Fine and coarse spline axles
40 replies to this topic
#1 _pallbag_
_pallbag_
Posted 01 August 2007 - 07:33 PM
What are the advantages/disadvantages of either a coarse or fine spline axles in diffs?
And what/how do you differentiate(hehehehe get it, DIFFerentiate) between both? 31 spline for eg. is a .... spline axle
#2 rodomo
  • 18,038 posts
Posted 01 August 2007 - 08:06 PM
Q.Fine and coarse spline axles, whats the diff?
A.The diff is the bit between the axles regardless of coarse or fine splines.
#3 _pallbag_
_pallbag_
Posted 01 August 2007 - 08:10 PM
Please translate diff as being difference ... But thanks for the input rodomo !!
#4 dattoman
  • 16,487 posts
Posted 01 August 2007 - 08:40 PM
Course spline Holden is about 10 splines
Fine has more but I can't remember how many ... haen't broken any in awhile (28 maybe ?)
So thats the easy method..... course or fine
The more splines the stronger the axle
Talking Ford 9" they start at 28 and you can buy axles and centres in 31,33,35 and beyond
#5 _Rob 5000_
_Rob 5000_
Posted 01 August 2007 - 09:41 PM
I think all LSD had fine spline.
#6 Peterpilot
Peterpilot
  • 185 posts
  • Name:Peter
  • Car:SS Hatch
Posted 01 August 2007 - 09:42 PM
Coarse spline: I've broken plenty of these, they snap like celery sticks.
Fine spline: I haven't broken any... yet.
#7 Heath
  • 18,393 posts
Posted 01 August 2007 - 10:20 PM
Course Spline are 10 splines, Fine Spline is like 18 or something isn't it?
Anyway the fine spline axles distribute the torque more evenly around the axle to compensate for its tiny diameter. I've been led to believe that they make a significant difference in strength.
#8 _73LJWhiteSL_
_73LJWhiteSL_
Posted 01 August 2007 - 11:46 PM
I thought fine was 23 spline.
But then i though course was 11.
Shows how much i know. :tease:
Steve
#9 rodomo
  • 18,038 posts
Posted 02 August 2007 - 12:35 AM
More input:
Coarse are cut further into the axle thus making the machined diameter of the axle smaller therefore weaker.
Edited by rodomo, 02 August 2007 - 12:36 AM.
#10 _HatchmanSS76_
_HatchmanSS76_
Posted 02 August 2007 - 03:33 AM
Just to add another number. I thought fine spline bangos were 21 splines
#11 _82911_
_82911_
Posted 02 August 2007 - 08:24 AM
course=10 splines
fine=23 splines
early BW=25splines
lateBW=28 splines
passenger9"=28splines
commercial/racing 9"=31 splines
aftermarket 9" axles avaliable in 33/35/40 splines.
Small Dana's=25 splines
Large Danas =33 splines
I think that should clear it up sufficiently! :D
Cheers Greg..
#12 _73LJWhiteSL_
_73LJWhiteSL_
Posted 02 August 2007 - 10:27 AM
Thanks Greg.
With all that info can I ask a mod to Sticky this thread please?
Steve
#13 WhiteA9XS
WhiteA9XS
  • 1,646 posts
  • Name:Shaun
  • Car:LJ LX
Posted 02 August 2007 - 01:20 PM
greg you forgot the salsbury
#14 _HatchmanSS76_
_HatchmanSS76_
Posted 02 August 2007 - 09:14 PM
Greg you don't have any volvo numbers as well do you. Blood thick fine spline axels and a conversion option for Torana's, same stud pattern.
#15 _82911_
_82911_
Posted 03 August 2007 - 07:25 AM
Volvo is small Dana
#16 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 03 August 2007 - 07:45 AM
V8 Salisbury is 28 spline, identical to pass. 9" in diameter, pitch etc.
#17 _pallbag_
_pallbag_
Posted 03 August 2007 - 07:46 PM
So fine spline axles need fine spline diffs ? Not differences as in explained earlier ...
#18 _uglybob_
_uglybob_
Posted 03 August 2007 - 08:40 PM
pretty much unless you jsut change the side gears in the diff.
#19 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
  • Car:76 LX Sedan, 4 seater
Posted 05 August 2008 - 01:05 PM
Have a look at the UC disc brake conversion article for pics of Torana coarse and fine spline axles.
Please note that the die/mould for torana axles changed with the UC, so UC axles should be a much solider unit compared to an identically splined LH/X unit.
Grant..
#20 _202LX_
_202LX_
Posted 13 August 2008 - 03:13 PM
I have heard that you can use a kingy fine spline diff centre (HQ for instance) and UC axles in an LX/LH diff housing and get a stronger diff. Any one done this or know if it will work?
#21 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 13 August 2008 - 05:23 PM
dont think so ive got a kingsy centre in the garae and its bigger than a banjo
#22 76lxhatch
  • 7,207 posts
Posted 22 August 2008 - 12:59 PM
Almost - the later model (e.g. HZ) six cylinders had the fine spline Banjo centre (utes had LSDs too), which will fit into any Banjo housing. Then add UC axles which have the fine spline and you are away. You can also just rob the fine spline side gears from the UC Salisbury and put them in the Banjo centre.
#23 _HQ SS_
_HQ SS_
Posted 23 August 2008 - 10:09 AM
I think it has been explained well as to what the differences are but if you want to have a look at the
differences between course and fine spline banjo axles and spider gears in pictures.
Also the differences between banjo to salisbury to 10 bolt axles and a few other diff related pictures
I have a few pictures here
http://gallery.oldho..._SS/Tech/Diffs/
that show the differences and general layout of various components.
Cheers Paul.
#24 _studricho_
_studricho_
Posted 02 June 2010 - 11:08 PM
I was always lead to believe that axle splines where rolled into the axle as part of the axle process from factory giving it good strength as your not taking away any material.
When they cut splines into axles they are actually taking away material making the axle weaker. This was what my boss explained to me after I started to snap fine spline axles 28 teeth after getting rear axles made to suit the commodore stud pattern After snapping 4 axles I was told I needed a 9 inch and that's when the head ache began.
Was I miss-informed as a young apprentice?
#25 Heath
  • 18,393 posts
Posted 02 June 2010 - 11:52 PM
Sure is an old thread ya found!
Some standard ones may be cold formed (particularly the V-type splines found on fine spline Torana diffs as opposed to the squaretooth splines found on coarse spline Torana diffs), I've only ever seen them machined but I haven't worked in a factory that mass-produces them.
One of the problems with the typical production car splined arrangement is that the outer diameter of the splined area is the same as the shaft diameter. This means that you get effectively a smaller diameter axle under where the splines are situated. So you're using excessive material for the same torsional rigidity if that makes sense. Basically you end up with a spline diameter that is undersized and a shaft diameter that is nominally oversized (or both undersized in the case of a Torana LOL) and isn't giving you any strength anyway because that isn't the weakest point
The best way to do a splined shaft is to have a larger diameter at either end of the shaft, with a radius leading into that diameter so that there are no stress concentrations (another problem with the typical production car spline arrangement). If the smaller diameter matches the depth of the splines, then you just machine the splines into that larger diameter, back and forth with an indexing head of some description, until you reach the nominal shaft diameter. This also means that the axle is allowed to 'wind up' a little bit so that the peak destructive forces are spread out over a matter of a very small timeframe which seems to make a difference, and when you have a shaft of this design it ends up being lighter too, which in a diff is bloody important if you actually want to go around corners and get the car to handle as well as possible.
Edited by Heath, 02 June 2010 - 11:57 PM.
