Performance Upgrade for V6
#26
Posted 06 July 2007 - 11:35 AM
#27
Posted 06 July 2007 - 11:49 AM
Tim
#28
Posted 06 July 2007 - 12:39 PM
im sure the internals of that concept torana would have been better suited, but as i said, it was never meant to be a massive performance motor like those jap motors you mentioned.
#29
Posted 06 July 2007 - 01:43 PM
#30
_youngy_11_
Posted 06 July 2007 - 05:39 PM
But theres plently of aftermarket stuff to strengthen it up. The thing is I won't be running high boost anyway 5-8p.s.i.
Im not gunna be wacking massive upgrades straight away, I gotta get use to driving her first. Much different compared to a VZ.
Posted 06 July 2007 - 08:24 PM
Elaborate. I don't know of any aftermarket gear to "strengthen it up". Interested in seeing that is availible.But theres plently of aftermarket stuff to strengthen it up.
EDIT: BTW aftermarket valvetrain components do not strengthen a motor up
Edited by Heath, 06 July 2007 - 08:24 PM.
#32
_youngy_11_
Posted 07 July 2007 - 04:46 PM
Posted 07 July 2007 - 06:32 PM
#34
_Keithy's_UC_
Posted 08 July 2007 - 06:07 AM
I'd be a bit more trusting of the ecotec crankshaft - they can handle more than you think!! As with the block!!
I rekon on a budget - tune, cam and headwork, pacemakers and a 2 1/2" exhaust system! That should see you over 200kW easily!
Keith
#35
Posted 08 July 2007 - 10:54 AM
#36
_Brewster_
Posted 08 July 2007 - 03:48 PM
Check them out
http://www.raptorsc.com.au
Edited by Brewster, 08 July 2007 - 03:51 PM.
#37
_brett_32i_
Posted 08 July 2007 - 07:40 PM
for the above mods you metioned keith, that would still end up at a fair whack of money. probably 5K? done probably (think about it if you dont beleive me)
i did my pre eco v6 and ended up with 154rwkw (i think more but cant find that dyno sheet)
best mod was the heads. get some one who knows what he is doing.
(my builder exports them back to the US, so he knows a trick or two.)
i also did that with std chip. c.o.m.e. chip was a piece of s&*t. it did need a tune done on it, but didnt have $800 to throw at it at the time.
oil system mods are very important, and piss the balance shaft off while your in there.
fit an oil cooler!
etc, etc.
#38
Posted 08 July 2007 - 08:21 PM
#39
_JBird_
Posted 08 July 2007 - 08:34 PM
#40
_Keithy's_UC_
Posted 09 July 2007 - 06:08 AM
Heads - $1000 max (port work and shave)
Extractors and exhaust (single 2 1/2") - $1500 max pending where you get it done
Cam and chip package/tune - $1000 to 1500
That there seems reasonable to me, and coming in around $4000 there, allowing another grand for miscellaneous bits and pieces!! Cheaper than what it cost me to build my 190HP 186cu red motor...
Keith
#41
_brett_32i_
Posted 09 July 2007 - 11:51 AM
70mm throttle $100?
oil cooler $300?
radiator upgrade $300? (vs siii ute is/was biggest factory option)
cold air system $?
ceramic coat the headers $?
list goes on....
I'm with jbird on this. buy an import nissan motor and throw it in there.
Edited by brett_32i, 09 July 2007 - 11:52 AM.
#42
_youngy_11_
Posted 09 July 2007 - 08:04 PM
The exhaust im running is custom extractors with a dual 2inch all the way out with an X pipe in the middle, im going to get it ceramic coated or wats the other treatment called??? I can't think of it
What do you guys recon I should do with the radiator setup???
I have spoke to Simon from Sydney Torana Club and he fitted a radiator from a commordore its look a treat??
Also could someone elaborate on whats involved in head work??
Edited by youngy_11, 09 July 2007 - 08:12 PM.
#43
Posted 09 July 2007 - 09:55 PM
#44
_Keithy's_UC_
Posted 10 July 2007 - 06:12 AM
What i was specifying before was a simple budget head job - shave and port is the basic performance upgrade on a standard head!
Keith
#45
_youngy_11_
Posted 10 July 2007 - 05:42 PM
I was going to clean them up.
Any suggestions?
Take it off with sandpaper to a shiny finish?
