Hiding the wiring
#26
_Eddie_
Posted 27 February 2008 - 11:50 PM
#27
_UNVSM8_
Posted 28 February 2008 - 04:52 PM
Ben
#28
_moot_
Posted 28 February 2008 - 05:31 PM
#29
Posted 28 February 2008 - 06:26 PM
Tim
#30
_Brewster_
Posted 28 February 2008 - 09:50 PM
#31
_Herne_
Posted 04 March 2008 - 11:12 AM
We have since drilled a fresh hole to run the wiring through and situated the large white drainage pipe back to its original location.
We have yet to water test it but it should be fine now.
Herne
#32
_j7723_
Posted 11 March 2008 - 08:31 AM
Jeremy
#33
Posted 11 March 2008 - 10:55 AM
I have beer in the fridge?
#34
_j7723_
Posted 11 March 2008 - 12:52 PM
ask heath if the girl with the mini can make it
#35
Posted 11 March 2008 - 01:24 PM
#36
_j7723_
Posted 18 April 2008 - 01:46 PM
#37
Posted 22 May 2008 - 10:13 AM
cheers!
#38
_j7723_
Posted 18 June 2008 - 02:59 PM
#39
Posted 18 June 2008 - 03:17 PM
Harden the f*ck up! LOLSorry I broke my shoulder about 5 weeks ago have had the ac joint pined 2 weeks ago as soon as I can I will be back at it
(I hope its not the beer drinking arm, that would be a tragedy!)
#40
Posted 18 June 2008 - 03:29 PM
The one thing i did find, was that in the end i had to run 2 cables to the front, both positive and negative to keep a good power supply.
I tucked mine up beside the rail underneath the car.
#41
_j7723_
Posted 19 June 2008 - 12:40 PM
LOL yes right arm and the drinking has been better more time of work to do itHarden the f*ck up! LOLSorry I broke my shoulder about 5 weeks ago have had the ac joint pined 2 weeks ago as soon as I can I will be back at it
and Im now harder have a rod in my arm would like to know if its polished
#42
_j7723_
Posted 07 January 2009 - 12:56 PM
#43
_Herne_
Posted 07 January 2009 - 01:20 PM
All worked well once we remembered to put the lead from the engine to earth on lol was hopeless before we did that
The wiring harness that ran along the passengers side of the engine now sits along the passengers rocker cover, I will get a photo of that later and we finally got around to tidying up the plug leads just prior to Nats.
Alan
Edited by Herne, 07 January 2009 - 01:22 PM.
#44
_Herne_
Posted 07 January 2009 - 01:43 PM
Perhaps not totally hidden but neat enough and well out of the way.
And this is all you can now see of the brake lines.
Herne
#45
_tomo123_
Posted 07 September 2009 - 07:12 PM
my wiring is hiden in a very similar way but i i couldn't find an efficient way of running the squirter hose.
those head light plugs you used where they brought from and auto parts shop or scavenged from another car?
#46
_Herne_
Posted 07 September 2009 - 07:48 PM
when you ran the hose for your window washer bottle, where did u run it to bring it back to the water squirters?
Hi Tomo
I will get a photo of the washer bottle lines tomorrow, right now I cant remember what we did to hide them if anything???
The headlight plugs were always a part of my car, they never changed just the way the wiring is run has changed.
Herne
#47
_j7723_
Posted 22 December 2009 - 12:38 PM
The new plugs for the light were bought new from battery World
#48
_Herne_
Posted 22 December 2009 - 12:42 PM
The washer line runs throw a hole just under the washer bottle then down under the xcross member bolts and back up the back of the motor
I dont remember us changing the plugs - there you go, we must have
Thanks for that Jeremy, I obviously forgot all about this thread and the question asked. sorry.
Herne
#49
_LS1 Hatch_
Posted 21 February 2011 - 07:58 AM
You can see I just added a couple of tangs to the inner guard area to support the wiring.
