Concrete Barriers V Tyre Barriers
#26
Posted 27 February 2008 - 07:09 AM
_JBM_
Posted 27 February 2008 - 09:04 AM
Arent Nascars built from the cage out (re Days of Thunder?). V8s start with a shell and build the cage into it.There was talk in the Melb. Herald-Sun today of re-designing the cars. Apparently the Nascars are all the same under the "skins" and that�s what they are hinting at.
As I posted early a Nascar style car would allow other manufacturers to get involved and make it a bit more interesting and allow Mitsubishi and Toyota to gain sales from racing success.
James
#28
Posted 27 February 2008 - 12:40 PM
And the shell.So are V8 Supercars now...only diff is the Ford or Holden engines.
_CHOPPER_
Posted 27 February 2008 - 12:41 PM
#30
Posted 27 February 2008 - 03:02 PM
_HatchmanSS76_
Posted 27 February 2008 - 06:49 PM
Going back to the VT VX model race cars the rear wing was different and Holdens had the gurney flap on theirs which was rumored to give them the good grip/drive out of the turns that the other make didn't have at the time.
#32
_scalpa1_
Posted 27 February 2008 - 07:23 PM
#33
Posted 29 February 2008 - 02:43 PM
Posted 29 February 2008 - 03:52 PM
I wouldn't like the track layout to be changed, but I think a barrier system that absorbs energy without bouncing the car back onto the track should be implemented at T8.
#35
_82911_
Posted 29 February 2008 - 05:54 PM
I don't really have an opinion on this crash, except to say that "motor racing is dangerous" at any level, at these elevated levels of risk the cosequences can sometimes be tragic.
Evertime this happens and my kids look to me for an explanation as to what happened to cause this crash, i get closer to hanging up the helmet.
tragic, just tragic for all involved.
#36
Posted 07 March 2008 - 03:30 PM
#37
_pallbag_
Posted 07 March 2008 - 06:45 PM
Ask Ayrton Senna the same question !!!!
#38
_Baronvonrort_
Posted 07 March 2008 - 08:30 PM
The autopsy of Senna showed he would have lived if he didnt get that puncture wound in his head from suspension piece.I like the reference between the V8's being unsafe as far as race cars go, seeing they are based on Holden and Ford everyday cars. But then they said the purpose built Indy and F1 cars are safer
The F1 cars did not get real serious about safety till Senna and Ratzenberger died at Imola on the same weekend with Rubens also having a big crash in qualifying with Wendlinger being seriously injured in the next race.
I have seen some results of crash testing the F1 cars and what impressed me is the 55g limit and how the graph shows it does not go over yet remains just under.
Courtney crashed a Jag F1 at Monza when suspension failed and peak g's were 53!
So basically when you design a car from scratch (F1) it is easier to implement things into design and far more difficult when converting a road car.
The V8 are not allowed to extend cage beyond pick up points in suspension to give a crumple zone.
Anyone see Kubicas crash in F1 last year and he almost went head on into concrete wall at high speed and lived,biggest recent impact in F1.
Modern design is all about controlling impact distance and time hence g forces.
90 Kph - 0 in 0.5 metre= 65 g's and fatal
100 Kph- 0 in 1 metre = 20 g's approx and very survivable if fit and healthy not good for pensioners with osteoporosis.
How far did David Hookes fall and die from head injury?
Motor racing is dangerous,always has been always will be.
#39
Posted 22 August 2014 - 02:38 PM
And here is what happened to Ayrton Senna:-
Very Sad and F1 is no good for Bathurst.
#40
Posted 23 August 2014 - 08:40 AM
Not much room on that corner when they come so close to the wall to maximize the race line but a simple cheap solution would
be to use water barrels against the wall,the barrels can be set up like a damper with holes in them that allow the fluid to escape
under force when hit,might mean moving the wall as well to keep same line or just place the barrels on existing track.
#41
Posted 23 August 2014 - 11:29 PM
Yes it did happen pretty quickly UC,
and the reasoning behind this thread about - Concrete Barriers V Tyre Barriers
they said a suspension part speared Ayrton's head,
so Concrete is bad.
#42
_outer control_
Posted 21 September 2014 - 10:04 AM
Fire a bullet into water and it splatters like hitting a concrete wall
#43
Posted 21 September 2014 - 06:16 PM
Concrete verses rubber,both will have their good and bad points depending on where the barrier is set,water barrels or similar devices will
have the same attributes,problem with water is that it does not compress hence the need for holes in the devise to allow the water to escape
on impact in order to soak up some of the impacting force and act like a 'shock absorber'... a bit like the damper on a car...only bigger.
#44
Posted 21 September 2014 - 06:41 PM
Water is expensive now.
They use car tyres these days, which must be the cheaper option for concrete wall/bank/public area safety,
and see wide open spaces used, with the long straights cut down.
So the need for speed is changing to the best time a lap is done, although the Top speed is still quite high ( 360kph ).
seen tyres flying everywhere on the last race, which could hit something
#45
_Skapinad_
Posted 21 September 2014 - 07:21 PM
#46
Posted 21 September 2014 - 07:48 PM
I've begun reading all of Daves posts that i click to view as if they were a hip hop song.
Imagine it to a basic 8 bar beat like this one:
https://www.youtube....h?v=lJvZ2BROtSU
And put his last like this.....
#47
_Skapinad_
Posted 21 September 2014 - 07:51 PM
#48
Posted 21 September 2014 - 08:00 PM
Tomorrow mate...Tomorrow....
#49
Posted 21 September 2014 - 08:58 PM
This is why i never take holidays.
Im so bored i decided to make a vid demonstrating how i would rap one of Daves posts.
Posted 21 September 2014 - 09:04 PM
That is out there DJ,
Great Man.
A Like Button for You Bud
