Turbo Torana
#201 _waz355_
Posted 17 June 2009 - 10:48 PM
#202 _Big T_
Posted 18 June 2009 - 12:37 AM
Who are the new owners of Milton Performance?
#203 _mumstaxi_
Posted 18 June 2009 - 03:17 PM
About Milton Performace info...
http://www.gmh-toran...showtopic=37763
MT
#204 _mumstaxi_
Posted 27 June 2009 - 10:53 AM
This is the first time ive had to get the car towed, (cost me $130) so i suppose it was lucky it happend only a few K's away from home and not up at Ipswich.
For those that don't know what the inside of a Auto gearbox (Trimatic) looks like, this is the output shaft and gear case (with planet gears) as they would normally live inside the gearbox , the long shaft is the bit that protrudes from the back of the gearbox (Far Left of pic... Tail shaft connects to this spline)
Below is what mine looked like, snapped away clean (instant neutral,lol)
My auto guy said he suspected (due to varing dis-colouration) a stress fracture "may" have already existed contributing to the break, regardless of that, i guess its more than 10 years old ,and been living behind Turbo engines for most of its life (not to mention putting over 400HP through it) so i spose i can't complain tooooo much about the fragile little Traumatic having a hernia once in a while
While the box was apart it got up-graded with some new clutches/bearings etc so "hope" it will be trouble free again for a while, at least untill i can pay back the Credit card bill anyway !
MT
#205
Posted 27 June 2009 - 11:25 AM
#206 _UCV80_
Posted 27 June 2009 - 12:57 PM
#207 _mumstaxi_
Posted 27 June 2009 - 01:56 PM
I asked that question Heath, aparently a bearing runs either side of the area that snapped so can't be beefed up due to clearance issues.
He (auto guy) said no stronger performace bits are available to replace the bit that broke ,he did suggest i could maybe get custom bits made, started talking billet (big dollar) stuff so we thought just give it a go with a "newer" (newer as in less stressed) part ?
People say they can get tri's to handle up to 600HP (flywheel) so i assume they have to use the same part i broke ?, but as per Nathan's comment its NOT the HP as much as the Torque that breaks the gearbox.
HP alone will not be the only culprit, traction and load plus torque all play a big part in failures, i had a full tank of fuel +3 passengers and all the stuff i was taking to powercruise ,so the car was "heavy", the tyres did not spin (that i know of) and not sure how much torque, but id bet the RB makes more than a lot of V8s would, then slam it back to first and nail it doing 40Ks = Tow Truck
MT
#208
Posted 27 June 2009 - 06:14 PM
BuggerI asked that question Heath, aparently a bearing runs either side of the area that snapped so can't be beefed up due to clearance issues.
Well yeah it's obviously torque, and more importantly, the way that it is supplied lol. It's not gonna happen from rolling onto throttle, it'll be from slamming gears.People say they can get tri's to handle up to 600HP (flywheel) so i assume they have to use the same part i broke ?, but as per Nathan's comment its NOT the HP as much as the Torque that breaks the gearbox.
By the sounds of your history with the gearbox, a less exercised (newer) part should cope okay
#209 _UCV80_
Posted 27 June 2009 - 06:48 PM
#210 _mumstaxi_
Posted 28 June 2009 - 12:07 AM
So ill have to try and control myself a bit then
Yeh, at least thats what im gonna keep telling myself anyway
Yea its pretty disapointing, i dont know when ill get it back. they have to pull it out and thats a pretty big job and there not sure what the problem is. its a worry too as im used to doing everything myself. its weird somone else working on it. you probly have more torque then my stroker chev. hopefully your new shaft will hold up for another 10years.
I think its better if the auto place does the fit/removal ,very annoying if the box has ongoing "issues" and you have to remove/fit yourself (and buy fluid etc) each time, at least if it stuffs up, they will have to supply labour etc for free (well id hope they would)
MT
#211 _waz355_
Posted 28 June 2009 - 04:50 PM
I'm impressed your gearbox lasted as long as it has. Have you thought of trying another box like a glide or th350/400? I know its a pain in the ass as your car is set up for the trimatic, but it may be a good investment over time your engine is crunching out some serious power.
