Darn Extractors Wont Fit "pacemakers"
22 replies to this topic
#1 _uglybob_
_uglybob_
Posted 04 March 2008 - 05:53 PM
hey guys went to hang my new pacemakers yesterday and found two things, one that they dont clear my new sump which is stupid but my fault should have checked earlier can just get a spacer its only a couple of mm. the second more worrying problem is that the collectors point directly at the box i cant even get the Y piece on to joint them together.
has anyone else had any problems like this? i am running a celica box but i cant see how running a celica or the m21 would make any difference in this case. is anyone else runnign these pipes with a celica box?
i did call up the exhaust shop they got onto pacemaker and they apparantly want to send someone out to have a look at it themselves and issue a new set if neccessary.
anyhow any feedback appreciated as always.
Ben
#2 _uglybob_
_uglybob_
Posted 04 March 2008 - 06:05 PM
Its a 202 by the way in my LC...
#3 _73LJWhiteSL_
_73LJWhiteSL_
Posted 04 March 2008 - 06:08 PM
I have pacemakers on my LJ, and don't have any clearence issues.
Steve
#4 _Mr Magoo_
_Mr Magoo_
Posted 04 March 2008 - 06:15 PM
Hi Ben,
I just fitted the pacemaker extractors with the gold coloured Y piece and they went in no problems. they clear the box easily.
I will find out tomorrow what type they are because they still have the part number stickers on them
#5 _CHOPPER_
_CHOPPER_
Posted 04 March 2008 - 08:44 PM
I had the same problem when I went from a 202/M20 to 202/Celica steel case. Nothing an oxy couldn't fix at the local exhausst place
#6 _uglybob_
_uglybob_
Posted 04 March 2008 - 09:23 PM
dammit, o well i guess ill have to do the same thing, the celica must just sit lower does it? cheers guys anyway. i think the main priblem is now going to be the sump. will just hav to pull the engine and cut the sump down.
#7 _smcbr6_
_smcbr6_
Posted 04 March 2008 - 09:33 PM
202, celica box and pacemakers in my LC. After refitting once they did just hit the corner of the box. Just loosened them off, pushed them around a bit, tightened back up and no problem - although clearance isn't much.
#8 _73LJWhiteSL_
_73LJWhiteSL_
Posted 05 March 2008 - 09:59 AM
I did have to get the exhaust modifed under the box when i put the Celica in... it was fine with the m20 tho, didn't hit the sump either.
Steve
#9 _uglybob_
_uglybob_
Posted 05 March 2008 - 05:38 PM
no dramas guys i guess i might hav to do some chopping i didnt think the celica box would change much but it obviously does shouldnt be to much of a drama. the biggest problem i hav still is the interference with sump.
o well
#10 _uglybob_
_uglybob_
Posted 05 March 2008 - 06:03 PM
Who has got a big sump on their little red motor? what sort of extractors have you used to clear them?
currently running the two piece comp pacemakers PH 5027 (just thought i would clarify that) r they the ones u are using mr magoo?
#11 _Mr Magoo_
_Mr Magoo_
Posted 05 March 2008 - 07:32 PM
yep PH 5027 TDR
#12 _uglybob_
_uglybob_
Posted 05 March 2008 - 07:35 PM
dinkum. would it be possible to get a photo from under the car where it collects? what box hav u got in it?
#13 _CHOPPER_
_CHOPPER_
Posted 05 March 2008 - 08:48 PM
What do you mean by a big sump?
#14 _uglybob_
_uglybob_
Posted 05 March 2008 - 11:07 PM
a big one like this one..
#15 _CHOPPER_
_CHOPPER_
Posted 05 March 2008 - 11:44 PM
Now for the next question, what's with the brass fittings on the oil pump?
#16 _uglybob_
_uglybob_
Posted 06 March 2008 - 06:52 PM
in and out
#17 _CHOPPER_
_CHOPPER_
Posted 06 March 2008 - 10:55 PM
In and out to a remote filter?
#18 _uglybob_
_uglybob_
Posted 07 March 2008 - 06:03 PM
yep
#19 _CHOPPER_
_CHOPPER_
Posted 07 March 2008 - 08:54 PM
Got some pics of the setup?
#20 _uglybob_
_uglybob_
Posted 08 March 2008 - 07:54 PM
here ya go chop
#21 _CHOPPER_
_CHOPPER_
Posted 08 March 2008 - 10:28 PM
Interesting...
#22 _Brewster_
_Brewster_
Posted 09 March 2008 - 09:48 AM
strewth! what is the accumulator for?
#23 _uglybob_
_uglybob_
Posted 09 March 2008 - 01:04 PM
what an accumulator is usually used for, make up for loss of pressure at any given time.
theres stuff everywhere but i didnt really know how to make it neater, i was trying to get some pictures from some guys that have already done it to get some ideas but no one wanted too and i got lazy coz i just want it to be driving. its just to get around using the sstandard galleries in the block obviously, its not as complicated as it looks.
just gonna get that sump cut up anyway prolly take 5mm out of the pan on the passenger side. then they will fit.
ben
