HG Carb Question
#1 _rorym_
Posted 11 February 2006 - 09:19 PM
#2 _Yella SLuR_
Posted 11 February 2006 - 09:25 PM
Posted 11 February 2006 - 09:26 PM
179 X2 had twin strommies as did 186 X2 before they switched to WW Stromberg 2 barrel and called it the 186S.
Posted 11 February 2006 - 09:27 PM
X2 went to 186S in the early HR's?If it is X2 carbs it should be a pair of 149 carbs..is there anything specific you want to know? all my books are still packed..might have to rely on memory..heaven forbid!
Posted 11 February 2006 - 09:29 PM
#6 _rorym_
Posted 11 February 2006 - 10:21 PM
Posted 11 February 2006 - 10:41 PM
Posted 11 February 2006 - 11:44 PM
Posted 11 February 2006 - 11:46 PM
Posted 12 February 2006 - 09:41 AM
Please try to post in the right section guys.
Thanks.
Tiny.
#11 _purpleLC_
Posted 12 February 2006 - 09:54 AM
They are found directly below the reinforcing bar which is screwed
down on the top of the bowl.
The numbers should start with 23-****
Louie
#12 _CHOPPER_
Posted 12 February 2006 - 12:49 PM
Posted 12 February 2006 - 02:09 PM
Posted 12 February 2006 - 02:36 PM
HR 186 X2 (twin BX Bendix-Strombergs) became the 186 S (single WW Bendix-Stromberg) on June 19th 1967 at the same time as the intro of the 4-speed Opel gearbox option.
This would make it late HR.
Dr Terry
#15 _rorym_
Posted 12 February 2006 - 02:42 PM
Louie, carbs are 2376050 on a HOLDEN manifold.
#16 _CHOPPER_
Posted 12 February 2006 - 03:32 PM
#17 _purpleLC_
Posted 12 February 2006 - 04:37 PM
The numbers are facing the radiator, 23-****
not the number in the circle.
By the looks of you photo on the front carb where your brake booster
hose is.
Louie
#18 _lexa_
Posted 12 February 2006 - 05:18 PM
#19 _rorym_
Posted 12 February 2006 - 05:59 PM
Email me and I will send some on. [email protected]
Louie,
Back carb is 2376068 and 3/32
front is 2376068 and 5/32
That make sense?
Edited by rorym, 12 February 2006 - 06:00 PM.
#20 _purpleLC_
Posted 12 February 2006 - 07:21 PM
2 screws at the front of the fuel bowl,
directly below that looking from the radiator (almost underneath that plate)
will be some numbers starting with 23-3***,
NOT 2376068 thats a casting number.
There will be more than likely dirt and grease, its hard to see but not impossible.
By the looks of it there are 2 different size carbys on it.
Louie
#21 _rorym_
Posted 12 February 2006 - 08:41 PM
#22 _rorym_
Posted 12 February 2006 - 08:52 PM
No numbers here
Edited by rorym, 12 February 2006 - 09:06 PM.
#23
Posted 12 February 2006 - 09:15 PM
#24 _purpleLC_
Posted 12 February 2006 - 09:43 PM
It is either under that plate or just on the upper part ofNo numbers on the float bowl, If I remove the reinforcincing bar and clean it will I see them?
No numbers here
where the centre body meets the top of the carby-
where you have cleaned at top you might have to look
real hard, sometimes they are not stamped real good.
Just to the right of that casting seam.
Louie
#25 _big chris_
Posted 12 February 2006 - 10:11 PM
Have a look at the numbers on the throat of the carby,
behind the bolt and nut that holds it onto the manifold,
The numbers should be the same,
If there are different,
the carbs will be nearly impossible to get to run well,
need a matching pair of carbs,
with matching jets,
then it will go well.
Chris.
