LX SLR wiring diagrams
22 replies to this topic
#1 _Cane_It_
_Cane_It_
Posted 18 July 2007 - 05:42 PM
can someone email me a good quality scan, there was a colour diagram posted up on here somewhere ages ago but it didnt print too well...
does someone have a hi-res scan of this wiring diagram, need to do some emergency wire grafting?
email is
djgare AT optusnet DOT com DOT au
AT=@
DOT=.
to avoid spammers
thanks in advance
#2 _Herne_
_Herne_
Posted 18 July 2007 - 05:57 PM
email and attachment sent, hope it's ok.
Herne
#3 _Cane_It_
_Cane_It_
Posted 18 July 2007 - 07:42 PM
Herne
champion!
thats exactly what i was after and the quality is right on the money.
what book did that come from? the quality is a million times better than my manual, it looks like the diagrams in my factory VK workshop manual.
my last question regarding the engine harness; as the wire colours are hard to make out until I print it on the colour printer tomorrow.
is the heavy purple wire the trigger for the starter solenoid?
is the heavy red wire a 12V source into the cabin? from the battery or the heavy wire on the starter post?
I'm grafting a holden electronic dizzy into it and I dont want to molest the factory wiring loom as its virgin, I have another torana engine harness out of a donor car and was going to use the yellow coil wire to trigger a relay to give the coil on the electronic ignition a full 12V? will the voltage coming from the yellow trigger wire (via that pink resistance wire when the car fires) be enough to keep that relay armed once the key returns from cranking to the run position?
#4 _Herne_
_Herne_
Posted 18 July 2007 - 07:48 PM
Glad it was ok, wasnt sure if it was going to completely cover an SLR or not :)
I found that diagram on the net some time back so I cant help with what book it came from. I figured it was worth keeping though :)
No help with wiring colours either sorry. Good luck!
Herne
#5 Obey 1
Obey 1
  • 414 posts
Posted 20 July 2007 - 07:19 AM
Cane-it..
Just had a look at my starter for you (on my 308).
You have your main cable coming from your battery to the large threaded stud on your starter motor.Piggybacked on top of that should be the thick RED wire ,which is the main Supply into your cabin. And then the Thick purple wire is the trigger to the starter as you have suggested.The red wire should have a Lug on it and the purple should have a female spade connection to slide onto the starter motor TAB (I suppose thats what I would call it).Hope this helps
Obey 1
#6 _youngy_11_
_youngy_11_
Posted 20 July 2007 - 04:28 PM
Herne could you be able to send me a copie of the wiring diagram too??
My email is youngy_11(AT)hotmail.com
Thanks alot
Ryan
#7 _Herne_
_Herne_
Posted 20 July 2007 - 05:39 PM
Sure thing Ryan, sending it now.
Herne
Edited by Herne, 20 July 2007 - 05:40 PM.
#8 _Cane_It_
_Cane_It_
Posted 24 July 2007 - 09:40 PM
Cane-it..
Obey 1
cheers mate, you confirmed everything I suspected, I've already soldered up the lug and all the wiring, so she'll be good to go if I need to drop the motor in in a hurry.
#9 _Eagle_
_Eagle_
Posted 25 July 2007 - 01:40 PM
G'day Herne, would love a copy too. Please e-mail to eagle at vision dot net dot au
Thanks :D
#10 _Herne_
_Herne_
Posted 25 July 2007 - 02:05 PM
^^^^ sending now.
Herne
#11 _PhillH_
_PhillH_
Posted 21 December 2016 - 01:05 PM
Hi Herne,
I realise this is an old thread :( but is there any chance I can get a copy too?
My email address is:
phill h 76 at y a h o o dot c o m
Thank you?
#12 rodomo
  • 18,039 posts
Posted 21 December 2016 - 09:50 PM
Herne hasn't been on for over 4 years sorry mate.
#13 Bigfella237
Posted 22 December 2016 - 08:36 AM
Enough of this emailing crap already, if it was simply attached to this thread then any one of a hundred people would be able to help you... why is a wiring diagram such a secret?
I have a full colour LH diagram here in PDF format, and I have a black & white scan of the LX diagram, which says "to be used in conjunction with LH diagrams", and I've got a black & white copy of the UC diagram "for all models", but I'm sure they all came from this forum anyway so maybe do a Google search?
#14 hanra
  • 10,978 posts
Posted 22 December 2016 - 09:24 AM
I scanned a nice High Def copy of the LH wiring diagram from the GMH Service Manual. If I upload it to photobucket or something, I think it automatically resizes it so its not as clear as the original. If I host the PDF to a website, that usually expires after a period of time.
#15 Bigfella237
Posted 22 December 2016 - 10:15 AM
The copy I have is probably yours anyway Brad, it's only 847KB so is able to be attached to the forum...
#16 hanra
  • 10,978 posts
Posted 22 December 2016 - 03:41 PM
How do you attach PDF's here?
#17 Bigfella237
Posted 22 December 2016 - 03:51 PM
Same way you attach photos... click on the blue "More Reply Options" button below the text box, once the new window opens, click below "Attach Files" on the "Choose Files..." button.
You can either leave them as attachments like I did above, or you can place the cursor where you want the attachment within your text and click "Add to post" to insert it.
EDIT: I forgot to say, maximum size of attachments in any one post is 1000Kb
Edited by Bigfella237, 22 December 2016 - 03:52 PM.
#18 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 23 December 2016 - 04:49 PM
It looks identical to the one I've downloaded from here before.
#19 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 26 December 2016 - 09:21 AM
You should also be able to photobucket it right?
s
#20 hanra
  • 10,978 posts
Posted 26 December 2016 - 02:35 PM
I don't think you can photo bucket PDFs?
#21 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 27 December 2016 - 05:04 PM
I meant to say, scan it, save it as a jpeg and photobucket it or use some other method to jpeg it so we can all view it online easily.
s
Edited by StephenSLR, 27 December 2016 - 05:04 PM.
#22 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 30 December 2016 - 09:39 PM
Sounds like a plan.
#23 hanra
  • 10,978 posts
Posted 28 February 2017 - 07:56 AM
The circuit diagram that was getting passed around in the original few posts, was it actually an LX wiring diagram? Or was it the LH one? Ive still not come across a decent LX wiring diagram that incorporates the few minor changes of the LX harness compared with LH.
