HX LE Wheels
12 replies to this topic
#1 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 09 January 2008 - 08:05 PM
I just found some wheels, which upon first glance look like HX LE 'Honeycomb' wheels. The centres, however, feel like they are made out of rubber, ie: it's a relatively soft material. Is this how they were made, or have I got some dodgy copies?
Tim
#2 Toranavista
Toranavista
    'Let There Be Rock' 1977
  • 2,862 posts
Posted 09 January 2008 - 08:12 PM
Thats how they are. The honeycomb is rubberised. Perhaps a rubber coating to the alloy.
#3 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
Posted 09 January 2008 - 08:48 PM
Sweeeet. Dad said the same thing, there's a rubber coating on the alloy.
Tim
#4 contessa5000
contessa5000
  • 66 posts
  • Car:1975 Casino Blue LH SLR500,1976 LE Monaro,2014 HSV GTS
Posted 09 January 2008 - 09:22 PM
Should be a steel rim, with like a rubber hubcap stuck to it [vulcanised].Hard to get balanced these days as most shops use a cone through the centre bore when fitting to the balancer and think it's alloy, but as it's rubber it gets a wobble up and cracks through the webbing.Took mine off my LE as I was unable to find a shop in my area with a balancer that uses the wheel studs for fitment,or did on car balancing.
#5 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
Posted 09 January 2008 - 11:34 PM
Yeah, it's a steel rim. I'll chuck some pics up tomorrow.
Tim
#6 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
Posted 10 January 2008 - 12:36 PM
There they be. Apparently they were found on 4 door Monaro's aswell, but in silver instead of gold. Can anyone confirm?
Tim
#7 Dr Terry
Dr Terry
  • 3,325 posts
Posted 10 January 2008 - 03:19 PM
Hi Tim.
The 7" Polycast wheel (in silver) was an option for all HJ, HX & HZ Holdens, not just Monaros.
The only Holden they were fitted as standard to was the HX LE (in gold).
Dr Terry.
#8 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
Posted 10 January 2008 - 03:22 PM
Oh, news to me. Cheers for that Terry, I thought they were HX LE exclusive :banghead:
Tim
#9 _torana_
_torana_
Posted 10 January 2008 - 03:28 PM
i can confirm
that they are ugly wheels.
cheers julian
#10 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
Posted 10 January 2008 - 05:02 PM
We established this a long time ago Julian :P
Tim
#11 CYCO355
CYCO355
  • 152 posts
  • Name:Cameron
  • Car:G PAK and a LH sl, VS Senator, VE SSV sedan
Posted 03 April 2018 - 03:16 PM
It’s an oldie but found this while trying to find some info on these rims.
Has anyone removed the the honeycomb material off of the rim?
I’m lead to believe that they’re a gts rim with the honeycomb moulded onto them?
Edited by CYCO355, 03 April 2018 - 03:17 PM.
#12 arrimar
arrimar
  • 3,134 posts
Posted 03 April 2018 - 03:43 PM
Two different things.
GTS is a steel pressed rim.
LE wheels are cast.
#13 CYCO355
CYCO355
  • 152 posts
  • Name:Cameron
Posted 03 April 2018 - 04:11 PM
I wouldn’t of thought a cast rim would have surface rust?
