Info on Rover V8's?
28 replies to this topic
#1 _Viper_
_Viper_
Posted 26 August 2007 - 10:04 PM
Hey guys... well researching the lil alloy rover V8's... anyone know any websites with any specs? especially external dimensions
is there any aftermarket performance parts for these motors? or even stock parts new?
Any other info is appriciated
thx
#2 Heath
  • 18,380 posts
Posted 26 August 2007 - 10:27 PM
Yes there is a decent supply market of aftermarket parts. Don't know what the prices are like in comparison to Holden, Chev & Ford parts, but I know there are things out there.
Maybe talk to Rodomo, as he has quite an interest in these motors as well.
#3 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 27 August 2007 - 12:13 AM
Talk to a guy called Dave at T R Green performance or talk to another Dave at a place called Rovercraft. Haven't got either of their numbers on me, but both know their rovers, Rovercraft a little more so, they've been racing them for years. Both in Perth as well.
What's the new project?
Dave
#4 _Viper_
_Viper_
Posted 27 August 2007 - 12:31 AM
LoL what is it a prerequisite that if your name is dave you have to be into cars and work at a automotive business? I got sooo many daves in my phone now that are all car related..
Cheers tho Dave, might look up rovercraft then...
Stroked 3.5L Rover in my Gemi Coupe... if it fits which is why im tryin to find dimensions... but its within the legal limits well not once its stroked but the RTA wont know that :D
Edited by Viper, 27 August 2007 - 12:32 AM.
#5 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 27 August 2007 - 11:48 AM
Dave's not here man.
:D
:blink:
#6 _[BOTTLEDUP]_
_[BOTTLEDUP]_
Posted 27 August 2007 - 04:39 PM
No its Dave!!...
Who?
#7 rodomo
  • 18,032 posts
Posted 28 August 2007 - 12:56 AM
Here are some dimentions:
This is the motor as fitted to my Rangie:
Overall height with aircleaner and sump is 74cm.
Overall width with extractors is 63cm.
Here is a pic of the motor with an E.F.I inlet manifold and twin WW2 strombergs.
This is a plan I have for the Commodore racer later.
I have a set of Rover S.D.1 extractors and a Bosch/Fairchild distibutor to go with it. The S.D.1 extractors flow better than the ones pictured and the Bosch dissy is basically the same as Holden H.E.I
The 3.5 was available in Range Rover, Discovery, Landrover, Rover 3.5 car and S.D.1 car.
The early motors had rope front and rear crankshaft seals. The later ones had neoprene seals and are better.
Standard twin 175cd manifolds are easy to adapt to Holley or WW2 stromberg.
Bosch dissy was available on late S.D.1 E.F.I motors but are rare.
A lucas electronic ignition is more common.
Late motors were E.F.I
E.F.I cam into carburetted motor is a cheap upgrade.
Some Buick parts e.g. timing chain kits will fit.
E.F.I S.D.1 heads have bigger valves.
If you are freshening up a standard 3.5, buy 2 sets of Holden 173 rings as they are the same and cheaper than 1 set of Rover rings.
Lifters are the same as Holden and V8 Holden lifters are cheaper.
Range Rover clutch plate is the same spline as Aussie.
Short manual bell housings are rare (Range Rover bell housings are really deep) and manual car bellhousings are rare. B/W auto bellhousing wouldn't be hard to adapt to manual and are shallow.
Too much horsepower on an early block can crack the webbing under the valley cover. Later blocks are stiffer.
Hi-Comp pistons are available $400ish a set.
A few different sumps available (I have 3 different sumps here) and would be more friendly if the Gemini rack is in front of the "X" member? as the pans are toward the rear.
A few different timing cover/ water pump combos available. The car ones leave the water pump lower under the bonnet and therefore the fan.
Would be a good swap into Gemini and I have been looking for a shell for racing.
A Piazza shell would be better :spoton:
I will see if I can weigh the motor in the top pics. I can tell you though they are lighter than Holden six and may be as light as Gemini as I can lift the engine pictured on my own and I'm not Hercules. :blink:
Edited by rodomo, 28 August 2007 - 01:04 AM.
#8 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 28 August 2007 - 08:09 AM
are they same or similar to p76 v8?, a freind many years ago had a p76, and he always mention rover v8 for some reason.
He had a mega cam, holley 4b carb..ported heads, it did go good, even tho it was a p76 :D
#9 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 28 August 2007 - 11:55 AM
Edelbrock do an inlet manifold for them as well.
Some great info there Rodomo, legend!!
Dave
#10 rodomo
  • 18,032 posts
Posted 28 August 2007 - 03:11 PM
Similar but not the same. I think the "V" is a different angle?
3.5 inlet manifold wont reach across 4.4 block without spacers.
Later Rangie/Disco motors are up around 4.6 and are the same as the 3.5 block as far as width.
My engine builder buddy mods these and gets them out past 5 litre.
I'll see if I can get some specs and H.P figures soon.
The best 3.5 to start with would be late S.D.1
I bought a carburetted S.D.1 complete but engine dismantled and diff removed (but with car) for $55 a couple of years ago.
Got more than my money back when I sold the bits and ended up with the motor.
Edited by rodomo, 28 August 2007 - 03:18 PM.