When are you back on the road??? I'm thinking of going to willowbank for the t and t this coming Saturday if your keen?
#212 _mumstaxi_
Posted 28 June 2009 - 05:35 PM
If my gearbox man would have said that no way is my box going to handle my driving, i would maybe have to look at a change to a different box.
For a lot of reasons i still like my tri for now, t350 is a bit to heavy, if i go glide its big dollars to get a box built from scratch, and may need to change diff gears to suit as the taller first gear will not be benificial with a big turbo, then add conversion bellhousing ......then id have to sell the car to pay for it all
Finished putting gearbox in 11.30 last night, seemed good today
Might be keen for willow, depends on how my drive friday night goes ?
MT
#213
Posted 28 June 2009 - 05:52 PM
#214 _mumstaxi_
Posted 08 July 2009 - 10:37 PM
Ran 11s all night (5 runs) with the best run a 11.4 @ 128MPH my best 60 foot was still only 2.041 but i did not have a traction problem off the line so could push a 1.9 yet ?
I would have been very happy with 11.9s running real street trim (on 185 wide tyres) so wrapped with 11.4s , still not reving out first gear tho due to the little tyres.
Should have some in car footage of one of the runs up when i get time.
MT
#215 _Big T_
Posted 08 July 2009 - 11:19 PM
Keep going like that and you will need a "sleeper" cage.
#216 _mumstaxi_
Posted 08 July 2009 - 11:55 PM
A quick look at the timeslip page http://www.gmh-toran...p?autocom=times and i can see ill have the second fastest "speed" across the finish line
Lucky the need to obtain a ANDRA licence/tech go off ET instead of terminal speed i guess.
MT
#217
Posted 09 July 2009 - 10:58 AM
#218 _mumstaxi_
Posted 09 July 2009 - 08:46 PM
I have not pushed the eng to see just how much i can get out of the RB , the Turbo is not running in its efficiency range yet and the fuel system is far from maxed out yet so i think it could make more HP without to much drama, i think the rest of the car will let me down if i push any more HP.
To be honest im more than happy with the way it goes now, ive way surpassed my goal of 11.9 @ 120 MPH running on 185s, and the engine behaves like a late model car, doesn't get hot in traffic and is good on fuel for a now 11 sec car.
Just need a paint job now !
MT
#219 _mumstaxi_
Posted 11 July 2009 - 11:17 AM
This run i had to back off due to slight sideways action ,you can hear the blow me off valve on closed throttle, but still ran a 11.9.
http://www.youtube.c...h?v=YfTNU-HCuJE
MT
#220 _waz355_
Posted 11 July 2009 - 05:14 PM
#221 _ass308_
Posted 11 July 2009 - 06:03 PM
#222 _mumstaxi_
Posted 12 July 2009 - 04:48 PM
Waz, i put the camera on a tripod ,2 tripod legs on the back floor ,1 leg on the rear seat, then put a occy strap around the front passenger seat (and the top of the tripod) to stop it from falling over.
If you look close at this pic borrowed from another forum, you can just see the camera through the LHF window (just above the seatline)
This mount is less than ideal, as the back rest part of the front seats can move/vibrate a fair bit making the images shake, i think it would work better if you could use another occy strap from a rear seatbelt to "pull" the seat backwards tight ?
MT
#223 _mumstaxi_
Posted 21 July 2009 - 09:36 AM
Was hoping to have my exhaust fixed up and get a new muffler on before this run (didn't happen,) , this muffler is about 10yrs old, so a new one may be even quieter without hurting HP i hope ?
Top gear (3sp Auto) rev to 7000rpm......
http://www.youtube.c...l/0/J_ngfXVb4oA
I will enter a pic of this dyno graph printout in the timeslip section.
MT
#224
Posted 21 July 2009 - 10:02 AM
With that MPH, you should be getting closer to 10's!!!! What tyres do you run in the drags? Please don't say those 13's LOL
#225 _mello92_
Posted 21 July 2009 - 04:32 PM
426hp in that UC! The ULTIMATE sleeper. I would love to see peoples faces when they get smooooked! hehe
