Thermo fans
#26
_devilsadvocate_
Posted 28 February 2006 - 05:45 PM
Not a fan of switches in the radiator, Ive got whats probably known as the Chev rad in my car with the switch screwed into the top tank. It stopped working about 12 years ago, now it just leaks out the end of it. Im not going to replace it with another one of the same design that will probably not last either. I dont think its a good place to have the switch either, it relies on a good level of water in the top tank(if youve got a leak which drops the water level below it, the fans wont turn on. Think they are much better off in the bottom of the tank, not that im sure you can fit them down there, though the switch needs to be of a lower temp on the other side of the rad, it also eliminates the needless switching on of the fans after short stops where heat soak finds its into the top tank of the rad.
#27
_draglc_
Posted 03 March 2006 - 12:32 PM
I got them from N&M spares at northgate, the packet is labelled Auto Transmission Cooler Mounting Kit, made by TRIDON. $9.70 per kit(4 of them). Going to make mounting my 2 10" thermos very easy. Part no is HK210.
A lot easier than making up brackets.
A1
#28
Posted 04 March 2006 - 03:47 PM
iv got two 10in thermos fans and a reco 4 core HQ radiator.
Now will the two 10in thermos keep my 355 cool or should i get two 12in??
danny....
#29
_Keithy's_UC_
Posted 05 March 2006 - 10:42 AM
I fitted my Twin 10" thermo fans yesterday to my UC and they work fine! The fans come with everything required to mount (provided they both fit over your radiator - in my case they were an exact fit to my radiator).
I tested them at every stage of fitting, then fitted a toggle switch from which i can turn them on and off how i please! That is how i wanted to do it btw!
I will upload photos directly of my setup - easy to do!!
Keith
#30
Posted 05 March 2006 - 11:33 AM
Grant..
#31
_devilsadvocate_
Posted 05 March 2006 - 01:45 PM
This is a six with a 4row radiator?Hi everyone
danny....
#32
Posted 05 March 2006 - 03:04 PM
danny...
#33
_devilsadvocate_
Posted 05 March 2006 - 04:12 PM
B4 you commit, take the car for a drive without any fans on a warm day?
If the engine will stay under thermostat temp at ambients of 35C+ at >80kmh then you should be fine with electric fans, if not engine fan would be more suitable.
Edited by devilsadvocate, 05 March 2006 - 04:25 PM.
#34
_Yella SLuR_
Posted 06 March 2006 - 02:19 PM
Also, just rewired my relay from constant power to the ignition circuit. I strongly recommend this. Having fans running with heat soak and no water flowing only seems to kill the battery, and also blows hot air off the extractors onto the solenoid making it cranky as well. Had no problems all weekend with battery after making this change.
It is much easier to wire to constant power though, but don't be tempted.
Edited by Yella SLuR, 06 March 2006 - 02:19 PM.
#35
_devilsadvocate_
Posted 06 March 2006 - 03:11 PM
#36
_Yella SLuR_
Posted 06 March 2006 - 03:32 PM
If that fails, I'll ring Struggler and we'll hit the dyno together. Unfortunately I'm still not supposed to be playing cars ATM (Still on Castle Duties), so just tinkering whenever I get a few spare moments. Poor old car is a bit neglected at the moment.
I hate nothing more than a misbehaving car, like to get em as reliable and bullet proof as I can.
#37
_Keithy's_UC_
Posted 07 March 2006 - 12:05 AM
#38
_devilsadvocate_
Posted 07 March 2006 - 03:51 AM
Interesting you decided to fit them on the outside?
Many will tell you they are more efficient as pullers rather than pushers.....yet not convinced myself.......it appears to be a bit of heresay that has become fact........never seen one bit of evidence to support it...........more inclined to believe it depends on whether the fan has been designed for pushing or pulling in terms of rpm/blade pitch........the same fan cant work equally well from both sides.
Anyway, at least you can run your engine fan(or refit it quickly) if they dont do the job well enough and should last a lot longer being on the front as they will run at ambient temp rather than the temp it comes out behind the radiator, 85C+ when the fans are working. Ive had the bearings cark it on three occasions in Dcraig fans(early 12in design) that have been mounted behind rad, the last one I didnt get to quickly enough and totally seized and burnt out the windings.....................
Hope they go well for you.........when are you going to get rid of the sunbudgie grille?
#39
_Keithy's_UC_
Posted 07 March 2006 - 05:03 PM
Davies Craig states that these fans are more efficient if placed outside the engine bay, and have therefore set the fans up to be used on the outside rather than the inside...
The temp of my motor sitting at traffic lights or driving never gets over 85 degrees (i dont run them until lower speeds or when i am about to stop at lights). With the belt driven fan, i saw temps over 100degrees celcius.
My grille is off a UC Torana (UC's came out with the same grille no matter what the badge, some chrome, some silver and black).
NOTE: Bolts have since been cut and sprayed black to match radiator, thermo fan wiring has been covered with insulation ducting and re-routed.
Keith
#40
_devilsadvocate_
Posted 07 March 2006 - 10:17 PM
Re the grille, satin grille was a sunbird feature, Torana SL's got the chrome grille-not sure about Torana S, possibly many toranas running around with the satin number(from small collisions) as I believe all replacement grilles were satin.
#41
Posted 08 March 2006 - 05:16 AM
#42
Posted 08 March 2006 - 09:06 AM
Keith said
"Davies Craig states that these fans are more efficient if placed outside the engine bay, and have therefore set the fans up to be used on the outside rather than the inside..."
I think the above advice is is intended to extend the life of the fan motors against engine heat, rather than them being more 'efficient'.
It's funny that nearly all car manufacturers place there electric fan behind the radiator as 'pullers'.
Dr Terry.
#43
_Yella SLuR_
Posted 08 March 2006 - 10:56 AM
I used the plastic radiator clips hoping they won't be as severe on the tubes as steel bolts, but probably will. Longer term I want to make up a steel frame to sit behind the radiator to take the fans, so no radiator penetrations.
Edited by Yella SLuR, 08 March 2006 - 10:59 AM.
#44
_Herne_
Posted 08 March 2006 - 11:11 AM
Herne
#45
_devilsadvocate_
Posted 08 March 2006 - 11:12 AM
What DC claim and what is reality can be a little skewed as you suspect.
On a warm 30+ day, temps exiting the radiator will be 90C+ when the fans are being used. On average,about a 60C difference, this will create a corresponding density change in the air, it will be ~20% less dense on the engine side(the same fan would spin faster on the engine side). So from that variable alone(Im sure its all much more complicated than just this-enter aerodynamic factors ), the fan(pitch and rpm of motor) would have to be designed differently for optimum performance in different air temps.
Edited by devilsadvocate, 08 March 2006 - 11:16 AM.
#46
_Yella SLuR_
Posted 08 March 2006 - 12:30 PM
#47
_Herne_
Posted 08 March 2006 - 12:49 PM
hehhehee
Herne
#48
_devilsadvocate_
Posted 08 March 2006 - 12:54 PM
#49
Posted 08 March 2006 - 12:59 PM
---> doors that way!
#50
_Yella SLuR_
Posted 08 March 2006 - 01:02 PM
Come on mate ^ you serious?I suspect that too Dr Terry, as ive had to replace bearings numerous times in DC fans that have been mounted on engine side.
