SLR 383
96 replies to this topic
#26 _the gts_
_the gts_
Posted 05 November 2007 - 07:52 PM
Well today I finally sent my application in to DPI, all 33 pages.
Fingers crossed.
If nothing else I have learned a LOT about my car from all the measurements taken, reading of ADR's NCOP etc.
one funny thing in the ADR's. If you are usig a tyre that is capable of over 300kM/h, you should abide by the manufacturers maximum load reccomendation above that speed. HA HA
#27 _the gts_
_the gts_
Posted 03 December 2007 - 10:52 AM
WHOO HOO
Got my approval in principal back.
Mini Tubs and relocated coil overs are allowed.
they will only allow 235 tyres at the moment though - weird.
#28 _moot_
_moot_
Posted 03 December 2007 - 11:33 AM
i have no limit to tire size on mine,just limited to a 10" rim.
#29 _the gts_
_the gts_
Posted 05 December 2007 - 02:53 PM
Yea i am waiting to talk to the engineer when i get back to Oz. until lthen he has asked me ti fill out a bucket load more forms.
#30 _the gts_
_the gts_
Posted 13 January 2008 - 05:11 AM
Someone asked me before about mods i did to the console bit to fit a B&M inside the standard console. Here are some pics.
its not finished yet, there are still a few things left to do in it but it gives an idea. I am planning to get the woodgrain done on top to match the dash and make it look standard.
This suits a B&M megashifter Note it is used with a TH700 4 speed
Edited by the gts, 13 January 2008 - 05:13 AM.
#31 _Brewster_
_Brewster_
Posted 15 January 2008 - 10:01 AM
Thank you for those pics Phil, it looks awesome and is a really great idea. Your project is coming along very nicely! :D
#32 _the gts_
_the gts_
Posted 24 January 2008 - 05:39 AM
Hand brake cable set up inside the car
#33 _the gts_
_the gts_
Posted 05 February 2008 - 08:37 AM
As the lowest part of a torana is usually the exhaust under the gearbox crossmember I decided to put the x-member inside the car. the new one is only 10mm high so shouldnt affect carpet too much and it is very strong. this should allow me to lift the exhaust about 30-50mm. they are not welded in yet, that will be done on the rotisary to ensure they are square underneath.
Edited by the gts, 05 February 2008 - 08:39 AM.
#34 _the gts_
_the gts_
Posted 05 February 2008 - 08:40 AM
Have started on cutting the tubs out, hopefully the parts will arrive in time for me to finish before going back to work next week. I will put up more pics when they are done
#35 _moot_
_moot_
Posted 05 February 2008 - 08:50 AM
looking good mate.i've cut mine up again too :spoton:
#36 LXCHEV
LXCHEV
  • 3,585 posts
  • Car:'76 LX - 383 Chev
Posted 05 February 2008 - 08:52 AM
Nice thinking with the gearbox crossmember - man that will give you stacks of room to play with the exhaust system.
#37 Heath
  • 18,383 posts
Posted 05 February 2008 - 02:18 PM
Very wise idea! Any problem getting it engineered do you think?
PS you might be the first but I don't think you'll be the last to do that!!!
Edited by Heath, 05 February 2008 - 02:19 PM.
#38 _the gts_
_the gts_
Posted 05 February 2008 - 10:05 PM
WHOO HOO
Tubs and coil overs turned up today - WOW the QA1's are light
Engineer turned up this afternoon - didnt really give any answers but wasnt too keen on the tubs although he did mention gutting the whole rear and welding in one of the rear clips. Thats a lot of work and more $$$
Just for others interest DPI have said a carb is ok but Rod says he hasnt been able to get a carb over the pits for over a year.
I think i am gonna have to do the chassis twist test.
No there is no problem with the G/Box mounts.
#39 _the gts_
_the gts_
Posted 05 February 2008 - 10:06 PM
Oh yea if anyone wants more info on G/Box mounts I have more pics which i can email and also give measurements
CHEERS
PHIL
#40 _Baronvonrort_
_Baronvonrort_
Posted 06 February 2008 - 11:35 AM
CHEERS
PHIL
Just post more gear box mount pics and dimensions in this thread to save hassles..lol.
I think it will be much stronger than original so engineers comments also appreciated.
#41 Heath
  • 18,383 posts
Posted 06 February 2008 - 12:22 PM
Yep I would post them up here, or maybe even PM an admin such as Tiny and get them to put it up as a Tech Article?
#42 _the gts_
_the gts_
Posted 06 February 2008 - 10:52 PM
engineer saw the gearbox mounts today from the bottom and said "the floor is not going to be strong enough for that" then i showed him the other side and explained it all to him. he said "thats a very good idea, i like that"
they are now tacked in and i can definately say its not worth the effort if the car is not on a rotisary or hoist. a lot of work getting them to line up.
#43 _the gts_
_the gts_
Posted 22 March 2008 - 10:53 AM
new chassis rails complete and shocks all mounted, tubs will not be welded in until engineer is happy with the rails just in case i need to modify something. I still need to cut the wheel well out and fab up part of the boot floor to cover the shocks, a bit tricky because the position of the shock bolts will be difficult to access from under the car.
great ride height adjustablity though!
#44 _2wild4u_
_2wild4u_
Posted 22 March 2008 - 11:20 AM
coming along very nicely, keep us updated
#45 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 22 March 2008 - 07:21 PM
Top effort Phil, looks a million $$$'s.
Dave
#46 _moot_
_moot_
Posted 23 March 2008 - 12:04 PM
over here in nsw,you'd have no chance in hell of rego. you cant touch the factory rail from the diff forward. looks good though :spoton:
#47 _the gts_
_the gts_
Posted 03 May 2008 - 11:21 PM
Beautiful - booked into panel beater August, here are a few pics of the tubs and chassis complete, F**K the a$$ end is very solid compared to a standard torana + I took out about an extra 30Kg while on the rotisary!
I am pretty happy with the ride height of the rear but obviously it is now fully adjustable up or down, will look even better with the 18's. There is 365mm width in the rear guards now and have been told the widest in 18" is a 315 or 335 so they will look awesome :rockon:
#48 _the gts_
_the gts_
Posted 03 May 2008 - 11:24 PM
Oh yea, I run out of Mig gas, grinding discs and Jack daniels so still need to tidy it up quite a lot yet!
#49 racean69
racean69
  • 782 posts
  • Name:Rod
  • Car:LH sedan
Posted 04 May 2008 - 09:40 AM
Coming along good.... am watching keenly
#50 _TJ253_
_TJ253_
Posted 04 May 2008 - 10:36 AM
sounds like its coming along well keep up the good work
