V6 LX Torana
#51
_youngy_11_
Posted 05 November 2007 - 05:54 PM
The original torana heater box has an inlet and outlet doesn't it???
Have you plumbed up any hoses so the car can be heated??
Also is the power steering pump the only idler besides from the original ones needed??
Was the air con by-passed???
Have you got and better photos of how you made the idler from the original power steering one because it looks heaps better than the v6conversions one.
Also is you air box mounted???, whats the bottom section of it look like as i have only got a top half and where does the air enter??
I was looking at buying a aluminum pipe like you have but have a pod on the end, are they legal ive heard there not, im probably best speaking to the engineer.
_TJ253_
Posted 05 November 2007 - 06:26 PM
#53
Posted 06 November 2007 - 03:25 PM
Hey youngy_11,The original torana heater box has an inlet and outlet doesn't it???
The torana has no heating or air conditioning in it. The air conditioning was deleted and using a non air-con belt.
The power steering pump is the only other idler besides the original ones needed.
I will also get you some better pictures of the power steering pump over the weekend once it stops raining.
Yes the airbox is bottled in place in the battery tray. The battery has been relocated to the boot. The bottom section is similar to the top and holds the filter. The top clips to the bottom. The air enters from a hole facing the headlight.
Pod Filters are illegal, unless fully covered.
Hey Mitch We use Blue Chrome at Bankstown they Do a Top job and are well Prised .
Yeah toddles we thought the same thing. They have been there for ages and dad has used them many times with his other projects. We were very happy when they quoted the price, and ecstatic when we saw the outcome.
Mitch
#54
_youngy_11_
Posted 06 November 2007 - 06:02 PM
Well why does the torana have 2 pipes coming in and out of it and a small radiator type thing in it???
I thought the hot water was run through the air box and theres a flap on the inside that is adjusted to allow cool air to pass through or air to flow through through the radiator, i.e hot air.
Thanks mate
#55
_studricho_
Posted 07 November 2007 - 09:37 AM
The torana heater box has two pipes so the water can flow through small radiator in heater box and then back into cooling system.Ok thanks mitch,
Thanks mate
Your correct about the flap thing in heater box. It governs how much air goes over the small radiator in your heater box.
Fully open=more air through small radiator=more heat.
Fully closed=no air through radiator=cold air.
#56
_youngy_11_
Posted 07 November 2007 - 10:05 AM
So how do I go about connnecting it in with a V6???
So you didn't connect anything to it mitch??
#57
Posted 07 November 2007 - 03:00 PM
check out what she had done with her inlet manifold. would improve the bay alot more mate. Mill the 3800 off and get it polished up.
Besides that mate, looks pretty horn.
Good luck with it all mate.
#58
Posted 18 December 2007 - 11:42 AM
Mitch
#59
Posted 18 December 2007 - 12:20 PM
#60
_evil_lh_
Posted 18 December 2007 - 03:33 PM
myles
#61
Posted 18 December 2007 - 03:40 PM
I can't believe you posted photos with no E.T.s! lol
#62
_TJ253_
Posted 18 December 2007 - 05:23 PM
#63
Posted 18 December 2007 - 05:53 PM
Edited by MRLXSS, 18 December 2007 - 05:54 PM.
#64
Posted 18 December 2007 - 08:31 PM
Yeah Heath Dad ran the street wheels for go-to-woah and his first drag, but then swapped to his slicks for the last one.What is with the rear wheel of the Monaro in the third pic? Are those pictures from different runs and he changed wheels?
Will post up time slips soon.
Mitch
#65
Posted 18 December 2007 - 08:35 PM
Look forward to the times, thanks Mitch!
#66
Posted 19 December 2007 - 05:07 PM
Best time -
Go-to-woah:
R/T: .486
60' : 2.368
330': 7.681
Drags:
1st run -
R/T: .410
60' : 2.598
330' : 7.153
660' : 10.797
mph : 68.30
1000' : 13.946
ET : 16.643
mph : 83.28
kmh : 134.03
2nd run -
R/T : .405
60' : 2.466
330' : 6.746
660' : 10.289
mph : 69.61
1000' : 13.397
ET : 16.069
mph : 84.02
kmh : 135.22
#67
_lcv871_
Posted 21 December 2007 - 03:20 PM
#68
_2DOOR_
Posted 23 December 2007 - 04:56 PM
While he mentioned the diff centre I didnt want him preforming a burn out due to this and seeing video of the run there was a bit of wheel spin on the first to second change.
but one of the other things is when I set up the speedo we found that the shifter mechanism hits the speed sensor if we try to manually select a lower gear than drive, so this meant racing in drive and the subsequent gear shifts around 3800 rpm. So we know there is a fair improvement available as we sort it out.
although if you have read this far you may recall that the brief that Mitch set was to have the car ready and registered by Supernats and he achieved that goal:clap:
now he has till July before he gets his P's
#69
Posted 26 January 2008 - 12:08 AM
Also,
I am looking forward to taking it out on the dragstrip again. Unfortunately I am working next Friday so I can't make the Full Throttle Friday at WSID, but has there been any talks about another GMH-Torana.com WSID drag night? As I would be very interested!
Mitch
#70
_ljharbsy_
Posted 26 January 2008 - 12:19 AM
Nice looking car would be interested in some engine bay pics and maybe later you could drop a supercharged number in it for more herbs.
#71
Posted 26 January 2008 - 12:36 AM
Pics will be taken tomorrow upon request. As for the supercharger... no matter how good that sounds, it is still illegal for me for about 3 and a half years, as is any performance upgrades and unfortunately a V8Mitch,
Mitch
#72
Posted 26 January 2008 - 11:29 AM
#73
Posted 02 February 2008 - 07:50 PM
As apart of my Design and Technology Major project, I have decided to build my own 'Torailer'. Well this is slowly but surely coming true. I recently purchased this -
After some grinding and cutting with the oxy, it has now transformed into this -
Will hopefully put up a thread in members projects and plans soon on this project, but I am curious about peoples input in this project e.g. trailer chassis dimensions, ideas for features to incorporate into the 'torailer'.
Dad and I have been talking about this for some time now, and we think we have come to a final decision as to the reason I have decided to build it and for what purpose I am going to use it for, but before i tell about that, I am interested to know what other forumers would suggest.
Mitch
#74
Posted 19 February 2008 - 02:29 PM
Tim
#75
Posted 19 February 2008 - 02:37 PM
