how do i check the timing on an EFI 304 motor? is it as simple as a holden 6, probably not.
my engine bogs down and i have a suspision it's the timing
please share your tips here!
john
![](https://secure.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e?s=100&d=https%3A%2F%2Fwww.gmh-torana.com.au%2Fforums%2Fpublic%2Fstyle_images%2Fblackstream%2Fprofile%2Fdefault_large.png)
timing on an EFI v8
_Chamois hatch_
, Jun 16 2007 01:50 PM
8 replies to this topic
_Chamois hatch_
Posted 16 June 2007 - 01:50 PM
Posted 16 June 2007 - 05:24 PM
You are meant to put it into diagnostics mode & set the timing to 10 degrees.
_Chamois hatch_
Posted 17 June 2007 - 01:56 PM
how do i put it in diagnostic mode?
and i look for a notch on the balancer yeah?
Posted 17 June 2007 - 10:15 PM
On a vr/s or a vt there is a black pad with pins on it above the brake pedal,bridge pins 5 & 6 with a wire or split pin then start car & check the timing on the balancer,to adjust timingby turning the distributer.
If you want to check fault codes,you do the same thing,bridge pins 5 & 6 then then turn on the ignition & fault codes will come up.
Vn/p have a plug up under the dash on the passenger side that you bridge the pins on to put it into diagnostics mode.I may have a diagram for that on photobucket.
Edited by gtrboyy, 17 June 2007 - 10:18 PM.
_Chamois hatch_
Posted 17 June 2007 - 10:46 PM
a pic would be great if not too much hassel. it's actually a 304 VP motor in my UC so i need to know what im looking for.
Posted 18 June 2007 - 01:37 AM
![Posted Image](https://cache.gmh-torana.com.au/i44.photobucket.com/albums/f28/gary2_gazzard/af86e015.jpg)
HTH.
_Chamois hatch_
Posted 18 June 2007 - 12:26 PM
thanks mate found it, what book is that out of?
Posted 18 June 2007 - 01:49 PM
Think it's out of the holden manual.On a vl I wired up few months back I used a test light to check for fault codes.
Posted 23 June 2007 - 02:52 PM
How did you go,all sorted?
