Oil pickup
30 replies to this topic
#26 _Bomber Watson_
Posted 23 May 2016 - 06:03 PM
This was 9 years ago.
I ended up doing nothing like the above, I actually just used a stock head with 3/4" cast steel weld el on it and a bit of pipe out the side.
Ta for the advice though :P
#27 _oldjohnno_
_oldjohnno_
Posted 23 May 2016 - 07:03 PM
Duh...
In my defence, I've had projects span more than 9 years..
#28 _Drag lc_
_Drag lc_
Posted 30 May 2016 - 04:17 AM
I've been running a -16 (1") hose on my red for years now works a treat..
#29 _duggan208_
_duggan208_
Posted 31 May 2016 - 01:22 AM
I've got to make mine as well. How close should I have the pick up to the bottom of the sump? I'm thinking about extending the windage tray over the pick up as well. Also shaping the bottom of the sump, under the pick up, into a X shape and have the magnetic sump plug in the center of the X, so that at an oil change all of the oil drains out and any fine particles of crap.
regards
#30 warrenm
warrenm
  • 2,117 posts
  • Car:1972 LJ Torana
Posted 31 May 2016 - 06:57 AM
regards
Keep the pickup to sump clearance about 10mm.
#31 _duggan208_
_duggan208_
Posted 31 May 2016 - 11:31 PM
Thanks mate.
regards
