My GTR Torana
206 replies to this topic
#126 _2runa_
_2runa_
Posted 29 May 2008 - 06:22 PM
clean the surface with a tiny bit of hydrochloric acid
#127 _2runa_
_2runa_
Posted 29 May 2008 - 06:27 PM
applied the kemtex on a cool panel then used the gas to tin it :D
#128 _2runa_
_2runa_
Posted 29 May 2008 - 06:32 PM
The shaping is not finished yet but is very close.
#129 _2runa_
_2runa_
Posted 29 May 2008 - 06:51 PM
When I first tried this i used 60/40 solder and bakers soldering fluid, it didn't work and i thought i would never be able to lead wipe. The DVD showed how it works,
it looked easy like all things do when someone else is doing it, with a bit of patients the lost art of lead wiping seam to fall in to place. I'm very pleased its lead for me :spoton:
#130 TerrA LX
Posted 29 May 2008 - 07:04 PM
Farken Awsome job mate :spoton: :spoton: :spoton: :spoton: :spoton:
#131 _2runa_
_2runa_
Posted 31 May 2008 - 04:32 PM
cleaned ready to weld then lead wipe
Edited by 2runa, 31 May 2008 - 04:33 PM.
#132 _2runa_
_2runa_
Posted 31 May 2008 - 04:38 PM
welded and lead wiped, just need to shape it :D
#133 LX 0076
LX 0076
  • 199 posts
Posted 31 May 2008 - 05:57 PM
just read this start to finish top job :spoton: Your skills are to be admired
Jayson
#134 _2runa_
_2runa_
Posted 31 May 2008 - 09:59 PM
Still a bit more shaping to do, Hey NO BOG :D :D :D
#135 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 31 May 2008 - 10:05 PM
Inspirational stuff mate... Wish I had the gear to do this stuff, that last pic shows exactly what I need to do to the LJ...
Tim
#136 _2runa_
_2runa_
Posted 31 May 2008 - 10:11 PM
Lead wiping takes a bit more work than bog, however i'm happy with the results :spoton: :spoton:
#137 rodomo
  • 18,037 posts
Posted 31 May 2008 - 10:41 PM
So am I :clap: :clap: :clap:
Old skool rools :spoton:
#138 _2runa_
_2runa_
Posted 31 May 2008 - 10:49 PM
Tim it's not as hard as what it looks, you just need a few tools and a bit of patiences.
#139 _2runa_
_2runa_
Posted 31 May 2008 - 10:59 PM
I would love to be able to panel beat like the Old skool.Then I would be able to give up my day job and do it full time :spoton: :spoton: :spoton:
#140 Zook
Zook
  • 1,536 posts
Posted 01 June 2008 - 12:24 PM
Nice work. As others have said, you've given those of us with rusty projects (and a few tools) some hope!!
Where did you get the lead wiping kit from?
Keep it up :rockon:
#141 _2runa_
_2runa_
Posted 01 June 2008 - 09:50 PM
All you need is a gas torch on low heat, kemtex, rag, paddle, and some files, I use a wood to rough it out then finish of with a metal file, a body file is best. dress up with 120 sanding block. If you google kemtex you may find a supplier close to you, cost about $80. Perth its avail. at 18 gibb rd cannington.
Remember The lead should contain about 18% tin only.
There is a DVD avail. Body lead work the lost art by Steve Frisbie
And thanks for the comments i hope it all helps.
#142 _@milco@_
_@milco@_
Posted 03 June 2008 - 10:34 PM
your a f*cking gun mate, bloody great work, restoring like it deserves to be done, keep it up buddy!
#143 _studricho_
_studricho_
Posted 04 June 2008 - 03:40 AM
I just sat and read this thread. One word describes this project.
Bravo!
Your work is excellent. Good to see someone doing the right thing.
#144 _2runa_
_2runa_
Posted 28 June 2008 - 08:52 PM
Thanks for the comments guys I've been away from the car and have just started back on it today, i have continued to complete the R/H rear today and finishing of the lead work. Bog is so easy to work however I'm still pleased even if it takes 3 times as long Its a good work out and saves me going to the gym :bowdown:
#145 _2runa_
_2runa_
Posted 05 July 2008 - 11:33 PM
When you think you've got it all there's more so what do you do :gun: cut it out.
#146 _2runa_
_2runa_
Posted 05 July 2008 - 11:52 PM
Have a good replacement panel from a doner.
Mock fit up.
Placed a row of holes accross the roof and plug welded the new panel in place
then fully welded the seam :spoton:
#147 _2runa_
_2runa_
Posted 06 July 2008 - 12:13 AM
After fully welding the new panel i lead wiped the repair :D
Just about finished shaping the lead filler However check out the speaker holes
looks like someone did this with a axe :fool: Make you wonder :<_<:
#148 _2runa_
_2runa_
Posted 06 July 2008 - 12:19 AM
Painted with epoxy undercoat I recon the parcel shelf next :D
#149 _2runa_
_2runa_
Posted 06 July 2008 - 11:48 AM
Can you believe someone who owned a GTR Torana did this :<_<: :<_<:
#150 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 07 July 2008 - 10:02 PM
No respect what-so-eva, some people need taking out and beating severly. :D
Mort
