HEI Distributor - s/b chev in LH
2 replies to this topic
#1 _LH350_
_LH350_
Posted 13 February 2006 - 04:07 PM
Guys,
the new small block is in the car sitting on castlemaine rod shop engine mounts, but the HEI dizzy that came with the engine won't bloody fit.
Has anyone dealt with this before?
Are their smaller electronic distributors or do I have to chase down an old points variety?
#2 LXCHEV
LXCHEV
  • 3,537 posts
  • Car:'76 LX - 383 Chev
Posted 13 February 2006 - 04:27 PM
Which HEI dizzy do you have? Is it the huge one with the coil built-in to the cap? At a minimum, you will have to trim the firewall lip to gain some clearance. I used to run the huge dizzy I just mentioned, and had to actually recess the firewall area back even further.
There are certainly small HEI dizzy's available too, so you have options galore...
#3 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 13 February 2006 - 09:18 PM
I personally use a Holden C/dore HEI that has been modified by ICE in Melb. to suit the Chev. A great unit and the smallest dia. you will find. Hope this helps.
