My GTR Torana
206 replies to this topic
#151 _2runa_
_2runa_
Posted 07 July 2008 - 10:23 PM
Yeah Mort it's pretty average I recon, however I have two of these panels, this one has a little surface rust. I will pick the best one and use it. The thing I hate the most is the unpicking doner panels :furious:
#152 rodomo
  • 18,037 posts
Posted 07 July 2008 - 11:29 PM
You love it or you wouldn't be doing it. :spoton:
#153 _2runa_
_2runa_
Posted 07 July 2008 - 11:39 PM
I wish my talents were just us good as the talented person who put the speaker holes in with an axe. I would have completed the project by now :spoton:
#154 _2runa_
_2runa_
Posted 08 August 2008 - 12:25 AM
this took a fair bit of time to UNPIC i hate it :cry: however no rust in the rear window panel amazing :spoton:
#155 _2runa_
_2runa_
Posted 08 August 2008 - 01:04 AM
just an other shot of where i cut some more rust out :spoton:
#156 _2runa_
_2runa_
Posted 08 August 2008 - 01:21 AM
#157 _Machine_
_Machine_
Posted 08 August 2008 - 11:03 AM
Great work mate, excellent to see.
Theyre rusty bustards the old torries but worth it.
M.
#158 _2runa_
_2runa_
Posted 08 August 2008 - 09:05 PM
Just a mock fit up to make sure it fits :clap:
#159 _2runa_
_2runa_
Posted 09 August 2008 - 11:42 AM
I"m glad to have this section of the car completed, it took a while however the effort was worth it. NO RUST :clap:
#160 _2runa_
_2runa_
Posted 10 August 2008 - 02:22 AM
Leaded the repair just need to a do a little more shaping an she's done :spoton:
Edited by 2runa, 10 August 2008 - 02:25 AM.
#161 rodomo
  • 18,037 posts
Posted 10 August 2008 - 09:19 AM
There's that much lead in that thing now, I reckon you should name her "The Bullet" :tease:
Keep up the good work and the pics, you're an inspiration! :clap:
Edited by rodomo, 10 August 2008 - 09:20 AM.
#162 _2runa_
_2runa_
Posted 10 August 2008 - 11:49 AM
Hopefully it doesn't start to peel back like a hollow tip during it projectory. great name though. there's not alot of lead work left and when you file it back there 's only a thin layer, just enough to hide the seam. At least this GTR will survive . Hope these post help to inspire as this is my first project like this :blink: , just step back picture what you want to achieve and measure twice and mock fit every component making sure it has even gaps and lines :spoton: Thanks again for your comment Rodomo
#163 _v6locker_
_v6locker_
Posted 10 August 2008 - 12:52 PM
great work my friend makes me want to get stuck into my project...
#164 _2runa_
_2runa_
Posted 10 August 2008 - 08:31 PM
well jobs done just a little etch primer and then two pack hi fill primer on this section and.... :D and thanks V6 for your coments
#165 _2runa_
_2runa_
Posted 24 August 2008 - 11:28 AM
I was really surprised how well the R/Spares panel fitted . I plug welded the
edge through the puch holes then fully welded the seam. Then I lead the ....
rear seam :spoton: Ha Ha ! Just about out of lead :cry:
#166 _2runa_
_2runa_
Posted 25 August 2008 - 12:25 AM
There was three layers of Red paint, Blue spray putty, Cream undercoat and the
original Glacer White. I tried paint stripper on the roof but it was to slow,
Five 36 grit sticky back sanding disc did the job stopping short of the last layer
I was happy there was no big surprises under the last layer :D
#167 _2runa_
_2runa_
Posted 14 January 2009 - 02:49 PM
Well....its happening OK.. first of all in was to cold now its to hot 44deg. but i have to do something so i've started again
will post some pics as soon as i down load them. Im at work 6 days a wk from 6 to 6 how do you guys find the time?
#168 _2runa_
_2runa_
Posted 14 January 2009 - 11:47 PM
These pics are some of the surprises that I found when I striped the paint of the
beaver panel, notice the poor workmanship.
Who would do this to a Torana :<_<:
#169 Heath
  • 18,385 posts
Posted 15 January 2009 - 08:37 AM
lol at least it's made of metal and not glass. Even if it isn't properly welded in hehe
#170 _2runa_
_2runa_
Posted 15 January 2009 - 09:13 AM
I recon they have done the 3 sided cut, folded the flap back then tried to extract the dent which was unsuccessfull then tack welded it and coved it up with heaps of bog. I must be the only one who finds bodgy work like this. Shame A
#171 GML-31
Posted 15 January 2009 - 09:48 AM
I know its a pain while you are doing the repairs properly but after its finished you wont have anything to worry about, peace of mind is priceless...
#172 _2runa_
_2runa_
Posted 15 January 2009 - 07:36 PM
Just a pic to show that I did cut it out completely and it look great inside as well :spoton:
#173 _2runa_
_2runa_
Posted 15 January 2009 - 09:15 PM
I placed the new panel over the area that it was to be fitted too and further
marked the the exact area that i needed to cut. Could never of done it
without a willing donor :spoton:
#174 _gtr161s_
_gtr161s_
Posted 16 January 2009 - 07:02 AM
Does anyone know where to get the Kemtex flux for lead wiping from? I tried Bakers but I feel its to severe. And how do you neutralize it so it does't cause a corrosion problem?
I bought my kemtex thru B J Howes on the central coast nsw..they sourced thru a supplier in smithfield syd
unreal stuff for tinning but one thing i found was to make sure that every part of welded area is COMPLETELY dressed to bare metal or else the tinning wont take properly
#175 _2runa_
_2runa_
Posted 16 January 2009 - 07:41 AM
One of the things about using lead is your arms will know about it I use 80 grit as the final surface prep, then scub with a small wire brush and acid . Just prior to painting make sure you clean the area well after lead wiping :spoton:
love using it :D
