Radiator: Is Aluminium Better Than Copper?
69 replies to this topic
#26 _the gts_
_the gts_
Posted 10 May 2008 - 02:09 AM
I like this thread it is very informative.
rory those rubber mounts look like they would be the go, what did you do with the earth wires that normally mount to the radiator bolts, still bolt them to the same place but on the body side?
#27 _1uzbt1_
_1uzbt1_
Posted 10 May 2008 - 12:17 PM
Generally I wouldnt be earthing anything back on the radiator,but do a strat current test when warm to check.
#28 ls2lxhatch
  • 5,332 posts
Posted 10 May 2008 - 02:05 PM
Some tech articles recommend grounding the radiator and others recommend you do not ground the radiator. They all agree that you must use appropriate coolant and test for stray current regularly using a multimeter (see Nulon document ) or dedicated device (Koolit Indicator). Apparently brass/copper radiators are also susceptible to stray current corrosion.
KOOL-IT� Electrolysis Indicator
So, why are we seeing more stray current related radiator failures these days? A good example of how
modern radiators are so vulnerable to stray current corrosion is that many of them are attached to the
vehicle by their plastic tanks, or are insulated from the vehicle chassis by rubber mounts.
Nulon Facts Sheet
Take electrolysis, for example. Before the days of front wheel drive and transverse-mounted engines, cooling system electrolysis was a rare occurrence. But today, with most cars and many light-duty trucks featuring electric cooling fans in conjunction with ungrounded plastic-tank radiators, cooling system electrolysis is becoming a frequent problem.
http://www.radiatorr...m/electrol.html
Early on, when electrolysis first cropped up as a problem in cooling systems, many mechanics attempted to solve the problem by grounding the heater or radiator in order to "collect" any stray voltage and route it to battery ground. But mechanics soon discovered that grounding a heat exchanger to "collect" stray current merely accelerated the damage to the heat exchanger.
http://www.birdsradi...lectrolysis.nxg
electrolysis and grounding 101
Edited by ls2lxhatch, 10 May 2008 - 02:13 PM.
#29 _rorym_
Posted 11 May 2008 - 09:17 AM
WONDERING WHAT MIX THE CIRCUIT/RACE GUYS ARE USING?...WE WERENT ALLOWED TO RUN GLYCOL ON THE BIKES BECAUSE OF ACCIDENTS. WHAT ARE YOU GUYS USING IN ALLOY RADIATORS?
#30 _the gts_
_the gts_
Posted 12 May 2008 - 03:37 AM
What fans are people using? Is there anything like the AU style that does not have to be butchered
#31 _1uzbt1_
_1uzbt1_
Posted 12 May 2008 - 10:35 AM
Mondeos.They fit perfectly over the core only on a torry rad.400x620mm are the dimensions.
#32 ls2lxhatch
  • 5,332 posts
Posted 12 May 2008 - 01:45 PM
Ford Mondeo fitted to LX Torana radiator.
Edited by ls2lxhatch, 12 May 2008 - 01:46 PM.
#33 dannygtrxu1
dannygtrxu1
  • 71 posts
Posted 12 May 2008 - 01:53 PM
Hi everyone
Im running a vs v8 radiator and ford au fans in my lj.
best thing i ever did and no more over heating anymore...
Danny.......
#34 TerrA LX
Posted 12 May 2008 - 01:55 PM
^ Is there much mods to fit the VS radiator?
#35 dannygtrxu1
dannygtrxu1
  • 71 posts
Posted 12 May 2008 - 02:02 PM
No VS radiator just fits in. but got to trim the radiator support a bit from where the old six radiator bolts up too.
Danny....
#36 _rorym_
Posted 12 May 2008 - 03:17 PM
Hi everyone
Danny.......
Thats really interesting...they are cheap as chips second hand....or even new...How did it mount?..Did you weld ears on it to bolt up?
#37 _1uzbt1_
_1uzbt1_
Posted 12 May 2008 - 05:10 PM
Hi everyone
Danny.......
Copper/brass one or the later ally ones??
#38 _rorym_
Posted 12 May 2008 - 05:25 PM
Think there were all alloy.
#39 _1uzbt1_
_1uzbt1_
Posted 12 May 2008 - 06:56 PM
The series III were ally,and are slightly different to the V6 rads,one being 35mm thick compared the V6 25mm and the v8s have a larger 38mm top fitting.
#40 dannygtrxu1
dannygtrxu1
  • 71 posts
Posted 12 May 2008 - 09:17 PM
The radiator has plastic tanks with an alloy core and its from a series III vs v8 auto.
RORYM--- ill try and get some pics up tomorrow. no welding needed just made up some brackets and bolted it all up. VERY tight fit but works really well..
Danny...
#41 _MAWLER_
_MAWLER_
Posted 14 May 2008 - 05:05 PM
Will be very interested to see what you've done/got/running ^
#42 _rorym_
Posted 18 June 2008 - 07:38 AM
Danny...Pics?
#43 _rorym_
Posted 09 July 2008 - 06:03 PM
DANNY!! PICS!!
#44 dannygtrxu1
dannygtrxu1
  • 71 posts
Posted 09 July 2008 - 07:17 PM
Here u go guys
https://cache.gmh-to.....u1/more pics/
Danny..
#45 _rorym_
Posted 10 July 2008 - 09:26 AM
Thats shit hot Danny...The fans wouldn't clear my Gilmer but I am looking at putting the 16" thermo on the front anyway...Nice work! :clap:
#46 _73LJWhiteSL_
_73LJWhiteSL_
Posted 10 July 2008 - 10:43 AM
I see you are also running a V8, which explains the fans behind the radiator.
IMHO you can't fit nothing other than the standard engine fan between the engine and radiator with a Holden 6 in an LJ. My electric fan is on the front.
Steve
Edited by 73LJWhiteSL, 10 July 2008 - 10:44 AM.
#47 _MAWLER_
_MAWLER_
Posted 12 July 2008 - 11:03 AM
Is that the standard, short nose, WP?
#48 dannygtrxu1
dannygtrxu1
  • 71 posts
Posted 12 July 2008 - 11:32 AM
^^^^ yes it is a short nose water pump
Danny...
#49 _v8slrtorana_
_v8slrtorana_
Posted 19 July 2008 - 12:02 AM
dannygtrxu1
What radiator hoses you running.
I dummy fitted a vs rad in mine today as my commy needs a new rad and the torana ones are too short.
#50 _conanricho_
_conanricho_
Posted 14 July 2009 - 06:44 PM
"dannygtrxu1
I dummy fitted a vs rad in mine today as my commy needs a new rad and the torana ones are too short."
also would like to know....cheers
