 2021 - 12:29 PM
might try swapping stubs  left to right right to left ,
put the caliper at back of disk
Edited by waynec, 24 February 2021 - 12:30 PM.
#249 yel327
  • 13,633 posts
Posted 24 February 2021 - 01:16 PM
It will hit the crossmember. I had the same problem originally back in the 80’s.
#250 waynec
waynec
  • 23 posts
  • Car:LX Hatchback
Posted 24 February 2021 - 08:22 PM
so if i get uc steering arms it should fix the problem ?
