Lokka Installation
Posted 05 April 2008 - 04:47 PM
_Brewster_
Posted 19 April 2008 - 09:42 AM
Posted 19 April 2008 - 10:48 AM
Posted 19 April 2008 - 11:19 AM
There are 3 pins holding the 2 halves together...punch them out being aware that there are only 3 holes that go all the way through on the bottom half but there are 4 holes on the top half so mark the halves so it goes back together the same way.
Prise the 2 halves apart.
This is what you see..
Lift out the top spider gears...making sure you also get the thrust washers from inside...these are vital and must go back in with the Lokka.
Next..knock out the long centre pin right through from one side...same with the half pins...knock one through to the other then out that side.
This is what comes out...there are flat thin washers that stick to the inside of the carrier at the ends of the spider gears..makes sure you have the 4 out. Clean the inside of the carrier with a clean cloth.
Clean, gease and replace thrust washers in carrier.
Get new centre pin and old half pins ready.
Install bottom half of Lokka as per instructions...fit centre pin and line up for the joiner pins to go through the end hole.
Fit rest of Lokka as per instructions and 2 short pins also lining them up for pins..
Fit thrust washer to other half...tap together..all the time lining up pin holes to hold 3 centre pins in place..Tap home pins..Bingo!..Finished! Fit crown wheel..remembering the bolts are left hand thread. The measured gap between the 2 Lokka halves should be 4mm...but it is a bitch to measure.
You will need these punches.
_Brewster_
Posted 19 April 2008 - 11:48 AM
Posted 19 April 2008 - 12:01 PM
Posted 19 April 2008 - 12:15 PM
Maybe the Mods can make a sticky of it.?
Posted 19 April 2008 - 01:11 PM
All the installation instructions I have read state that the crown and pinion do not require re lapping as the bearings have not been disturbed. In theory it should bolt back into the exact same position as before.When re installing into the diff is it recommended to have the crown and pinion re lapped?
Posted 19 April 2008 - 01:57 PM
_GMV877_
Posted 23 April 2008 - 07:01 PM
enjoy it is exciting to drive!
_Torrie_Man_
Posted 08 June 2008 - 02:49 PM
Posted 08 June 2008 - 05:22 PM
Put it in there and make any extra comments as needed.
What sizes are those punches?
Grant..
Posted 08 June 2008 - 06:07 PM
Dont think there is one for bangos...axles wont take it anyway.
Grant Good idea..
about 4mm, 6mm and 8mm.roughly. Supercheap stuff...they come in a set.
Edited by rorym, 08 June 2008 - 06:08 PM.
Posted 29 July 2008 - 01:13 PM
i just rang up the shop that put the spool in and they gave me some for free.
Very happy with the LOKKA and didnt realise how much a spool makes your car handle like poo.
Evan.
Posted 29 July 2008 - 03:04 PM
_@milco@_
Posted 07 October 2008 - 08:58 PM
Posted 19 October 2008 - 09:02 AM
try give them a call.
Ev.
Posted 31 October 2008 - 11:22 AM
s
Posted 07 January 2009 - 10:03 PM
_UNVSM8_
Posted 24 March 2009 - 11:46 AM
Cheers Ben
#21
_Machine_
Posted 25 March 2009 - 10:34 AM
M.
#22
_UNVSM8_
Posted 25 March 2009 - 12:28 PM
#23
_UNVSM8_
Posted 25 March 2009 - 01:39 PM
#24
_Machine_
Posted 25 March 2009 - 02:04 PM
Cheers, M.
#25
_gh20_
Posted 26 March 2009 - 05:31 PM
