Gday guys
Iv had my fuel sender unit in pieces for a while and cant quite remember how exacly the sender unit is wired, there is a flat wire on the inside of the unit which is attached to the outside, cant remember if there is some insulation along the line.
I could probably work it out but dont want to risk it as i dont want to blow my self up
Some pics of the fuel sender would be great
LJ Fuel Sender unit
Bart
, Nov 05 2007 04:07 PM
5 replies to this topic
Posted 05 November 2007 - 04:07 PM
Posted 06 November 2007 - 10:49 PM
Pics and description anyone?
Posted 08 November 2007 - 04:07 PM
Next question is, is th Kingswood fuel sender the same resistance as the LJ Tori? Will the Kingswood sender work?
#4 _jap-xu1_
Posted 10 November 2007 - 04:35 PM
i dont have pics but i can tell you that no lj sender will work with aftermarket gauges.
i put an aftermarket sender in mine
Posted 11 November 2007 - 12:48 PM
Thanks Jap, what i want to do is use the original LJ sender with original LJ gauge.i dont have pics but i can tell you that no lj sender will work with aftermarket gauges.
Unfortunately i havr taken the flat wire off the sender (the part which goes inside the tank and i want put that wire back in its correct way, im assuming its insulated from the metal top? But i want to confirm that with someone with pics or info.
In this pic it look as though the flat wire is insulated from the metal top. Is this correct?
#6 _Bomber Watson_
Posted 11 November 2007 - 01:07 PM
I dont think you will have to many problems with sparks either way.
Its only sending resisted negative signal to the gauge, no positive in the sender unit.
