HQ Brake conversion Tutorial
#51
_joe moellers_
Posted 19 February 2009 - 07:48 PM
Joe
#52
_Drue_
Posted 21 February 2009 - 11:13 AM
Edited by Drue, 21 February 2009 - 11:14 AM.
#53
Posted 21 February 2009 - 01:28 PM
Just tried the cut down method for the HQ disk. Not happy with it as disk runs approx 7mm further away from caliper. Looks like mounting on caliper needs to be machined. What am I missing?
Joe
Are you using the HQ stubs or Torana?Torana stubs should be used.
#54
Posted 22 February 2009 - 09:30 AM
So using machined LH Drum Stubs with the castlemaine Adaptor plates will allow me to mount my wb girlock calipers ontop of my hq-j-x-z rotors?
_joe moellers_
Posted 29 March 2009 - 06:59 PM
I am using Torana stubs. Torana stub axles have bearings mounted 4 to 5 mm further out than HQ. That's how Holden made the HQ axles stronger. Same on the back. Torrie stub is also machined differently. 2 to 3 mm step instead of flat. I have machined my brackets and ground them to fit around the tie rod end. Will post some pictures when finished. Not a weekend job as I hoped. Thank God I have a spare front end.
Joe
#56
_waz355_
Posted 02 April 2009 - 11:53 AM
Joe
Did you have to machine down the thickness of the caliper brackets as well as clearance for tie rod?
#57
_joe moellers_
Posted 16 April 2009 - 09:25 PM
Yes. Had to remove approximately 4mm from the bracket mounting face. Also have to remove 2.5 to 3 mm from between mounting holes OR the step on the stub axle itself. Bracket will be approx 2mm thicker than old torrie one. Also need to remove about 2 to 3 mm from area near steering arm (so both fit on the stub) and then grind for the tie rod end. If you want further info pm me at [email protected]
Joe
Edited by joe moellers, 16 April 2009 - 09:38 PM.
#58
Posted 20 October 2009 - 10:21 PM
$100 per set.
I'm going to try this conversion for myself and experience the much talked about 'bumpsteer issue' and will then probably buy the Harrop steering arms to finish it off.
#59
Posted 20 October 2009 - 10:40 PM
What happenned to that car after PB finished with it ?
Mick that car is still racing here in WA.
#60
Posted 21 October 2009 - 02:17 PM
I have a couple of sets of WB Rotors/Stubs/Calipers if anyone needs them.
$100 per set.
Can you take lots of pics so we can finally have a decent how to?
Cheers,
Grant..
#61
Posted 21 October 2009 - 02:43 PM
Does anyone know if you can run still run 13"s over the HQ (etc) series calipers on stub axles, or are the calipers that much bigger that it no longer clears? Cheers
#62
Posted 21 October 2009 - 04:04 PM
#63
Posted 21 October 2009 - 05:06 PM
#64
_JS192_
Posted 25 November 2009 - 12:49 PM
i just finished doing a hq conversion on my mates lx hatch here is what i did!! hq stubs and discs put left stub on right and right stub on left used hz calipers had the rubber hose brake lines made longer,used uc steering arms got wheel alighnment and all works fine!! took it in the hills at 80kmh and 100kmh had no steering issues at all!!
will the hq discs and hz alloy calipers fit straight under 14inch wheels? or will the discs need to be machined?
this is the exact setup i'm putting together at the moment. thanks for your help!
jack
#65
Posted 25 November 2009 - 01:09 PM
So all fits
#66
Posted 05 January 2010 - 05:50 PM
Struggler,I'm sure I will upset a few people but after doing a heap of HQ/LH/X brake conversions this is how I now do it.
Remove the Torana caliper and disc. Take your HQ discs to the brake shop and get them to remove about 6mm or a quarter inch from the external diameter of the disc and get the disc face machined down all the way to the bolt up face (most HQ discs dont have this face fully machined as the pad normally doesn't run in this area). Fit these discs to the stub axles on your car and repack the bearings (HQ and LH/X/UC bearings are the same). Trial fit the HQ caliper and check for interference (yes the HQ caliper will bolt to the torana stub) and grind away as required to clear the tie rod end. Check the clearance between the outer pad and the bolt up face of the disc (you have moved the caliper closer to the bearing than it would be in an HQ). Refit, bleed brakes and drive off !!!
Yes the caliper does not sit as far away from the spindle as it does in an HQ but you do have ventilated discs, a real caliper, HQ pattern and no wheel alignment or bumpsteer issues. Try it , you'll like it.
Flame on non believers !!!!!!!!
Would this conversion be possible if I wanted to retain Torana stud pattern, 4.25" PCD. Could i fit a drilled HQ disc over a torana disc hub etc?
Max
#67
Posted 24 January 2010 - 09:02 PM
DBA will do an HQ-Z rotor in Torana pattern.
Grant..
#68
Posted 24 January 2010 - 09:19 PM
But won't drill the Torana pattern for you
Unless you buy 100
Its not worth reprogramming the CNC for less
#69
Posted 28 January 2010 - 11:45 AM
Thanks Max
Yes Max
Grant..
#70
Posted 28 January 2010 - 09:48 PM
Nor do LX for that matter
So not sure where your going with this theory
#71
Posted 29 January 2010 - 06:30 AM
Looking at the bits and pieces in my shed it looks like it could be a few mm out which is just enough to be a pain.
#72
Posted 29 January 2010 - 09:41 AM
Brock raced a car just like it
#73
Posted 29 January 2010 - 10:23 AM
Thanks for that
Max
HQ's don't have hubs... its all cast into the disc
#74
_vintageholden_
Posted 24 February 2010 - 08:08 PM
hq ventlated disks
i have wb alloy callipers.
what steering arms please, uc??
#75
_shannonstorana_
Posted 18 March 2010 - 08:06 PM
sorry about the questions when you swap the stubs left to right, does this position the caliper on the front of the disc
jack
and when you say uc steering arms are you talking about the little arms that attach to the rear of the stub
shannon
