Intake Manifold, thermostat housing
8 replies to this topic
#1 _pallbag_
_pallbag_
Posted 16 July 2007 - 08:27 PM
What does everyone think about a thermostat housing on the inlet manifold that looks like this ... Thermostat still sits in OK with a minimal bit of seeping possible around the outer edges, but should it be a concern?
#2 _Monkey_
_Monkey_
Posted 16 July 2007 - 08:29 PM
You could machine a new lip.
#3 _timbotorrie_
_timbotorrie_
Posted 17 July 2007 - 05:22 PM
silastic is your friend mmk :spoton:
shouldnt be a worry mate, a light smear underneath a new gasket should be right
#4 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 18 July 2007 - 07:46 PM
bit of ultra blue and ull be set
#5 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 19 July 2007 - 08:33 AM
Personally I reckon its stuffed. The only way to fix that is to remachine the 'stat groove and cut down the mounting flange so that the thermostat is held captive. As it is coolant can flow past the thermostat and out the bypass. The thermostat will also not be held captive and coolant will get past it. Anyway it will cause you grief.
JMHO
#6 _pallbag_
_pallbag_
Posted 19 July 2007 - 01:51 PM
What is MMK ?
#7 TerrA LX
Posted 19 July 2007 - 02:52 PM
Get rid of that KC manifold before it desolves before your eyes, fit a late model factory or the preformer you got
#8 _trna76hb_
_trna76hb_
Posted 20 July 2007 - 05:55 PM
Hi
maybe try liquid metal in a tube. Put it on a clean surface & let it dry. it goes hard & then you can drill & fill the stuff.
It might work, you cpold only try
Ian
#9 _pallbag_
_pallbag_
Posted 08 August 2007 - 07:31 AM
Mmmmmmm, couldnt fix the leak so off it comes and on goes the performer. Anyone wanna buy a "good" intake manifold !!!
