Fitting Performance Hei Coils
4 replies to this topic
#1 _tyre fryer_
_tyre fryer_
Posted 19 February 2008 - 04:17 PM
I bought this proform HEI coil from the speedshop and went to hook it up to my red 6 when I realised I have absolutely no clue how to do it.
It can't fully replace the bosch coil as it has nothing for the distributor lead to connect to.
I thought I'd put some pics up for you guys to see if you can work it out....
thanks guys :D
#2 _tyre fryer_
_tyre fryer_
Posted 19 February 2008 - 07:01 PM
*BUMP*
does anyone have a clue?
#3 TerrA LX
Posted 19 February 2008 - 07:54 PM
get a refund and leave the old coil on or if it is stuffed buy a new one.
#4 _CHOPPER_
_CHOPPER_
Posted 19 February 2008 - 07:55 PM
Bumped after less than 3 hours? Not all 3000+ members check every thread that often. I can't get the images to display for some reason, which is why I can't help ATM.
#5 Dangerous
Dangerous
  • 948 posts
Posted 19 February 2008 - 08:37 PM
Unless you're running crazy cam or compression, stick with the stock GMH coil - it's good enough to do the job.
