Lowering Tricks, Other Springs to use?
#51
Posted 07 June 2010 - 02:47 PM
#52
_SS Hatchback_
Posted 07 June 2010 - 10:19 PM
hahaha nice , although the amount of lowering can vary, depending on profile of tyres i believe
#53
_youngy_11_
Posted 08 June 2010 - 10:33 AM
#54
_arsnic_apple_
Posted 08 June 2010 - 11:25 PM
Wasnt quite the solution i was looking for but im sure that could work haha
#55
Posted 09 June 2010 - 01:52 PM
What about lovells springs apparantly they are good.
Never had a drama with Lovells,
Ray runs them in his XU-1 and I ran a set in my torry for a while too.
I need some new springs in the next couple months and will be going back to lovells, or custom wound to suit the height I want.
#56
Posted 15 September 2010 - 02:01 PM
I am probably going to go anothe 1/2-1 inch lower again(2-2.5 in total) and would like to know if I should get a different brand spring to get set at that height or if theres a way to make the pedders one seat in better. I also have the original front ones so I could always get them reset 2.5 inches lower than standard.
Anyone have any ideas on whats best???
Edited by Orange SS, 15 September 2010 - 02:07 PM.
#57
Posted 15 September 2010 - 02:12 PM
I kinda pushed it across hard with a pinch bar and the noise went away for a drive or three, but it returned and I just chucked a bit of sheet rubber between the two parts to temporarily shut them up. Don't know what I'm going to do in the long run.
Is that where yours touches?
#58
Posted 15 September 2010 - 02:20 PM
I just called up Pedders, and they have recommended some plastic coil wrap. I think this similar to the stuff also used to wrap hydraulic hoses on various pieces of machinery. Not sure how long this stuff would last though, but it is pretty tough plastic.
#59
Posted 15 September 2010 - 02:35 PM
Edited by Heath, 15 September 2010 - 02:36 PM.
#60
Posted 15 September 2010 - 02:39 PM
#61
Posted 15 September 2010 - 02:47 PM
#62
Posted 15 September 2010 - 02:59 PM
Its been a while since I put the springs in mine, but I don't remember having a rubber insulator for the rear springs? Something I will be checking. Are they needed? or just optional?
#63
Posted 15 September 2010 - 04:34 PM
Not a recall, a warranty fix if the owner complained.Interesting, rodomo mentioned a product something along the lines of that being used for a manufacturer's recall
#64
Posted 15 September 2010 - 07:08 PM
On the top only, I'm having trouble remembering now you've asked but I think it is needed to stop the spring from moving aroundI don't remember having a rubber insulator for the rear springs? Something I will be checking. Are they needed? or just optional?
#65
_arsnic_apple_
Posted 30 September 2010 - 04:06 PM
problem is they wont fit over where the spring is supposed to sit.
So like the circle at either end of the spring is too small to fit over.
Anyone else used pedders?
Blake
#66
Posted 30 September 2010 - 07:06 PM
Edited by Bomber Watson, 30 September 2010 - 07:07 PM.
#67
_arsnic_apple_
Posted 30 September 2010 - 10:23 PM
Did the job nicely, i'll upload some pics when i get it all cleaned up.
Blake
