Double Diaphram Brake Booster
31 replies to this topic
#26 dattoman
  • 16,485 posts
Posted 17 February 2008 - 02:48 PM
Rory
Where are you getting this 12mm master cylinder depth from ?
Are you sure that cylinder of yours says P6615 not P6613 and your eyes are going ?
#27 _rorym_
Posted 17 February 2008 - 02:55 PM
Yaeh cant work that one out as well...when I just redid it it was 40mm in the rod hole on the M/C to the body with the new tip on it.....less 15mm to the bolt up face makes 25mm....Only thing I can think of is the small nut style head on the rod end wasnt allowing the end to go right into the M/C cavity.
Edited by rorym, 17 February 2008 - 02:56 PM.
#28 _rorym_
Posted 17 February 2008 - 03:04 PM
Definately a P6615 and the booster was originally a VH305 if that helps.So whats a VH-305 off?
Edited by rorym, 17 February 2008 - 03:09 PM.
#29 dattoman
  • 16,485 posts
Posted 17 February 2008 - 03:11 PM
Lets guess and say
A Torana
#30 _rorym_
Posted 17 February 2008 - 03:12 PM
You funny man!..DT looking..what you reckon Terry?
#31 _rorym_
Posted 17 February 2008 - 03:17 PM
Just re -read it worked out what I meant...it was sticking out from the bolt up face 12mm...I wasnt reffering to M/C depth. Anyway all is good..150mm to face...25mm into M/C..less reaction disc.
Edited by rorym, 17 February 2008 - 03:18 PM.
#32 _rorym_
Posted 22 February 2008 - 02:55 PM
Reaction disc was $4 and about 5mm thick....thicker than I thought...All done now. :D
