HQ Brake conversion Tutorial
278 replies to this topic
#176 _LS1 Taxi_
_LS1 Taxi_
Posted 27 November 2013 - 11:12 AM
I think people tend to get a bit carried away at times.
Personally as my time is my own to work on the cars I am happy to do things in a stepwise fashion and see how they turn out. Never been a fan of spending money for things I may not need.
On the hatch I went from the standard set up to one tonner stubs and discs, kept the alloy LX calipers bodies and added the HX pad carriers. Total cost zero as parts already stockpiled in shed. I already ran commodore rear discs.
Drives just fine for my needs and I won't be changing to the Harrop steering arms.
Completely agree.
My car has
King lowered springs, monroe gas shocks, LX control arms, HQ stubs, HQ discs, HQ girlock calipers and LX steering arms.
Car drives, steers, stops well.  No sign of bump steer for me and I did drive it fairly hard through some sweeping country roads for the 120km I've driven so far.  Same deal as Rexy, nothing spent on the conversion as all parts I had laying about.  It did cost money as I bought new pads, discs, bearings, springs and shocks though....but that was as I was renewing everything as part of the build, not because it needed it.
Edited by LS1rana, 27 November 2013 - 11:14 AM.
#177 TerrA LX
Posted 27 November 2013 - 12:19 PM
IMO bump steer will vary with spring height, in relation to the horizontal alignment of the inner and outer tie rods.
#178 _LS1 Taxi_
_LS1 Taxi_
Posted 27 November 2013 - 12:22 PM
Yep, I agree...which is why I mentioned I have lowered king springs.
#179 royalplumss
royalplumss
  • 246 posts
  • Car:had L31 SS Hatch
Posted 29 November 2013 - 12:26 PM
After hours and hours of reading and asking questions from some of the more notably experienced members on here, I decided to install a simple Torana/HQ combination that was easily sourced without any expensive mods (except for the Harrop arms).
HQ stubs
HQ calipers (PBR Steel - smaller ones)
HQ discs
UC upper control arms - fitted to redrilled lower point on UC Kframe
LX lower control arms (didnt have thicker LH on hand)
All in all - I am pretty happy with how it all went together, but am yet to test it on the road - and wont be able to for some time (it has been 16 years so far)
Have to revise this!
After getting back to the car and having a closer look (as per Reds query) - the caliper is touching the lower control arm - seemingly way too early for normal steering requirements.
It will take some time before I can have a proper look and see if I put something together wrong though.
I am thinking the UC top arm has brought it closer quicker in the turn.......
At least I am getting used to pulling these things apart - and attempting to put them together correctly
#180 v6 torana
v6 torana
  • 497 posts
  • Name:Peter
Posted 30 November 2013 - 01:17 PM
Thanks for the info guys, dont worry about the measurement Toranamat69 (huntsman spiders are creepy). I have found a set of UC steering arms from old mate in QLD for $25 each + postage to NSW.
Once i fit the UC steering arms I will add another post and let you know how it finished up.
I have fitted UC steering arms to the LC with HZ stubs (I wanted to drop the angle of the tie rod arms). It has dropped the steering arm by 4 cm comapred to the hz steering arms. The steering rack tie rod arms are now parallel with the rack, however because the tie rod ends mount at the top on UC arms (not the bottom) I am back to square one.
Has anyone done a reverse taper on steering arms ??
HZ
Attached File  P1060375_3.jpg   71.38K   13 downloads
UC
Attached File  P1060378_1.jpg   71.85K   13 downloads
Attached File  P1060376_2.jpg   152K   13 downloads
#181 TerrA LX
Posted 01 December 2013 - 12:25 PM
^ you might want to start a new topic for yourself asking specifically about the taper, this is a sticky thread for HQ brake conversion.
#182 _BOURKEY400_
_BOURKEY400_
Posted 20 February 2014 - 07:39 AM
Well I guess that depends on how you go about it.
True m8  B)
#183 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 24 October 2014 - 09:18 PM
I fitted hq cast iron caliper to Torana stub axle, the caliper sits sort of in side of tie rod. Should swap over the steering arms to UC??
#184 dattoman
  • 16,487 posts
Posted 24 October 2014 - 09:29 PM
When the cars sitting on the ground at normal ride height what sort of angle are the rack ends on ?
#185 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 24 October 2014 - 10:54 PM
I'm still using lx torana stubs and arms so it should sit fine but the tie rod needs to be tilt back so I can get the caliper on.
Just one last thing how bad is the bump steer with hq stubs with uc arms??
Edited by snickersbar, 24 October 2014 - 10:56 PM.
#186 76lxhatch
  • 7,205 posts
Posted 25 October 2014 - 08:58 AM
The UC steering arms are lower to counter the effect of greater positive caster as tilting the stub axle raises the outer tie rod end; the A9X ones are lower again and allow even more caster. If you can get at least 2-3 degrees of caster then the UC arms will be good, and the bonus side effect is a little more clearance to the caliper.
Bump steer is greater when the outer tie rod end sits too high or too low for the arc of the tie rod to follow the arc of the stub axle closely.
