You make it sound soooo easy!Nah it wasnt necessarily hard, just time consuming. We havent really had practice on anything, dad has a spare torana backseat at work so he was able to fabricate the cover to fit over that one and made it work and then we just placed it over the one in the car at home, and clipped it into place.
The backrest part is just the ones from a VR with a custom made, shortened centre part. But it looks so much better. Looking forward to when its finished, engineered, registered and on show at Supernats!
Torana seats are 120mm shorter than the VR. so I used the Torana lower. The VR lower was stripped and the trim shortened, the Torana seat required extra padding to fill the trim properly as well as mounting points holding the original wires in the middle of the seat when this was all sorted the trim was refitted to the seat and all the ring clips refitted. all up about 3 hours work.
On the back the rear of the VR is a close fit it required mounting points to be made to fit the seat as per factory this was then bolted through the floor where the seat belt bolts would have secured the VR seat. we then constructed a centre piece using the foam from the VR centre boot access panel some ply and the original factory vynal that we purchased. just need to refit the belts.
Hope this helps
