![](https://secure.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e?s=100&d=https%3A%2F%2Fwww.gmh-torana.com.au%2Fforums%2Fpublic%2Fstyle_images%2Fblackstream%2Fprofile%2Fdefault_large.png)
Turbo Torana
#101
_gtr-xu1_
Posted 21 October 2008 - 01:20 PM
#102
_panthervs_
Posted 28 October 2008 - 09:30 PM
#103
_studricho_
Posted 28 October 2008 - 11:17 PM
#104
_gtr-xu1_
Posted 07 November 2008 - 12:36 PM
![Posted Image](https://cache.gmh-torana.com.au/i41.photobucket.com/albums/e271/bullarab/P1000534.jpg)
#105
Posted 08 November 2008 - 03:39 PM
#106
_mumstaxi_
Posted 09 November 2008 - 04:48 PM
http://au.youtube.co...h?v=cLWLbJccvUM
Sounds a bit loud with just a dump pipe (lol)
MT
#107
_gtr-xu1_
Posted 09 November 2008 - 05:06 PM
#108
_LJ_MAN_
Posted 09 November 2008 - 07:00 PM
panthervs: i mounted a VL v8 radiator on the engine side and my cooler on the front side and squeezed my thermo's in between, very tight but looks tidy and hidden.
#109
_tyre fryer_
Posted 09 November 2008 - 07:38 PM
Do you have any pics? it looks just like the way i want to my car to be.
sorry to hijack the thread...
#110
_gtr-xu1_
Posted 09 November 2008 - 10:34 PM
#111
_LJ_MAN_
Posted 11 November 2008 - 09:00 PM
GTR_XU1: ill get some new pics on the weekend. starting it for the 1st time in about 3weeks. just need injectors and some wiring, cant wait!!!!!
#112
_brett_32i_
Posted 12 November 2008 - 06:48 PM
are you just running the afm as a reference like the old grp c bluebirds used to do? otherwise it doesnt make sense. and if you are, then its not necessary to run an air filter, you could just mount the afm up under your glove box out of sight.
did you get your air box sorted out? pics?
#113
_mumstaxi_
Posted 12 November 2008 - 09:00 PM
![:blink:](http://www.gmh-torana.com.au/forums/public/style_emoticons/default/blink2.gif)
The turbo just blows air on the ground,and the engine runs naturally aspirated, drawing air through the plenum via the throttle body.
Ive just temporarily cable tied a pod filter over the throttle body, to stop any dirt getting sucked in when i drive the car on a test drive, the pipe work "from" the intercooler will join to the front of the throttle body (in place of the pod filter)
I dont need a AFM as i am running Microtech engine management that uses a MAP sensor for reference.
Filter box pic's......
All installed, still need a K&N (just running paper filter for now)
![Posted Image](https://cache.gmh-torana.com.au/i83.photobucket.com/albums/j320/02ard/Pictures198.jpg)
^^^ top left is small breather hose from oil catch can and the 35mm pipe going to air box (botton centre of pic) gets connected to the vent from the Blow Off Valve (so its not to atmosphere and legal)
![Posted Image](https://cache.gmh-torana.com.au/i83.photobucket.com/albums/j320/02ard/Pictures200.jpg)
Air Box is rubber mounted so it can move a bit under hard acceleration if it needs to, have opened up (cut) the forward area of the air box (left of pic) behind the headlight,just to get a little more cold air in.
Have not yet cut any holes in the old battery tray area yet ,untill i know where the intercooler pipes will sit.
MT
#114
_studricho_
Posted 12 November 2008 - 09:52 PM
#115
Posted 13 November 2008 - 08:42 AM
#116
_brett_32i_
Posted 13 November 2008 - 03:09 PM
#117
_mumstaxi_
Posted 13 November 2008 - 06:40 PM
Thanks Brett, i am a little surprised that everyone so far that has seen the air box seem to have liked it.airbox looks quite neat..
Yes it is a VT to VY (V6) Commodore air box, liked it for its 3.5 inch Dia mouth, and only cost about $50 new !Looks like VT-VX commodore.
![:clap:](http://www.gmh-torana.com.au/forums/public/style_emoticons/default/clap.gif)
MT
#118
_mumstaxi_
Posted 15 November 2008 - 02:37 PM
![:burnout:](http://www.gmh-torana.com.au/forums/public/style_emoticons/default/burnout.gif)
MT
#119
_studricho_
Posted 15 November 2008 - 11:20 PM
#120
_mumstaxi_
Posted 19 November 2008 - 01:20 PM
If you want to see them i put them in my "profile/about me page" as i have enough stuff clogging this thread already (Ha-ha)
![:D](http://www.gmh-torana.com.au/forums/public/style_emoticons/default/biggrin.gif)
MT
#121
_evil UC hatch_
Posted 06 December 2008 - 11:09 AM
#122
_mumstaxi_
Posted 06 December 2008 - 11:31 AM
Car is now registered and driveable
Quite a bit of tuning to do, and a few items that need minor attention, but happy with it all so far.
Boost gauge stopped working and Tacho had a bit of a hernia, but i hope the Diode i have got for it will fix that.
I will get some pic's of the cooler pipe work etc posted soon.
MT
#123
_evil UC hatch_
Posted 06 December 2008 - 11:34 AM
![:rockon:](http://www.gmh-torana.com.au/forums/public/style_emoticons/default/rockernana.gif)
there are always little bugs that need to be sorted out hey
#124
_mumstaxi_
Posted 06 December 2008 - 12:17 PM
after seeing the things you have for sale here are you still going ahead with this project, or were they surplus parts?
Yes, all the parts are what i have left over, the ENG is the first one i intended to use, the first idea was to get a "standard" RB30 Turbo in the car and going, then later on make it go fast, i got a bit carried away (can u tell ?) buying all sorts of stuff on the way (at one stage i had 4 intercoolers,3 RB sumps, 4 lots of RB ENG mounts
![:banghead:](http://www.gmh-torana.com.au/forums/public/style_emoticons/default/banghead.gif)
As i learned more and more i changed plans and went overbord a bit with yet another engine
![:rolleyes:](http://www.gmh-torana.com.au/forums/public/style_emoticons/default/rolleyes.gif)
I just wanted to keep everthing untill i had my car on the road incase i needed anything !
Now i want the space !
MT
#125
_studricho_
Posted 06 December 2008 - 03:22 PM
Yey!
Car is now registered and driveable, took it for a bit of a test drive, ended up driving around till midnight (LOL)
MT
I used the diode from a VL dash at it worked fine. You just need to make sure it's done the right way. Need a picture?
