Driving Lights/Spotties
knoath
, Jan 25 2006 09:14 AM
7 replies to this topic
Posted 25 January 2006 - 09:14 AM
Thinking about installing some lights behind the grill.
1) What are a good set to go for? Pencil beam and broad beam?
2) Has anyone got any pix of lights installed behind grill to look at different mounting ideas?
3) May go for some thermo fans too while I'm at it... how can I tell if my Alt is up to the job, is there a set of numbers to go by (on the alt)? I'd say it's larger than orig by looking at the size of it.
Cheers and thanks.
Cheers and thanks.
#2 _devilsadvocate_
Posted 25 January 2006 - 10:05 AM
Will post some pics of driving light brackets tonite.
In relation to alt specs, there are two numbers stamped on bosch alternators, ie 55A20. The larger number gives you output at about 3000rpm engine speed and the lower is an idle speed rating.
If you are going to run two au fans mainly at idle, youd wanna be looking at an alternator with at least a 40A lower rating, preferably 60.
Posted 25 January 2006 - 10:28 AM
Thanks devilsadvocate, I'll check that out.
#4 _2doorterror_
Posted 25 January 2006 - 03:09 PM
If you do or plan on doing some travelling I would recommend getting one of each, the pencil for further along the the road, the broad for closer objects. Fitted a lot of spotties and most customers have been more than happy. If you do a few short trips here and there maybe go for a set broad beam spotties. IPF is a good brand, slightly on the expensive side but well worth the money.
#5 _Yella SLuR_
Posted 25 January 2006 - 05:20 PM
I'd prolly make up a 25 SHS steel bracket. This one just used flat plates and a thousand washers on the bolt below the top radiator bolts.
As you can see, rocks are an issue.
Edited by Yella SLuR, 25 January 2006 - 05:21 PM.
#6 _devilsadvocate_
Posted 25 January 2006 - 08:55 PM
I actually sold the lamps(hella pencil beams) and removed the brackets(they are for sale, put in place for sake of the photo), all worked well, just didnt need them.
#7 _Yella SLuR_
Posted 25 January 2006 - 10:47 PM
That looks like a much better set up.
Paint or coat your bonnet catch you lazy bugger.
Edited by Yella SLuR, 25 January 2006 - 10:48 PM.
#8 _devilsadvocate_
Posted 25 January 2006 - 11:38 PM
Yeh, its on my "to do" list, right after "change air in tyres"Paint or coat your bonnet catch you lazy bugger.
