HQ Brake conversion Tutorial
#251
Posted 24 February 2021 - 09:01 PM
Run UC torana front end alignment specs with UC steering arms and the geometry will be ok.
Would be good to borrow a set rather than buy incase they don't fit either.
People want good money for UC steering arms these days. If you were in Bris I could bring some over for you to try.
#252
Posted 25 February 2021 - 11:34 AM
Depends how much more clearance you need.
i am only in vic mate not that far .
#254
Posted 25 February 2021 - 06:55 PM
so pays to check things out ..
Edited by waynec, 25 February 2021 - 06:58 PM.
#255
Posted 25 February 2021 - 07:04 PM
#256
Posted 25 February 2021 - 07:09 PM
thats how i worked out the issue they where fitting not to bad with bleeder at the bottom
#257
Posted 30 July 2023 - 10:45 AM
Question. If it all fits up good (with a little grinding on the caliper mounts) will it pass for a roadworthy/rego as the car is now not registered in Vic?
Any advice much appreciated.
Sent from my Pixel 7 using Tapatalk
#258
Posted 30 July 2023 - 11:37 AM
Should be fine.
Don't mention it to them and if they are relatively young they probably wouldn’t know it’s not factory. Or tell them its an A9X!
#259
Posted 30 July 2023 - 12:04 PM
#260
Posted 31 July 2023 - 01:21 PM
Hi mate, when you say "a little grinding on the caliper mounts" its actually around 5mm you would need to grind off in order to get the rotor running centrally in the caliper. I would suggest getting the caliper mounting faces properly machined so the pads will sit up all nice and square to the rotor faces.
John
#261
Posted 31 July 2023 - 01:30 PM
#262
Posted 31 July 2023 - 01:59 PM
Ok. I thought it was only the caliper mount. I ground a few ml off the mount to clear the steering arm so the mounting bolts would fit. I wasn't aware I needed some off the face as well.
It is all due to the differences in the 'step' at the base of the spindles of the 2 types of stub axles, which is approximately 5mm.
Basically, when you fit a H rotor to a Torana stub it offsets the rotor 5mm outwards comparative to where it would normally sit within the H caliper. So to overcome this, the 5mm has to be machined from the caliper mounting faces which effectively offsets the caliper outward and sitting back centrally over the rotor.
You will probably still have to grind a little 'relief' for the steering arm too.
Posted 31 July 2023 - 02:07 PM
#264
Posted 31 July 2023 - 03:02 PM
Is that photo above for HK to mid HX or the later HX through to WB stubs? There is a difference, can't remember exactly what it was. The parts books say the change occurred when the calipers changed during HX.
#265
Posted 31 July 2023 - 07:09 PM
Hi Yel,
they are 43695 (1 Tonner or A9X stubs).
I have several sets of HQ-WB stub axles here, they all appear to have the same basic geometry, however, there are differences in the machined caliper mounting areas of each.
On the later ones they have machined off a slightly larger flat surface. Not 100% sure why this was done, as later calipers fit on earlier stubs (and vice versa) without issue.
Pictured are the earlier and latter versions of the 1 tonner stubs, measuring the same arbitrary reference point. Hard to measure precisely as it's curved, but shows the depth of cut 27-25mm (either side of the ruler) on one and 24-22mm on the other. Can also see it goes further into the 'meat' of the stub axle itself on the latter.
Posted 31 July 2023 - 07:26 PM
It’s to do with those alloy body HX PBR calipers, must have been to get a few more mm tolerance in clearance.
Edited by yel327, 31 July 2023 - 07:32 PM.
#267
Posted 31 July 2023 - 08:26 PM
There's another version where the caliper mounting area doesn't go all the way between the two bolts, and not all calipers will bolt onto those without clearance mods.
#268
Posted 01 August 2023 - 10:07 AM
Is the extra machining apart from disc diameter reduction only required if you use the HQ steel calipers?
When I did this in the early 90s with HX slides on torana stubs with LX alloy PBR calipers there wasn’t any extra machining required to fit it together.
#269
Posted 01 August 2023 - 01:08 PM
Out of the 6 different HQ-WB calipers, the PBR alloy calipers are the only ones that don't need the actual caliper mounting points machined. They overcome the problem by using the HX slides (which as you would know are longer than the LX versions) which effectively span the rotor enough to overcome the introduced offset.
#270
Posted 01 August 2023 - 01:56 PM
6 different HQ-WB calipers? Old memory but when I played with these in the 80's and 90's I can only remember:
HQ PBR (and some HJ).
HJ Girlock (and some HX).
HX PBR alloy body.
HZ-WB Girlock alloy body.
Some overlaps of course but I can only remember the four distinct types. Admittedly this is on a sample of maybe 500 cars all up I ever took the time to look closely at, so I didn't see all of them!
#271
Posted 01 August 2023 - 02:32 PM
HX PBR alloy body.
You are correct in the above list but I would note there are 2 types of cast HQ.
There are the earlier which are often referred to as small pin, and also the latter, which have the big slide pin (and have a scalloped out area in the top of main body).
I would also split the late HX/HZ and WB calipers into 2. The WB is obviously very similar but does have the inlet hose at the back of the piston via a banjo fitting, rather than fitting up underneath the main body.
#272
Posted 01 August 2023 - 02:38 PM
WB has metric fittings too, doesn't it?
#273
Posted 01 August 2023 - 02:44 PM
Yes I believe so.
#274
Posted 01 August 2023 - 03:03 PM
Ah, that makes more sense, I remember those HQ variations now - I think the castings changed in common with Ford and Chrysler too, but it's been 30+ years since I fiddled with them. WB were always a pain the in butt, where you'd buy two cars and parts were not interchangeable. Even some of the threads on bolts and screws changed. All the hex heads remained AF from memory but some threads went metric. Like the screws around the perimeter of the front guard into the metal splash guard. They were imperial on early WB but went metric later.
#275
Posted 01 August 2023 - 03:59 PM
