sprintmaster wheel nuts...
#1 _Skapinad_
Posted 01 September 2007 - 03:38 PM
I have seen a couple of sets available on ebay, but have asked the sellers if they would suit, and they are unsure... so Im reluctant to spend the cash only to find they dont fit.. has anyone bought some repros that are definately right ?? if so who from.. or can someone give me the exact dimensions etc. so i can have some made... thanks
Adam.
#2 _UFO XU1_
Posted 02 September 2007 - 09:07 PM
look for the find a member
type in brett cnc
he makes the repos for the self locaters, they fit but the chrome falls off when you tighten them up.
leave it up to you approx 100 smakers.
cheers UFO XU-1
#3 _Skapinad_
Posted 05 September 2007 - 05:49 PM
http://cgi.ebay.com....1QQcmdZViewItem
thanks,
Adam
#4 _Tangey_
Posted 05 September 2007 - 10:28 PM
The answer is none of the obove.
The ones you want have a more rounded dome top, I bought a set for $110.
I think it was from him??
They are identical to my original ones, haven't used them yet, hope the chrome stays on they are for the big sprinties.
I will try and get some pics.
#5 _OLD50L_
Posted 06 September 2007 - 03:35 PM
#6 _OLD50L_
Posted 06 September 2007 - 03:47 PM
#7 _Skapinad_
Posted 23 October 2008 - 10:51 AM
Posted 24 October 2008 - 01:28 PM
2 Sturt Reserve Rd
Murray Bridge SA 5253
(08) 8532 4977
This is the details on the set I and a couple of mates bought off ebay. Could very well be the brett cnc guy, I don't know.
Anyway he definately has the right ones: I've just used mine in putting the original sprinties on the car. The chrome didn't bugger up putting them on, but i was real careful as I had heard the chrome wasn't real flash and if it doesn't peel off the nuts will rust anyway?? They look fine at the moment tho' and you can always get them re-chromed I suppose. Cost around $100-120 from memory.
Cheers,
jpxu1
Edited by jpxu1, 24 October 2008 - 01:30 PM.
#9 _ck1971_
Posted 25 October 2008 - 05:46 AM
ck1971.
#10 _BATHURST-32D_
Posted 25 October 2008 - 06:00 AM
cheers john
#11 _Skapinad_
Posted 25 October 2008 - 01:54 PM
#12 _Skapinad_
Posted 29 October 2008 - 11:09 AM
#13 _ck1971_
Posted 30 October 2008 - 03:29 PM
ck1971.
#14 _Skapinad_
Posted 30 October 2008 - 05:12 PM
How do I post a picture?
ck1971.
you can just email it to me and ill chuck it up here also... thanks,
[email protected]
#15 _Skapinad_
Posted 09 November 2008 - 06:03 PM
Posted 22 November 2008 - 11:05 PM
Well that wasn't so hard after all
Cheers,
jpxu1
#17 _Skapinad_
Posted 23 November 2008 - 10:14 AM
pics.....I hope you can see enough detail in the pics as the repros are still in a sealed plastic bag and I don't want to open them.
The nuts are pretty much the same apart for the following differences:
1 the steel hex rod used to make the repros is better quality than the originals due to the fact that they make better steel these days. It's smoother with less pitting.
2 the flat on the end of the nut looks wider on the repros but it's not it's the radius of the curve that makes it look that way, see the pics to see what I mean. I think the difference is due to the originals being slightly linished prior to chroming and the repros were not. The easy fix would be have the repros linished.
which seems to agree with yours jpxu1...
I also found this drawing some time ago, think it may have been off an ebay ad, though I could be wrong... either way, the pics seem to confirm that this drawing is the correct dimensions... though it also shows a washer to be used for each one ?
Now all I have to do is find someone to make em for me !!
Thanks again for the help.
Adam
Posted 23 November 2008 - 11:00 AM
The repro wheel nuts come with washers but they are not needed unless your mags have suffered a casualty over the years.
CK would have got his repros from the same place as me - same sealed bag and if he looks there should be washers in there as well.
Cheers,
jpxu1
Edited by jpxu1, 23 November 2008 - 11:02 AM.
#19 _ck1971_
Posted 23 November 2008 - 06:47 PM
ck1971.
#20 _Skapinad_
Posted 23 November 2008 - 06:54 PM
#21
Posted 23 November 2008 - 11:30 PM
2 Sturt Reserve Rd
Ph (08) 8532 4977
Refer my post 24/10 ^^^^^^^
Cheers,
jpxu1
#22 _Skapinad_
Posted 24 November 2008 - 07:31 AM