#11 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 28 August 2007 - 03:31 PM
some model buick v8 heads fit
#12 _Yella SLuR_
_Yella SLuR_
Posted 28 August 2007 - 03:44 PM
You can turbo charge em and put them into a Sports Sedan and still be under 6.0L!!!!!
#13 rodomo
  • 18,032 posts
Posted 28 August 2007 - 03:50 PM
Yep, but some have big combustion chambers and its difficult to raise compression on a 3.5.
#14 _[BOTTLEDUP]_
_[BOTTLEDUP]_
Posted 28 August 2007 - 04:30 PM
All comes down to how much you want to spend... Remember these engines formed the basis for the Repco F1 engine in the 60s
#15 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 28 August 2007 - 04:55 PM
good place to leave it, on the lawn mower :tease: I have seen a rover V8 in a blue lh/lx in SM, 20yrs ago. A toyota V8 would be a better engine to play with. You can buy a complete toyota for $800
#16 rodomo
  • 18,032 posts
Posted 28 August 2007 - 05:55 PM
But not as compact.
Viper wants to put one in a street reg. Gemini.
#17 Gump
Gump
    Paisty White
  • 1,146 posts
  • Name:Russell
  • Car:LX SL hatch
Posted 28 August 2007 - 06:36 PM
i was reading the quokka a few weeks back and there was a turbo (think it was twin turbo) rover v8 in a lc lj sounded alright
#18 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 28 August 2007 - 07:25 PM
But not as compact.
I was looking at a 308 Gemini last week. My mate has one and if a 308 will fit, any small block V8 will fit. It's the length of the engine that is the only problem.
Edited by lakeside, 28 August 2007 - 07:26 PM.
#19 _Viper_
_Viper_
Posted 28 August 2007 - 09:08 PM
Yea the length is the problem... Id prefer not to hack into the firewall and have just over 600mm to play with..
Rodomo You show the length as 600mm but in the pic with it mounted on the mower it has the front pulley attached and looks to be least 100mm long... Is it possible to reduce this pulley to one belt slot only?
Im also worried the waterpump and alternator may be even further forward?
RE: the sumps, would u happen to have a pic of each (side on) and yea gemi steering rack is on front of the x-member so one with the sump at the rear would be best..
Cheers tho is good info!
Edited by Viper, 28 August 2007 - 09:09 PM.
#20 _Viper_
_Viper_
Posted 28 August 2007 - 10:16 PM
Jus did a rough measurement in the coupe... Fits width peice of piss, and Height should be fine with the right sump and I wanna use a EFI intake so should be heaps of room...
If I can move the radiator forward and as long as the waterpump n alt dont stick out way forward it just might fit!
#21 rodomo
  • 18,032 posts
Posted 29 August 2007 - 12:53 AM
More "adjusted" pics:
Overall length with pulley fitted is 67cm.
I have added the radius size of the bellhousing which would also be a big consideration:
And the sumps, the red dotted lines indicate the sump as fitted to the Rangie, about 1 litre more capacity. The top sump has a bracket that bolts to the bellhousing on a car auto. They also have surge/splash plates in side.
#22 _Viper_
_Viper_
Posted 29 August 2007 - 07:57 AM
Sweet that top sump would be the best one for sure... Altho still may need to cut some for the front the clear the x-member then maybe ad some width to it to keep the capacity up.. Is the pickup right at the rear? And is it steel or alloy?
Oh and are the 4.4's the same size externally? or only the 3.5's and 3.9's the same?
And Can the front pully be reduced down to 1 belt groove long instead of 3?
#23 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 29 August 2007 - 11:19 AM
There is a friend of my wife who has 2 v8 gemini's, one with a rover 3.5 and the other a 308.
The guy next door to our old place was messing with a 3.5 Turbo in a dolomite for years.
Welby
#24 rodomo
  • 18,032 posts
Posted 29 August 2007 - 03:09 PM
In the "lawn mower" pic, the pulley has only 2 grooves. My alt-water pump belt runs on the frontmost pulley. The p/steering runs on the inner pulley. The bolt holes and spigot for the water pump pulley are the same as early holden red 6 so perhaps a different pulley could be sourced? Or the flange pressed further onto the waterpump bearing? The alternator could easily be moved backwards (and relocated to where my p/steer pump is if need be) with fabricated brackets and then run the belt off the inner pulley?
Sumps are steel, pickup is in centre of pan.
I think the 4.4's are wider as mentioned above, not sure about length though.
There arent as many 4.4 blocks around as they were only in P76 and Leyland Boxer trucks here. I know the 4.4 wont bolt in where a 3.5 was without alterations to the engine mounts.
Edited by rodomo, 29 August 2007 - 03:14 PM.
#25 _Viper_
_Viper_
Posted 29 August 2007 - 06:24 PM
Thanks Rodomo very helpfull, If i can move the waterpump pully back as well as the alternator I should be able to fit it.
A9X I dont suppose id be luck enought for u to have pics of the gem with the 3.5L? If not can u remember how they mounted it? like did they chop out the firewall heaps or?
Ok next part... G/boxs.. Are the manuals Cable or Hydraulic clutch? And are they relatively bulky? Wouldnt happen to have any dimensions/pics of them either would u? maybe autos too...
It looks like its getting more plausable might keep my eye out for a 3.5L for sale...
I read somewhere the later model blocks are alot better? any way to tell which block is which for sure?
