Sl/r Gauges?
38 replies to this topic
#26 MRLXSS
  • 12,413 posts
Posted 08 April 2008 - 09:06 AM
Great pics showing the 3 main different styles of guages...
I guess the late LX one (with the 2 seperate brake lights) would be the pricey ones, as they would have been A9X items...
I personally prefer the LH SLR white ones, they look cleaner, newer and sharper!
#27 _JBM_
_JBM_
Posted 08 April 2008 - 10:49 AM
A purely 4 cylinder one was made too with no selection.
My L34 tacho doesnt have the switch on it. To use it with a standard dizzy it needs to be adjusted internally, otherwise it will read double the actual revs.
James
#28 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 08 April 2008 - 11:00 AM
thats because it's a 4 cylinder tacho as per all L34's
#29 MRLXSS
  • 12,413 posts
Posted 08 April 2008 - 11:42 AM
Is that because of the twin point dizzys?
#30 _JBM_
_JBM_
Posted 08 April 2008 - 12:04 PM
Yes. The dizzy has 4 lobes on the shaft to open the points, instead of 8.
James
#31 _prrojo_
_prrojo_
Posted 08 April 2008 - 07:47 PM
I thought there was a post / thread saying that RARES are making yellow instrument decals , does any-one know of these ?
#32 _bek_lx330_
_bek_lx330_
Posted 10 April 2008 - 08:56 AM
I got one! I got one! Yey! :D
Picked one up here in my hometown y'day. A yellow needle cluster with the park brake light in the speedo in pretty good nick and all is in working order...
just wanted to let you know and thank everyone for their help and input! You guy's rock! :clap: :spoton: :clap:
#33 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 10 April 2008 - 10:31 AM
Yes, rares are doing the decals to suit yellow needle with park brake in speedo, you can see them on their website.
Good work Bek, good luck with it, you have a nice straight looking original car there, certainly a nice starting base should you ever choose to modify it at all.
#34 MRLXSS
  • 12,413 posts
Posted 10 April 2008 - 01:44 PM
Good Stuff Bek! Great to hear.
#35 jeffblanco
jeffblanco
  • 386 posts
  • Name:Mando
Posted 12 July 2020 - 05:06 PM
There are basically 5 sets of SLR gauges, I decided to go and take some pics of the 3 different sets I have. All are in very good condition so you can get an idea of what they should look like.
first up, LH. There are 3 different types of LH I have seen, the first has miles and KM, the second is as pictured, and the 3rd has 7 digits in the odometer while this one has 6
The next is the early LX SLR type
Late LX type. These appeared in around mid 77 and have the park brake in the bottom of the speedo as you can see.
Hi guy's,
I want to re do my instruments to look like the bottom picture.
According to this post by REDA9X the park brake light on the last of the LX cars were located below the km/h sign.
Where was the park brake light located in the earlier cars?
Regards Mando.
#36 yel327
  • 13,632 posts
Posted 12 July 2020 - 05:56 PM
Will be the same as a Holden dash. There was a new ADR applicable and GMH had to separate the brake fail light and the park brake light.
#37 jeffblanco
jeffblanco
  • 386 posts
  • Name:Mando
Posted 12 July 2020 - 09:49 PM
Thanks for the info.
Regards Mando.
#38 Shiney005
  • 9,578 posts
  • Car:Toyota Mirai
Posted 13 July 2020 - 09:36 AM
You can see the park brake / brake fail light, and the volts light at the top and bottom of the right hand gauges Mando.
#39 jeffblanco
jeffblanco
  • 386 posts
  • Name:Mando
Posted 13 July 2020 - 03:53 PM
Now I get it.
Thanks guy's
Regards Mando.
