308 oil filter no clearance to thermo fans
Posted 22 July 2007 - 12:10 PM
Posted 22 July 2007 - 12:37 PM
Posted 22 July 2007 - 12:51 PM
Posted 22 July 2007 - 02:36 PM
#5 _wombat_
Posted 22 July 2007 - 02:44 PM
i've been using the small one for years to get oil pressure up quicker on 1st start
on a black 308 in a vk,dunno when the thread changed on these pumps.if no joy what would be cheaper,remote mounted filter or later oil pump?
Posted 22 July 2007 - 03:50 PM
Posted 22 July 2007 - 03:59 PM
#8 _lx5008_
Posted 22 July 2007 - 05:14 PM
Posted 22 July 2007 - 05:51 PM
#10 _tonyslr5000_
Posted 24 July 2007 - 09:16 PM
you may want to check the filter your using ,just because the thread is the same , fikters have different characteristics. ie return and pressure valves inside the unit.
Posted 24 July 2007 - 10:02 PM
Posted 26 July 2007 - 11:24 AM
Posted 26 July 2007 - 12:10 PM
Are you sure about that? I bought a brand new pump for my VT and fitted it to my Torana and the old filter from the Torana screwed straight ontryed injected oil filter but oil pumps are different thread 7/8" where red 308 thread is 13/16" i wish it was that simple
#14 _Herne_
Posted 26 July 2007 - 12:18 PM
Sounds like a dodgy pump may be the source of the problem.thanks for the ideas guys have managed to find a filter to suit off of hilux V6 has same thread size 3/4" unf but i am now unsure of oil pump fitted to engine as the oil filter doesnot sit horizontal but angled slightly upwards i think this mod has something to do with front sway bar setup it has Selby swaybar which would also have fouled on original horizontal standard oil pump/filter setup allgood now anyway.
Herne
Posted 26 July 2007 - 04:24 PM
Hi Guys.but i am now unsure of oil pump fitted to engine as the oil filter doesnot sit horizontal but angled slightly upwards
There was a popular conversion in the 70s which used a Chrysler V8 pump of some sort, with an adaptor. These had the filter sitting at an angle & used a filter with a different thread. I thought that these kits used a Z9, in which case a Z10 or a Z89A is the short version.
Dr Terry
Posted 26 July 2007 - 05:59 PM
From the left is the standard genuine Holden oil filter fitted on the 308 in the late 70's and as still available today (with slightly different writing) Z30 is the same.
The next is the AC Delco replacement which is slightly shorter. AC Delco also make one the same as the Holden version
The next is the A9X filter which is shorter again, NLA.
After that comes the genuine Holden VT 304 filter which is the same as the Gen 3 filter
And last is the AC Delco replacment for the VT filter.
Posted 26 July 2007 - 06:34 PM
I think Dr Terry might be on the money with his diagnosis still haveing a few teething issues with the thermos but BROWNS Radiators[Perth] who supplied radiator and thermos together mounted up told me run 40 amp relay for thermos as mentioned earlier AU Falcon twin setup but i am haveing dramas with every now and then 40 amp blade fuse blowing i have run 4mm wire from battery with fuse inline direct to relay to supply power for thermos i am thinking of putting a resettable 40-50 amp circuit breaker in place of fuse i am wondering if maybe one of the new fans comeing from a Ford might be dicky any ideas.
Garth
Posted 26 July 2007 - 06:43 PM
Based on the specs I have for SPAL fans I would expect each fan to draw around 20 amps. If you have each fan on a separate 40 amp fuse and it is blowing then you have a problem. If the 40 amp fuse is shared between the two fans then it could be expected to blow.
Edited by ls2lxhatch, 26 July 2007 - 06:46 PM.
Posted 26 July 2007 - 06:56 PM
#20 _rorym_
Posted 26 July 2007 - 06:57 PM
Please be careful with this shit...We first ran the Honda CBX 1000 6 cylinder bikes in the Production Race in NZ b4 we ran them in the Castrol 6 Hour in Aust....we ran out of CBX 1000 filters and used CB 900 4 cylinder ones....we seized 2 motors b4 we worked out they flowed different volumes....double check all things like volume flow.....it might not be relavent here but being warned is being knowledgable.Can anyone tell me if they know of reduced size engine oil filter [length] to suit red 308 similar in size to injected 5 litre filter as i have just fitted a polished alloy radiator with thermo fans from i hate to say it but AU falcoon into my LH SLR5000 and i now have clearance issues with standard oil filter .?
Posted 26 July 2007 - 07:12 PM
#22
Posted 26 July 2007 - 07:25 PM
#23
Posted 26 July 2007 - 08:08 PM
Should screw on where a Z30 (or smaller) fits.
Just a thought.
Edited by rodomo, 26 July 2007 - 08:13 PM.
#24
Posted 26 July 2007 - 09:55 PM
#25 _HRV74_
Posted 01 August 2007 - 10:44 PM
The filters were supplied to me by Shanes Race Engines in Wollongong.
Edited by HRV74, 01 August 2007 - 10:46 PM.
