LH-LX colour wiring diagram needed
35 replies to this topic
#26 _lxsl308_
_lxsl308_
Posted 05 February 2013 - 09:01 PM
Try this.
that is great quality and easy to follow does a diagram for LX exist im trying to work out a few wires in the engine bay loom
#27 Marks LXTorana
Marks LXTorana
  • 158 posts
  • Name:Mark Grovenor
  • Car:LX Torana
Posted 12 September 2013 - 04:32 PM
Does anyone have the high definition colour wiring diagram for SLR (optional instuments)?
#28 _Turk32_
_Turk32_
Posted 23 October 2013 - 02:19 PM
thanks guys the wiring diagram was a treat took all day to re do wiring in the tory but all done.
#29 _LONA-CK_
_LONA-CK_
Posted 25 October 2013 - 06:08 AM
#30 _abtorana_
_abtorana_
Posted 25 October 2013 - 03:49 PM
gday all
how do i get a copy of these??
i have 1 which is sheet 1 i think, has page no 12-41 at the top
same as the pdf 1 posted
regards adam
Edited by abtorana, 25 October 2013 - 03:54 PM.
#31 micklx
micklx
  • 1,785 posts
Posted 10 May 2014 - 02:58 PM
Does anyone have a wiring diagram showing LX dimmer switch wiring?
The microswitch on the blinker stalk has 3 terminals but I only seem to have 2 wires (and no lo beam)
#32 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 10 May 2014 - 05:14 PM
Only two wires on the column dipper switch.
Item 11 on the attached diagram.
Attached File  LX Wiring Diagram.jpg   142.77K   39 downloads
#33 rodomo
  • 18,038 posts
Posted 10 May 2014 - 06:02 PM
Have a read here Mick: http://www.gmh-toran...eadlight-relay/
The LX headlight relay is a bit weird, not like your normal relay.
#34 notna
notna
  • 706 posts
  • Name:Reverse of username
  • Car:1976 LX L32 SL/R
Posted 25 March 2015 - 02:37 PM
Thanks all for the diagrams in this post. Just what I needed to finish connecting up my spaghetti wiring :)
#35 hanra
  • 10,972 posts
Posted 25 March 2015 - 03:10 PM
Did you figure out that pink wire issue?
#36 EunUCh
EunUCh
  • 2,769 posts
  • Car:japos
Posted 25 March 2015 - 04:09 PM
Attached File  rly.JPG   84.86K   3 downloads
The LX relay was quite simple,the lever from solenoid would push down on the left hand leaf spring causing the right hand leaf spring
which had the contacts to move left leaving the "V" of the right hand leaf spring more or less in line with the lever from the solenoid,when the solenoid was energized again the lever would push the right hand leaf spring with the contacts to the right and the left hand leaf spring and it's "V" would move right ready for the next cycle over and over,it simply flip flopped the right hand leaf with the contacts to
high/low contacts within.
Believe or not i have heard that some Volvo's used a very similar light relay ?
Edited by EunUCh, 25 March 2015 - 04:12 PM.
