Identification M20 and M21
43 replies to this topic
#26 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 31 May 2006 - 12:56 PM
Terry, you wouldnt have the numbers for the opel 4 speeds as well by any chance?
#27 Dr Terry
Dr Terry
  • 3,316 posts
Posted 31 May 2006 - 01:13 PM
Hi makka.
If by 'numbers' you mean gear ratios, AFAIK GM-H only used one version of the Opel 4-speed in Holdens. The Opel M20 was used in late HR, then HK/HT/HG & LC Torana up to 6/71, after that the existing stockpile was used in LC/LJ export cars.
The ratios are 3.43/2.16/1.37/1.00. These are rounded to 2 decimal places, some publications quote the ratios to 3 decimal places.
Dr Terry.
#28 antelopeslr5000
antelopeslr5000
  • 1,022 posts
  • Car:1977 LX SL/R 5000
Posted 02 June 2006 - 03:14 PM
And while you're on a roll with numbers Doc ... I don't suppose you would happen to have the numbers for this Saturday night's Lotto draw? ^_^
#29 _NOGEN 3_
_NOGEN 3_
Posted 19 November 2008 - 02:33 PM
triple post deleted-modem went haywire...
Edited by NOGEN 3, 19 November 2008 - 02:39 PM.
#30 _NOGEN 3_
_NOGEN 3_
deleted......
Edited by NOGEN 3, 19 November 2008 - 02:38 PM.
#31 _NOGEN 3_
_NOGEN 3_
Posted 19 November 2008 - 02:34 PM
Just wondering, with the ratios- 3.08diff/75km/h in 1st gear....would that be a M21 or M22 ratio?? I thought I'd scored a M21 (back in '92 in a LJ 2 door S- for $550, mind you) for my old LJ GTR, only to be told later, it was probably an M22 but looking at the ratios, this now dosen't seem to be the case?? Can anyone shed some light on this??? I want to replicate the old gearbox in the LC 2door....
Edited by NOGEN 3, 19 November 2008 - 02:37 PM.
#32 LX2DR
LX2DR
  • 1,763 posts
  • Name:Paul
Posted 19 November 2008 - 02:55 PM
Hi makka.
Dr Terry.
Pretty sure i'm correct in saying their were 2 types of Opel 4 speeds.
One had a tin pan on the bottom, Usually referered to as the weekest type.
One with a cast iron pan, usually refered to as the stronger one.
May have been the same box with a different pan and the benefit of strength might have been ridgidity with the cast pan?
Didnt really make that much difference, treat either hard and you will break it.
Edited by LX2DR, 19 November 2008 - 02:56 PM.
#33 rodomo
  • 18,028 posts
Posted 19 November 2008 - 04:50 PM
There was a difference in strength between the tin and cast bottom g/boxes.
Tin I could blow in 3rd gear, cast needed 2nd gear. :blink:
#34 yel327
  • 13,575 posts
Posted 19 November 2008 - 08:22 PM
75km/h in 1st with 3.08?
Assuming say 205/60/13 tyres, I have your tailshaft doing 2127rpm at 75km/h.
So with an M22 your engine would be doing 7954rpm.
M20 it'd be 6487rpm.
XU-1 M20 it'd be 5402rpm.
The box will probably not have been an M21 but 1st gear is the same ratio as XU-1 anyway.
My guess is you had an XU-1 box. You can buy new input shafts and clusters to make one of these out of a normal M20 quite cheaply.
#35 _NOGEN 3_
_NOGEN 3_
Posted 19 November 2008 - 10:07 PM
Yeah, thanks for that . I'm looking at the 899 cluster, input shaft and third gear, with a rebuild kit. There's a lot of metal in there....After reading about the M22 1st gear, I highly doubt it was one of them...With the condition the car was in that the box came out of, I doubt the car had a modded M20...
#36 yel327
  • 13,575 posts
Posted 20 November 2008 - 06:33 AM
All you need to turn an M20 into an XU-1 box is the input shaft and cluster, then they are identical (except for original markings, date codes etc). 3rd gear is the same. You can do almost the same thing with a V8 M21 box where you only need to change the input shaft using one off an XU-1 box (and 6cyl bearing cover). The M21 just has a shorter 3rd gear (1.38:1, XU-1 is 1.25:1).
Reece at Kingswood Country has the parts you need. I have some input shafts here (Newcastle) that I bought off him in bulk but no clusters.
#37 Dr Terry
Dr Terry
  • 3,316 posts
Posted 20 November 2008 - 12:01 PM
There were more than two versions of the Opel 4-speed used in Holdens, but they all had the same gear ratios.
You are correct about the pressed metal & cast iron bottom lids, but there were various types of shifter used also.
HR Opel gearboxes had the shifter attached to the rear of the extension housing, whereas the HK/T/G Holdens had the shifter mounted further back & attached to the floor. LC Toranas had theirs attached HR style, but not using the same parts, it was different yet again.
Dr Terry
#38 _NOGEN 3_
_NOGEN 3_
Posted 24 November 2008 - 03:51 PM
Cheers m8, cool. So, the xu-1 box just has a taller 1st and nothing else?
#39 yel327
  • 13,575 posts
Posted 25 November 2008 - 02:47 PM
No, all actual ratios are different to the normal M20. The only actual different parts are the input shaft and cluster. The different ratios come about because of the teeth count on the input shaft and cluster that meshes with it. The ratio is a function of the input shaft gear, the cluster gear it meshes with, the selected gear (ie 1st to 3rd) and the corresponding gear on the cluster. If you sit down and work it all out on paper it makes sense.
#40 _NOGEN 3_
_NOGEN 3_
Posted 25 November 2008 - 03:54 PM
Excellent, all sorted. Of course!- all drive goes throught the input shaft gear, thats how all the gear ratios are altered! (except the 1:1 4th gear, of course!)
Nightshift 6 nights a week makes me a dumbarse at times and all logic goes out the window...lol.
Cheers for the explanation. :)
Edited by NOGEN 3, 25 November 2008 - 03:57 PM.
#41 _glennhailstone_
_glennhailstone_
Posted 15 October 2014 - 07:45 AM
OMG
#42 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 15 October 2014 - 12:33 PM
while we're at it...anyone know how to identify between a celica and a supra box?
Celica has a cast iron case and Supra is alloy?
s
#43 craigcn27
craigcn27
  • 12 posts
  • Name:craig
  • Car:lc
Posted 13 October 2023 - 03:32 PM
Aussie 4 speed smooth case
D21 (2nd april 1971)
serial number:  T262306
#44 yel327
  • 13,575 posts
Posted 13 October 2023 - 04:55 PM
That could be a 3 or 4 speed case. Nice find.