#187 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 29 October 2014 - 07:27 PM
Hey Im trying to fit my pbr cast iron caliper to my torana stub axle it wont fit.
the rotor has been turn down the size is 270,
back of the stub has been grand flat,
if I remove the out side pad I can bolt it on
can anyone help me
#188 SS hatch
SS hatch
  • 104 posts
Posted 30 October 2014 - 08:56 AM
DBA 014       276mm new od   270mm would indicate 3mm off radius most state 6mm of radius. Although I have only just finished this conversion machining on the weekend. Disk is 270mm. Hq pbr cast calipers 2mm removed from inboard of caliper to where outside radius of disk runs. Caliper to disk clearance 2mm. All fitted prior to machining of caliper problem disk touched inside of caliper slightly, disk still was able to be rotated. Torana stub uc steering arms.The simplest thermal expansion gap remove more off disk.I was trying to keep as close as possible to standard Od. Is the pad touching hub of disk I had to remove some material from pad backing to allow pad to have clearance to hub
Edited by SS hatch, 30 October 2014 - 09:01 AM.
#189 _napes_au_
_napes_au_
Posted 07 November 2014 - 09:47 PM
I'm going the easy route guys, turning down HQ rotors and fitting HQ cast callipers... Just one question, some people say 6 mm off the radius, while others say 6 mm off the diameter (That's only 3 mm off), which is it please? I just don't want to make a mistake sorry...
#190 _mervx_
_mervx_
Posted 08 November 2014 - 11:06 AM
napes,have a read of page 1 and all will be revealed. lokk at the posts by struggler.
mervex
#191 ribz0
ribz0
  • 512 posts
  • Name:Eric
  • Car:LC Torana & 1975 South African Mini
Posted 05 February 2015 - 11:11 PM
Luv this mod... well worth doing!!! Have had it on my LC for a while now and its the best thing I have done to it!!! had to have another read of the thread myself....
Edited by ribz0, 05 February 2015 - 11:20 PM.
#192 gtrboyy
gtrboyy
  • 3,209 posts
Posted 06 February 2015 - 02:15 PM
You reckon on lc-j it be better to fit A9X arms?
Is it worth doing for square torries? curious
#193 TOERUNNER
TOERUNNER
  • 630 posts
  • Name:RODNEY
  • Car:73 lj gtr 73 lj 2 dr S
Posted 09 February 2015 - 05:25 PM
when you put the hq rotor onto the torana stub does it change the mounting point for the wheel, as in changing the track.
cheers Rodney
#194 _mervx_
_mervx_
Posted 10 February 2015 - 10:40 AM
mate, read page one,post 6 by struggler. it does not mention making the track wider,so I presume it does not.
maybe someone who has done this mod can verify for sure.
mervx
#195 _LHSL308_
_LHSL308_
Posted 10 February 2015 - 11:46 AM
cheers Rodney
I done this mod with the HQ disk onto the Torana stub and I didnt notice any change in track of the wheel, I didn't measure it though.
Edited by LHSL308, 10 February 2015 - 11:47 AM.
#196 _Lazarus_
_Lazarus_
Posted 10 February 2015 - 01:08 PM
Running HQ offset wheels is what will change the track. Difference is approx. 35 - 40 mm overall. The actual hubs themselves are very similar in width.
#197 Bigfella237
Posted 10 February 2015 - 03:13 PM
I did the math in another thread and the front hub-to-hub width of an L34 (with HQ stubs and rotors) came out 14.6mm wider than the standard SL/R, so obviously the HQ bits added 7.3mm per side.
As Mark pointed out, the biggest difference will be the wheels, standard factory rims can often be set inward around 70:30 (%)
HQ GTS rims are set inward 57:43
L34 (& A9X) rims are set inward 53:47
The reason for these offsets (and the regulatory allowance in track increase) is of course to keep the load in the proper place over the wheel bearings, the wider the offset, the more load is placed on the smaller outer wheel bearing (and on the thin end of the stub axle), where the intent from the factory was to have the larger inner bearing carry more of the load.
#198 _the mrss car_
_the mrss car_
Posted 19 October 2015 - 05:57 PM
Hi all,
The car...
LX Hatch, torana disc stubs, HQ rotors machined to suit, HQ PBR steel calipers, and long hoses....
Ive had a good read here but still somewhat undecided on one thing,  am I better to reverse the stubs and run the calipers on the back or front mount them and machine anything in the way persee??
Awesome post BTW
#199 76lxhatch
  • 7,205 posts
Posted 20 October 2015 - 05:53 AM
Personally I would fit them to the front and check out the clearance - those calipers should fit with little to no work and you will have better clearance to the cross member itself. However if significant grinding/machining is required then move them to the back where you can take the clearance out of the cross member rather than the calipers or steering gear.
#200 _the mrss car_
_the mrss car_
Posted 21 October 2015 - 07:41 PM
That sounds good to me, I do need to machine 3mm from caliper face so I guess knocking a bit off the bottom for the tierod isn't to much drama.
thankyou
4 user(s) are reading this topic
0 members, 4 guests, 0 anonymous users
