what 308 do i have qt9957** ch8?
As far as i know the motor is stock runs well dosent blo smoke not sure wat thou ova it is thou , plan is to giv it a freshen up mabe fit some pro comp alloy vn heads a lumpy cam, mid rise manifold,650 holley and swap it from my 4 door into my 2 door lj. also how would i check to make sure the motor hasent been stolen in the past ect, b4 i go throwin money at it? thanks.
308 identification
_turbolj_
, May 13 2008 04:55 PM
5 replies to this topic
#1 _turbolj_
Posted 13 May 2008 - 04:55 PM
Posted 13 May 2008 - 06:03 PM
its out of a kingswood, looks to be pre pollution. although if CH8 is the casting number it would be pollution.
I would steer clear of the pro comp heads but thats just me
Posted 13 May 2008 - 08:07 PM
It's not just you, Cohen... It's 3/4 of the automotive enthusiasts that are members of various forums
Tim
Tim
Posted 13 May 2008 - 08:43 PM
I was thinking along the lines of there being around 97.314159265358979323846264338327950288419716939937510582097494459230781640628620899862803482534211706% of people would not touch Procomp crapIt's not just you, Cohen... It's 3/4 of the automotive enthusiasts that are members of various forums
Tim
Edited by makka, 13 May 2008 - 08:51 PM.
Posted 14 May 2008 - 09:35 AM
It's a HZ 308 block, from just before the Zx series of engine numbers started (as the Qx series reached 999999 mid HZ).
#6 _turbolj_
Posted 14 May 2008 - 04:37 PM
wel looks like i wont b using procomp then, if 97.314159265358979323846264338327950288419716939937510582097494459230781640628620899862803482534211706% of people wont touch it.
